Page 4 of 8 1 2 3 4 5 6 7 8
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Kern Dog] #2557349
10/02/18 12:05 AM
10/02/18 12:05 AM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Originally Posted By Frankenduster
I agree but how far off does it have to be to be THIS bad?
A loss at high rpm would mean the cam would have to be WAAAAY advanced, right?
I had a 318 in a 74 Duster that was an absolute PIG out of the hole. It would not even peel out on gravel. It ran smooth as glass, quiet and nice. I swapped distributors, carburetors, spark boxes, I cranked the static timing to the moon...nothing made any difference worth mentioning. I pulled the timing cover to see that the cam sprocket was 2 teeth off the mark retarded ! I replaced the set since the chain had slop. Once back together, it would peel out easily on pavement and ran just as smooth as before.
I was just stirring the pot.
@Goody
You said in your original post that the AFR goes lean the closer it gets 4k, but the fuel pressure remains steady all the way through. I'm going to say carb and not just because it's almost the only thing left at this point. lol. It really does sound like fuel starvation. If it were spark it wouldn't go lean and right up where it noses over it would get real choppy like hitting a rev limiter.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: MarkZ] #2557353
10/02/18 12:11 AM
10/02/18 12:11 AM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Ignition misfires certainly cause lean AFR readings. The cylinders pump pure oxygen ["air"] across the wideband, it's an oxygen sensor, not a fuel sensor.
We'll see here soon, there are only so many things that can cause it. Coil is next, it's newer, but a weak spark could be dropping out, I suppose.
From there I'll rob the rebuilt 600 AFB from the Dart and stick it on there.
After that, I'll find some Tannerite. ozbbq
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557400
10/02/18 02:39 AM
10/02/18 02:39 AM
Please hurry!
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557441
10/02/18 08:43 AM
10/02/18 08:43 AM
Mass
charge70 Offline
charge70  Offline
Mass
Did you happen to check float drop when you had the carb apart?
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: charge70] #2557447
10/02/18 09:10 AM
10/02/18 09:10 AM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Yes, within the 15/16"-1" spec for edelbrock, 7/16" when shut
2020 RAM 1500
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557488
10/02/18 10:53 AM
10/02/18 10:53 AM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Fuel pressure does not mean fuel in the bowls. You could be out flowing the needle and seats add that to questionable fuel pressure and there you go.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: FurryStump] #2557614
10/02/18 01:01 PM
10/02/18 01:01 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I understand. The fuel height within the carb is to spec and to the top of the baffles, validated by running the electronic fuel pump then pulling the air horn. In addition the fuel pressure was validated at 5-6psi with a mechanical gauge on the windshield while driving.
I would fine it hard to imagine going from an idle directly to 4000rpm with no load could starve the carb. Perhaps a sustained 2nd/3rd gear pull, but free revving in neutral doesn’t demand much fuel.
2020 RAM 1500
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557623
10/02/18 01:15 PM
10/02/18 01:15 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
I agree, I don’t think it’s fuel, but it might drop the bowls enough to screw around with the air bleeds a/f ratio. I had 5 lbs at the gauge and it would drop to 4 lbs. you would think if you have pressure you should be good, but I needed to increase the needle an seat and increase the fuel supply so the velocity of the fuel into the carb was quick enough not to let the level drop. I truly believe its your tach. The way it goes right to 4000 backs off a hair goes right back to 4000 and repeats. I have seen it before. smile
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557636
10/02/18 01:23 PM
10/02/18 01:23 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
I’d be very surprised to find this was a fuel supply related problem.
I’m not 100% convinced it’s not valvetrain, but it certainly appears that area is decent, since the heads and cam have already been successfully run on another motor.
When it comes to troubleshooting electrical stuff, whenever possible I like to start out by swapping out “everything”.
For the ignition, I’d see if you could borrow an old points distributor and coil/ballast resistor, and hot wire it to the battery.
If not, then I’d swap in a “known good” distributor, and hot wire in another box/coil/resistor.
I would use none of what’s on the motor now in the ignition system, including the primary wiring.
All that being said........ disconnecting the tac is too easy to not try that first.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557645
10/02/18 01:47 PM
10/02/18 01:47 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Is your battery good???
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: B3422W5] #2557678
10/02/18 02:36 PM
10/02/18 02:36 PM
God's Country Maryland
GODSCOUNTRY340 Offline
It takes 30 seconds to unhook the tach from the negative side of the coil, I've seen a bad tach cause your problem.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GODSCOUNTRY340] #2557733
10/02/18 04:09 PM
10/02/18 04:09 PM
STL
cdstl Offline
cdstl  Offline
STL
What he said
1972 Cuda 340 4 speed, 2001 Ram CTD 4x4 6 speed, 1970 Duster 408 4 speed, 1996 Ram 5.9 2x4 auto, 1965 Coronet 500
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557928
10/02/18 08:36 PM
10/02/18 08:36 PM
Washington
madscientist Offline
Washington
Originally Posted By GoodysGotaCuda
Originally Posted By pittsburghracer
So I’m guessing you didn’t degree the cam in.
Nope. There's no reason why it shouldn't run fine installed dot-dot with two different timing gear sets.
So you'll have no idea where the cam timing and evidently you don't care.
Try and not be offended when I say that you shouldn't assemble engines. For you, or anyone else. Until you learn how to degree a cam, and WHY you do it, every single time.
I can give you reasons why dot to dot is a bad way to do it, but you wouldn't care.
There is no reason EVER to skip the simple process of degreeing a cam. EVER.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: madscientist] #2557933
10/02/18 08:47 PM
10/02/18 08:47 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Thanks for the feedback.
2020 RAM 1500
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: madscientist] #2557940
10/02/18 09:06 PM
10/02/18 09:06 PM
Guitar Jones Offline
There actually are good reasons to not degree a cam every single time, but you wouldn't care so why bother.
Let us know when the coil or distributor fix your problem.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: GoodysGotaCuda] #2557942
10/02/18 09:12 PM
10/02/18 09:12 PM
Badham Co.
Y
Y3 70 BEE Offline
Y3 70 BEE  Offline
Y
Badham Co.
Make sure the tabs on the floats that touch the needle and seat are bent correct. People mess with them incorrectly and the float level may look to be correct but is not.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Guitar Jones] #2558007
10/02/18 11:02 PM
10/02/18 11:02 PM
Washington
Washington
Yeah, don't degree the cam if it's the same cam and the same timing set. That's about it. Other than that, degree the cam. Takes less than 20 minutes.
I've seen name brand [censored] that when used together were 8 degrees off. And that was good, quality parts. They just had tolerance stack up.
Again, you degree the cam every time. Unless it's the same parts. It's not that hard.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: madscientist] #2558035
10/02/18 11:49 PM
10/02/18 11:49 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I think you are wasting your breath. You can only help those that want to do things the right way.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: pittsburghracer] #2558057
10/03/18 12:52 AM
10/03/18 12:52 AM
Right! The factory is degreeing every single engine that comes down the line. Moving the cam 2 degrees changes its peak power band about 50 rpms. So moving it 8 degrees changes it about 200 rpms. You figure 8 degrees advanced or retarded that is a spread of about 400 rpm. Ooh, I can feel the difference already.
Re: LA 360 - Hits a wall at 4,000rpm - *not cam timing* [Re: Guitar Jones] #2558066
10/03/18 01:33 AM
10/03/18 01:33 AM
PA.
"Little"John
"Little"John
PA.
Wow. I guess I give some guys more credit than they deserve.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
