just got home from the track, and...
#2556418
09/29/18 10:10 PM
09/29/18 10:10 PM
dartman366
Mt. Vernon, Ohio
set a new best with the car on a iffy at best track, went 6.15@110 mph 1/8th mile twice with a 1.29 60ft first pass and 1.32 60ft the other, this car just keeps amazing me.
Re: just got home from the track, and...
[Re: slantzilla]
#2556758
09/30/18 08:06 PM
09/30/18 08:06 PM
dartman366
Mt. Vernon, Ohio
Around a 9.65. I would say closer to mid to upper 9.70's in my car, and definately in the 135.xx mph range,,I never even got to try out my new air pan, need to get to a TnT and not a regular event to play with it, cause I figure I am going to have to jet up just a little in the cooler weather.
[Re: max_maniac]
#2556761
09/30/18 08:10 PM
09/30/18 08:10 PM
dartman366
Mt. Vernon, Ohio
set a new best with the car on a iffy at best track, went 6.15@110 mph 1/8th mile twice with a 1.29 60ft first pass and 1.32 60ft the other, this car just keeps amazing me. Anything to do with going to a BB ---- yes Russ I think it may have somthing to do with it, LOl! Yes Dave it's a low deck 511 with the Trick flow 240's untouched and the untouched TF intake, 2" adapter spacer and a 1050 Dommy.
[Re: mopar dave]
#2556796
09/30/18 10:17 PM
09/30/18 10:17 PM
dartman366
Mt. Vernon, Ohio
never dyno'd, was going to but with everything that I needed to do to get it ready for that spring, it just wasn't in the battle plan, maybe when I freshen it up, I may try to get it on the pump then.
[Re: dartman366]
#2556797
09/30/18 10:20 PM
09/30/18 10:20 PM
Posts: 5,160 Texas
dannysbee
Texas
How much does it weigh with you in it?
Getting old just means you were smarter than some and luckier than others.
[Re: dannysbee]
#2556801
09/30/18 10:28 PM
09/30/18 10:28 PM
dartman366
Mt. Vernon, Ohio
not real sure but with the small block and 904 John Holt has it in his file as 2951 wet weight since then I put in the big block and 727 and I am around 215,,so probably a little over 3200, I hope to get it back to him and have the car gone over haven't been back to his chassis shop since the changes.
[Re: dartman366]
#2556804
09/30/18 10:40 PM
09/30/18 10:40 PM
Posts: 11,730 Portage,michigan
B3422W5
Portage,michigan
Wonder what it would have run if you had just popped those heads you were using off the smallblock and put Indy heads on it. 9.60’s? And not went to the dark side
[Re: dartman366]
#2556809
09/30/18 10:53 PM
09/30/18 10:53 PM
Posts: 5,160 Texas
dannysbee
Texas
Running really well for standard ports and 3200-3300 lbs.
[Re: dartman366]
#2556839
10/01/18 12:33 AM
10/01/18 12:33 AM
Posts: 6,354 Aurora, Oh.
max_maniac
Aurora, Oh.
Around a 9.65. I would say closer to mid to upper 9.70's in my car, and definately in the 135.xx mph range,,I never even got to try out my new air pan, need to get to a TnT and not a regular event to play with it, cause I figure I am going to have to jet up just a little in the cooler weather. Don't under estimate your car Bill. In my 3480 POUND PIG when I ran 6.21 in the 1/8 I ran a 9.75 in the 1/4!! I say you are easily in the 9.6x range
[Re: max_maniac]
#2556869
10/01/18 01:46 AM
10/01/18 01:46 AM
Posts: 20,203 PA.
pittsburghracer
"Little"John
"Little"John
PA.
A 6.14 was a 9.73 with my old small block combo. 6.00 was low 9.40’s with my current combo running out of cam.
