starter won't dis-engage #2556086
09/28/18 08:33 PM
09/28/18 08:33 PM
Shelby, Ohio
2
2abodymcodes Offline OP
Shelby, Ohio
key off, soon as you hook up the battery the starter engages. is there a way to test the starter relay before I replace it ?
Re: starter won't dis-engage [Re: 2abodymcodes] #2556100
09/28/18 09:30 PM
09/28/18 09:30 PM
there should be no continuity between the large threaded "batt" stud and the mini bolt on brown wire "solenoid" terminal. Same thing on the large/small starter terminals (no continuity). It is a good precaution to pull a batt cable before switching the meter to ohms. EDIT Which I'm sure you will (just a caveat) take off the main cable/brown wire either at the starter or at the SR before testing either component cuz with the wires still connected, if one device has continuity both em at their terminals will show continuity. holler (with) what you find out.
Re: starter won't dis-engage [Re: RapidRobert] #2556110
09/28/18 09:56 PM
09/28/18 09:56 PM
Shelby, Ohio
2
Shelby, Ohio
Is there a way to check that without an ohm meter ?
Re: starter won't dis-engage [Re: 2abodymcodes] #2556116
09/28/18 10:25 PM
09/28/18 10:25 PM
possibly a flashlight battery/flashlight bulb & several jumper wires with alligator clips. Likely you could take the top of a flashlight & jump from the center terminal of the top battery & the copper "slide" on the side that comes up from the lower battery negative bottom (whichever way is easiest for you with what you have). it wouldn't be near the same voltage but if it does show continuity then you know that that is the problem.
Re: starter won't dis-engage [Re: RapidRobert] #2556128
09/28/18 10:51 PM
09/28/18 10:51 PM
Shelby, Ohio
2
Shelby, Ohio
Ok. Thanks
Re: starter won't dis-engage [Re: 2abodymcodes] #2556169
09/29/18 02:39 AM
09/29/18 02:39 AM
Do this first: Pull the yellow wire/terminal off of the "ign" terminal on the starter relay then hookup the battery & see if it cranks by itself like it is doing now (with key off).
Re: starter won't dis-engage [Re: RapidRobert] #2556237
09/29/18 12:23 PM
09/29/18 12:23 PM
Shelby, Ohio
2
Shelby, Ohio
Ok, I removed that wire and it no longer cranks. What does that mean ?
Re: starter won't dis-engage [Re: 2abodymcodes] #2556239
09/29/18 12:25 PM
09/29/18 12:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
relay is bad
Don't be the exception.
Re: starter won't dis-engage [Re: Supercuda] #2556244
09/29/18 12:36 PM
09/29/18 12:36 PM
Shelby, Ohio
2
Shelby, Ohio
Yep just figured that out, going after a new one. Thanks all
Re: starter won't dis-engage [Re: 2abodymcodes] #2556245
09/29/18 12:42 PM
09/29/18 12:42 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
good luck
Re: starter won't dis-engage [Re: 2abodymcodes] #2556297
09/29/18 03:28 PM
09/29/18 03:28 PM
Which wire?, the yellow one? The only way plugging it in could make it crank WO the key on is if the yellow wire/terminal is hot all the time which would point upstream toward the ign sw as opposed to the relay cuz the yellow wire is only hot when the key is turned all the way to "start". (I feel like I missed something).
Re: starter won't dis-engage [Re: RapidRobert] #2556473
09/30/18 12:20 AM
09/30/18 12:20 AM
Shelby, Ohio
2
Shelby, Ohio
Someone suggested tapping on the ralay with a screwdriver . I did that while I removed the yellow wire to test the cranking.after I hooked the yellow wire back up, everything works as it should. I guess the relay was stuck so I'm getting a new one.
Re: starter won't dis-engage [Re: 2abodymcodes] #2557396
10/02/18 02:32 AM
10/02/18 02:32 AM
Good idea on the tapping (I learned something) & that would (& did) certainly pinpoint the culprit.
