Re: Holley carburetor
[Re: Coke]
#2556057
09/28/18 05:35 PM
09/28/18 05:35 PM
Posts: 1,645 Phila. Pa.
Mattax
Phila. Pa.
That particular one is made or distributed by Scott Drake. https://www.summitracing.com/search/brand/scott-drake/department/engines-components/product-line/scott-drake-valve-cover-oil-caps?N=401272%2B4294949512&SortBy=Default&SortOrder=Ascending&autoview=SKU&ar=1 And there are cheaper ones like these: https://www.summitracing.com/parts/snn-10071and https://www.summitracing.com/parts/trd-4999Since you have to ship, lets make sure we can match a PCV Valve for it. Most likely something for a Ford 'CJ' Cobra Jet or such. But most important will be that its the correct size for the grommet or hose. I collected some information about sizes but wont be able to look for it until tonight.
[Re: Coke]
#2556231
09/29/18 12:06 PM
09/29/18 12:06 PM
Posts: 340 Vitoria, Spain
Coke
Vitoria, Spain
Ok don,t worry.They are not expensive parts,so i can order a couple of pcv valves and use the most aproppiate.The stant cap you posted looks good to start.What i don,t know is why all these breathers-pcv caps do throw vapors to the atmosphere instead to have a connection tube for the air filter.
[Re: Coke]
#2556281
09/29/18 02:29 PM
09/29/18 02:29 PM
Mattax
Phila. Pa.
Ok don,t worry.They are not expensive parts,so i can order a couple of pcv valves and use the most aproppiate.The stant cap you posted looks good to start.What i don,t know is why all these breathers-pcv caps do throw vapors to the atmosphere instead to have a connection tube for the air filter. OK. You can try one for a Chrysler v-8 and if you want to experiment, ACDelco CV736c has is reported to be good for engines with lower manifold vac, and has 3/8" connection (suction side). I don't have the other diameter. As to why so many open breathers? That might be a sociology question as much as a technical one. On a good running engine, the most of the vapors will to through the PCV valve and the breather is just air in. Before 1960 or so, cars here used draft tubes to evacuate the crankcase. The low pressure under the moving car sucked the vapors out. Probably the same in Europe. To address the greater blow at high rpm, wide open throttle, some racers use vacuum pumps or evacuation tubes in the exhaust. One problem with PCV valves is with engines that have poor manifold vacuum at idle. There has to be enough vacuum at idle for the valve to be in the most restrictive position. I *think* if your engine can get 11 - 12"Hg at idle, it should be OK with a stock PCV Valve. This why some people experiment with different valves like that CV736. I had plans to test the flow of PCV valves but that's been sidetracked.
[Re: BLACKHEMIRR]
#2556322
09/29/18 04:52 PM
09/29/18 04:52 PM
Coke
Vitoria, Spain
If the PCV doesn't fix it for you, I would suggest checking everything that would make it run rich. Make sure the air bleeds are not blocked (they are the 4 very small passages on the front, just under the choke plate). I think the idle air bleeds are the outer 2. Make sure the floats don't have any gas in them, and are adjusted right. Make sure you have the correct gasket between the carb body and the metering block. Not a likely cause, but make sure it doesn't have some crazy sized jets in the front, (should be around a 76) because that could make it idle a little rich. I would definitely put another PV in it too, just to completely rule that out. Hello,i blew all the cicuits with air pressure when i removed the carb a couple of days ago and i didn,t find a blocked passage.I removed the primaries metering plate to check the PV valve. Fuel bowls level ok,in the botton of the window,drip a bit of fuel if i shake the car. I put a new body gasket that i had stored from a Holley trick kit i bought several years ago.All the holes match.I just had to make another hole for a center pin,cause the body has two and the gasket only had for one. I found that the throttle body has threads for eight bolts and i only had six. I started to imagine horrible things about where the two screws could have gone until i read in the Urich,s book that even having 8 threads,only the earlier models came with 8 screws. However the two center bolts were in the wrong threads.I put them where it should to go(Taking the book pictures as a guide)and tightened them a bit using an impact screw driver.That solved the vac.leak i had between the plate and the body at the front of the carb.The right side continues leaking a bit(Tested with that smoke machine that Mattax likes ) Both main Jets are 70s. I know you can change air bleeds in the latest carbs.That is a good improvement.
