Main Studs for Mopar Aluminum block #2557126
10/01/18 04:53 PM
10/01/18 04:53 PM
Sac, CA, USA
N
ntstlgl1970 Offline OP
N
Sac, CA, USA
Looking for specs on the main studs for the aluminum block. Thread pitch, length etc. specifically for the oil pump pickup stud. My engine came with studs, but has a stock bolt for the oil pump. I already talked to ARP and they said their stud is not long enough to fully engage the all the threads on the aluminum block. I also talked to Arrow/Prefix and they did not respond to my repeated emails and questions. Looking for specs to find another stud from another engine maybe? LS etc. ?!?
My motor is at the machine shop and this is holding it up....
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2557798
10/02/18 05:33 PM
10/02/18 05:33 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
shruggy
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2558049
10/03/18 12:20 AM
10/03/18 12:20 AM
Sac, CA, USA
N
N
Sac, CA, USA
Cool, thank you. I’ll try calling him tomorrow.
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2558052
10/03/18 12:30 AM
10/03/18 12:30 AM
USA
hudsonhornet7x Offline
USA
Unless I am mistaken his name is Rick Talbot.
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2558695
10/04/18 12:39 AM
10/04/18 12:39 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
I have the same problem. Do you have one of the Mclaren blocks? The studs have no name on them and are 7/16x20 on one end and 12x1.75 on the other. ARP doesn't have them but told me an AUF-6.000-1B is the pick-up stud. Could be the guy that told me that didn't know they were too short. I have never gotten a reply from Arrow/prefix.
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2558816
10/04/18 11:14 AM
10/04/18 11:14 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Eric,
I emailed Prefix for you for the #3 main cap oil pick up stud,
waiting on their reply.
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: hudsonhornet7x] #2560379
10/07/18 03:08 PM
10/07/18 03:08 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Correct. I need to correct that in my phone
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2561375
10/09/18 01:05 PM
10/09/18 01:05 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Eric,
Dale Matthews emailed me back just now and they have the oil pick up stand off available. It goes on top of the main cap stud same as in my engine
What is your zipcode for shipping?
They are $13.21 email RylisPro@gmail.com to order
Thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: RylisPro] #2561490
10/09/18 05:03 PM
10/09/18 05:03 PM
Charleston
sixpackgut Offline
sixpackgut  Offline
Charleston
Originally Posted By RylisPro
Eric,
Thanks!
Just sent you $30. Send me 2 of them
Re: Main Studs for Mopar Aluminum block [Re: sixpackgut] #2561562
10/09/18 07:40 PM
10/09/18 07:40 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Eric & Ray,
I emailed Prefix on shipping quotes for your respective address. Will get a reply from them tomorrow.
If anyone else needs parts from Prefix email us your shipping address at RylisPro@gmail.com for a quote.
Thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2561714
10/10/18 12:44 AM
10/10/18 12:44 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
Are the studs available and are they 12x1.75 by 7/16x20 and are the standoffs 7/16 where they fit the stud?
Re: Main Studs for Mopar Aluminum block [Re: Stewart] #2561739
10/10/18 01:35 AM
10/10/18 01:35 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I'm not sure if the aluminum block main studs are available separately from the block?
The #2, #3 and #4 main caps utilize a vertical 4 bolt mounting structure for added strength. All of the 5 main caps utilize the production cross bolts.
J 80-01-0001 M8 X 1.25 X 35 HEX FLANGE HD qty. of 10
Also the main studs and caps are a unique size for the aluminum 6.1 block casting. These will NOT fit any production cast iron cylinder block. I am pretty sure the 16 main studs and part numbers are:
H 80-03-0002 STUD - 7/16 BOTH ENDS - SHORT qty. of 6
G 80-03-0001 STUD - 7/16 BOTH ENDS - LONG qty. of 10
on the instructions .pdf and will have to email Prefix to confirm.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: RylisPro] #2561748
10/10/18 02:02 AM
10/10/18 02:02 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Here are some cool schematics on the 6.1 aluminum block if anyone needs them.
Pay attention to the torque sequence for the main studs and cross bolts along with the increasing torque per fastener.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2562217
10/11/18 12:02 AM
10/11/18 12:02 AM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
My blocks are different. I have 4 bolts + side bolts on all 5 caps with one end metric and 1 end Std.
Re: Main Studs for Mopar Aluminum block [Re: Stewart] #2562284
10/11/18 02:26 AM
10/11/18 02:26 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Stewart,
You have a couple of McLaren blocks don't you? Those are different than the 6.1 Gen 3 aluminum blocks obviously.
If your main cap studs have the metric ends that go into the block and the 7/16 end that holds down the main cap, I'm thinking that the oil pick up stand off may work if you modify it with a 7/16-20 fine thread helicoil maybe?
Unfortunately the main studs on our 6.1 aluminum block looks like they are 7/16-14 coarse thread.
There is no way that is a fine thread. You can see the oil pick up stand off in the background.
I had forgotten to email Prefix until the last minute today haha I'm still out of town.
Awaiting their reply.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2562313
10/11/18 06:33 AM
10/11/18 06:33 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
might want to look in to these , won't help with the pick up tube.
ARP Chevrolet Small Block LS/WP Warhawk LS aluminum block
Kit #:134-5802
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2562373
10/11/18 12:01 PM
10/11/18 12:01 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Hey Eric,
Prefix got back to me they have the main stud in hand which looks to be like a 7/16-14 coarse thread on both ends. I had asked for the specs but they didn't respond with detailed info?
They are $10 bucks each and I had them ship one to you via the cheapest way possible. I'll send you an invoice but don't worry about it right now. I would rather have you pay me in person at the Spring Fling Speed Festival at Big Willow in April 2019 haha!
If anyone else needs one please email us your zipcode.
Thanks!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2562460
10/11/18 02:54 PM
10/11/18 02:54 PM
Mrytle Beach SC
johnscudashop Offline
Mrytle Beach SC
I wish Arrow had these avail back in 2010 when I bought my Aluminum crate hemi.. I ended up making some stand offs for mine.. One thing I noticed. When I saw sixpackgut (Ray's) block the other day, I only saw 3 or 4 threads sticking out above the stud nut. I remember mine had alot more Threads above the main cap nut
Re: Main Studs for Mopar Aluminum block [Re: RylisPro] #2562465
10/11/18 03:38 PM
10/11/18 03:38 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
Here is the part number and specs on the invoice for the main stud that got sent out to ntstlgl1970
Part # 80-03-0001
STUD; MJ12X.4375X4.452 190 4340, 190 KSI MIN, BLACK OXIDE FINISH. STUD-MAIN CAP LONG
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2562520
10/11/18 05:50 PM
10/11/18 05:50 PM
Loganville, GA
Stewart Offline
Stewart  Offline
Loganville, GA
Don't know what I was thinking when I said all 5 caps were 4 bolt, only 2,3 and 4. No wait, it was not me. I was hacked, ya thats what happened, I would never make that mistake. Think i will order the pickup stud from the 5.7 ARP kit and see I can get it to work it works.
PS. It was me.
Re: Main Studs for Mopar Aluminum block [Re: ntstlgl1970] #2563425
10/13/18 03:40 PM
10/13/18 03:40 PM
Sac, CA, USA
N
N
Sac, CA, USA
Thanks Ariel and sixpackgut,
Should have my engine back on track next week. Looking forward to see what these new heads will do for me
