just got home from the track, and... #2556418
09/29/18 10:10 PM
09/29/18 10:10 PM
Mt. Vernon, Ohio
dartman366 Offline OP
Mt. Vernon, Ohio
set a new best with the car on a iffy at best track, went 6.15@110 mph 1/8th mile twice with a 1.29 60ft first pass and 1.32 60ft the other, this car just keeps amazing me. up
Re: just got home from the track, and... [Re: dartman366] #2556419
09/29/18 10:14 PM
09/29/18 10:14 PM
Easton, PA
68DART360 Offline
68DART360  Offline
Easton, PA
Re: just got home from the track, and... [Re: dartman366] #2556465
09/30/18 12:05 AM
09/30/18 12:05 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Anything to do with going to a BB ---- drive
whistling
Re: just got home from the track, and... [Re: dartman366] #2556505
09/30/18 01:19 AM
09/30/18 01:19 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Awesome! boogie
Re: just got home from the track, and... [Re: dartman366] #2556577
09/30/18 12:04 PM
09/30/18 12:04 PM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
Nice. 511 right?
Re: just got home from the track, and... [Re: dartman366] #2556582
09/30/18 12:12 PM
09/30/18 12:12 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Congratulations on the new best!
Re: just got home from the track, and... [Re: humpty] #2556590
09/30/18 12:27 PM
09/30/18 12:27 PM
tboomer Offline
tboomer  Offline
Good job Bill!
Re: just got home from the track, and... [Re: dartman366] #2556617
09/30/18 01:34 PM
09/30/18 01:34 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Sounds pretty stout. Where would that correlate in 1/4 ET & MPH... mid 9s at 135-ish?
Re: just got home from the track, and... [Re: dartman366] #2556652
09/30/18 02:56 PM
09/30/18 02:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Around a 9.65. punkrocka
Re: just got home from the track, and... [Re: slantzilla] #2556758
09/30/18 08:06 PM
09/30/18 08:06 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
I would say closer to mid to upper 9.70's in my car, and definately in the 135.xx mph range,,I never even got to try out my new air pan, need to get to a TnT and not a regular event to play with it, cause I figure I am going to have to jet up just a little in the cooler weather. work
Re: just got home from the track, and... [Re: max_maniac] #2556761
09/30/18 08:10 PM
09/30/18 08:10 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
whistling
yes Russ I think it may have somthing to do with it, LOl!
Yes Dave it's a low deck 511 with the Trick flow 240's untouched and the untouched TF intake, 2" adapter spacer and a 1050 Dommy. up
Re: just got home from the track, and... [Re: dartman366] #2556787
09/30/18 09:36 PM
09/30/18 09:36 PM
Mt Morris Michigan
Mt Morris Michigan
Ok thanks. You had the 511 dyno'd couple years ago. What were the numbers?
Re: just got home from the track, and... [Re: mopar dave] #2556796
09/30/18 10:17 PM
09/30/18 10:17 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
never dyno'd, was going to but with everything that I needed to do to get it ready for that spring, it just wasn't in the battle plan, maybe when I freshen it up, I may try to get it on the pump then.
Re: just got home from the track, and... [Re: dartman366] #2556797
09/30/18 10:20 PM
09/30/18 10:20 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
How much does it weigh with you in it?
Getting old just means you were smarter than some and luckier than others.
Re: just got home from the track, and... [Re: dannysbee] #2556801
09/30/18 10:28 PM
09/30/18 10:28 PM
Mt. Vernon, Ohio
Mt. Vernon, Ohio
not real sure but with the small block and 904 John Holt has it in his file as 2951 wet weight since then I put in the big block and 727 and I am around 215,,so probably a little over 3200, I hope to get it back to him and have the car gone over haven't been back to his chassis shop since the changes.
Re: just got home from the track, and... [Re: dartman366] #2556804
09/30/18 10:40 PM
09/30/18 10:40 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Wonder what it would have run if you had just popped those heads you were using off the smallblock and put Indy heads on it. 9.60’s?
And not went to the dark side beer
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: just got home from the track, and... [Re: dartman366] #2556809
09/30/18 10:53 PM
09/30/18 10:53 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Running really well for standard ports and 3200-3300 lbs.
Re: just got home from the track, and... [Re: dartman366] #2556839
10/01/18 12:33 AM
10/01/18 12:33 AM
Aurora, Oh.
max_maniac Offline
max_maniac  Offline
Aurora, Oh.
Don't under estimate your car Bill. In my 3480 POUND PIG when I ran 6.21 in the 1/8 I ran a 9.75 in the 1/4!! I say you are easily in the 9.6x range drive
Re: just got home from the track, and... [Re: max_maniac] #2556869
10/01/18 01:46 AM
10/01/18 01:46 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
A 6.14 was a 9.73 with my old small block combo. 6.00 was low 9.40’s with my current combo running out of cam.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: just got home from the track, and... [Re: dartman366] #2556911
10/01/18 10:17 AM
10/01/18 10:17 AM
Mt Morris Michigan
Mt Morris Michigan
With SB+727 my barracuda was 3300 with me. I'm 195#. With BB+727 it's 3380# with me. So the BB only added 80# and it's full of hard block as well.