[Re: Mattax]
#2556331
09/29/18 05:52 PM
09/29/18 05:52 PM
Coke
Vitoria, Spain
OK. You can try one for a Chrysler v-8 and if you want to experiment, ACDelco CV736c has is reported to be good for engines with lower manifold vac, and has 3/8" connection (suction side). I don't have the other diameter. As to why so many open breathers? That might be a sociology question as much as a technical one. On a good running engine, the most of the vapors will to through the PCV valve and the breather is just air in. Before 1960 or so, cars here used draft tubes to evacuate the crankcase. The low pressure under the moving car sucked the vapors out. Probably the same in Europe. To address the greater blow at high rpm, wide open throttle, some racers use vacuum pumps or evacuation tubes in the exhaust. One problem with PCV valves is with engines that have poor manifold vacuum at idle. There has to be enough vacuum at idle for the valve to be in the most restrictive position. I *think* if your engine can get 11 - 12"Hg at idle, it should be OK with a stock PCV Valve. This why some people experiment with different valves like that CV736. I had plans to test the flow of PCV valves but that's been sidetracked. Interisting. i have seen that Moroso sells a system wich threads a tube in the header close to the out for this purpouse. Also ,i have done a new test today. I have stolen the pcv valve from my Jeep 5.2 magnum wich has a 3/8 nipple and i have connected to the 3/8 port in the rear of the carb. The idle is erratic and low rpms when the pcv valve is connected.Rightnow ,this thing needs an open 6-7mm (Sorry for the metric,1/4"?) hole for a decent idling . When that port is open it idles around 750-800 and seems to throw less smoke and fuel smell.However the engine was still cold and i haven,t had the time for warming it up. Regards,
[Re: crackedback]
#2556382
09/29/18 08:31 PM
09/29/18 08:31 PM
Coke
Vitoria, Spain
That camshaft should not require any type of "drilling" anything on the carb to run properly.
That,s what i think.This cam is more mild than wild. The trouble has to be in the carb.I think that it creates a rich condition and needs that air for compensating it or something. In the end a fixed leak is a temporary solution..
[Re: crackedback]
#2556395
09/29/18 09:01 PM
09/29/18 09:01 PM
Coke
Vitoria, Spain
Turn the idle UP using the adjustment screw on the carb. 800 rpm in park/neutral.
Where are the idle mixture screws set? Most of the time if you leave them at 1 1/2 turns out, it's going to be rich.
Is fuel dripping in from the boosters?
The issue IS NOT anything related to the PCV or booster. Isolate the intake and solve the carb/timing issue and worry about the other stuff later.
The car has manual gearbox,are not 800 rpm are a bit high? If i use the idle screw i loss the transfer slots adjustment.Don,t understand the Holley design,why that screw is so accessible. The mixture idles are 1&1/2 or 1&1/4 (i don,t remember how i set them last time)turns out. Tomorrow i will check if i see fuel dripping from the boosters. Also it has manual brakes,the only thing connected to manifold are the headlights covers.The vacuum advance does not work so i have plugged the port. Thanks
[Re: crackedback]
#2556702
09/30/18 05:26 PM
09/30/18 05:26 PM
Coke
Vitoria, Spain
Lose transfer slot? If the mix screws don't do anything, it's likely dropping fuel in from somewhere else (ruptured PV diaphram) or dripping boosters is likely.
Oh,they do.Very strange things but they do The pcv diaphragm is ok and i haven,t seen the boosters dripping at idle. I have done several tests today ,engine at 170 celsius and every time a diffent thing occurs here,very confusing. Let me repeat the tests again,to see if i,m able to get a better conclusion.I will record another video to show you how this is going on. Meanwhile a bit offtopic,but i need to order some parts,a vacuum canister for example.The broke unit i got is the part 3656766.I have seen it on the web listed as a part for small block dist.There is another part number for BB i think. Do you know if this part is correct for this distributor (MP electronic ign)or maybe a previous owner made it to fit ? Thanks
[Re: Mattax]
#2560308
10/07/18 12:27 PM
10/07/18 12:27 PM
Coke
Vitoria, Spain
Broken? Difficult item to break. Did you put a vacuum pump on it? Yes, i did: https://youtu.be/WvjHgs5YX8cI continue studying the carb,just to become familiar with the circuits. Just one question:Wich holley carburetors had auxiliary idle air bleeds? Had that circuit The 4160 factory installed on latest 60s Chryslers ? I did notice that the gasket does not have a hole for the ports marked with the yellow circle: I have a set of spare gaskets and neither have them. On the orher hand ,there is a picture in the Urich&Fisher book wich shows a correct gasket for the 4160 that came in the 68-up Chryslers, and it has the hole for those ports.
[Re: Mattax]
#2562592
10/11/18 09:00 PM
10/11/18 09:00 PM
Coke
Vitoria, Spain
You mentioned its a M[i][/i]opar performance distributor. It will either have been made by Chrysler or Mallory. The main difference is the advance mechanism. The vacuum advances are probably the same. Any vacuum advance for a Chrysler built B/RB magnetic pickup distributor should physically fit and work. The differences will be the internal spring, and the notch which limits the maximum degrees, and the preload adjustment on the spring.
Beware of that. I just have received the new part that i had ordered.It was listed as a direct replacement part for my canister ,but it is not. As you can see,they are symmetric,it means the lever and the bracket are inverted. Here are a couple of pictures,just in case it can helps to someone else: https://ibb.co/eO2sG9https://ibb.co/bS6Kw9
