biggest tire on 1967 plymouth belvedere?????? #2555308
09/26/18 11:49 PM
09/26/18 11:49 PM
ohio
JMracin Offline OP
JMracin  Offline OP
ohio
Hey y'all I have a 1967 plymouth belvedere 1 two door sedan, Iam planning on using a U.S. tool spring relocation kit, also narrowing the 8 3/4 rear possibly 2" or 3". The wheels Iam using are 15 x 10 with 3 3/4 inch backspace.Factory wheel wells will be cut out replaced with wheel tubs. I have a bare e-body rear end housing Iam going to have cut down. Has anyone here done the same thing? Can y'all share your set ups? Iam hoping for around a 14x32 slick at this point.
'67 plymouth belvedere 2dr sedan
'17 challenger rt
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2555364
09/27/18 02:07 AM
09/27/18 02:07 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I don't think a 14X32 will make it with stock frame rails...maybe a 13x31.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2555365
09/27/18 02:08 AM
09/27/18 02:08 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run all stock sheetmetal and rear end dimensions, so I can’t verify. But I would guess with a 32” tire, you’ll likely have to move the axle location rearward an inch or more. The leading edge of the fenderwell is fairly tight on my 28x9’s down low on the rocker where it cuts in front of the tire.
[img:left][/img]
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2555394
09/27/18 04:39 AM
09/27/18 04:39 AM
The 1966 and 1967 dodge and Plymouth B body have a very small wheel well opening, I have a 1966 Dodge Deluxe two door sedan that I stretch the front wheel opening around five inches so I could move the rear end forward to shorten the wheel base up two inches for better traction and get more clearances for taller tires thumbs scope I move the spring into the rear sub frames also thumbs This is a street car, not a all out race car shruggy
I do own a 1967 Satelite hardtop also, both cars have similar wheel well openings whiney
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2555522
09/27/18 01:31 PM
09/27/18 01:31 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Just got my car back in August I had mini tubbed done along with leaf springs moved in with subframe connectors. I tried using 15/10 inch wheels with 4.5 bs it didn't work so a quick call to Moser in went a new D60 now I'm able to fit a 12 inch wide wheel using 29-10.5w tire, keep an eye on the lip on the qtr that rolls inward
P.S with that wheel combo it measures 14.5 across
IMG952018051795161023157.jpgIMG952018051795160959955.jpgIMG952018051795155539105.jpgIMG952018051695185102565.jpg
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: biggest tire on 1967 plymouth belvedere?????? [Re: 67mprfan] #2555633
09/27/18 06:13 PM
09/27/18 06:13 PM
ohio
JMracin Offline OP
JMracin  Offline OP
ohio
Thanks for the info guys. The original sheet metal is long gone in the quarters. It has some junk repro-quarters that were bulged like Jimmy Addisons silver bullet, so iam not worried about cutting here and there.
67mprfan.. how wide was the dana60 you put in? That's the look iam going for.
'17 challenger rt
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2555683
09/27/18 08:44 PM
09/27/18 08:44 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
[quote=JMracin]Thanks for the info guys. The original sheet metal is long gone in the quarters. It has some junk repro-quarters that were bulged like Jimmy Addisons silver bullet, so iam not worried about cutting here and there.
67mprfan.. how wide was the dana60 you put in? That's the look iam going for. [/quote
If I remember correctly it's 54 and some change I would have to measure it for correct width.... I also have the us car tool relocation kit along with Cal tracs on mine..... PS when using their kit double check the strips ensure they are cut straight
Re: biggest tire on 1967 plymouth belvedere?????? [Re: 67mprfan] #2555904
09/28/18 11:20 AM
09/28/18 11:20 AM
Metro Detroit
OUTLAWD Offline
OUTLAWD  Offline
Metro Detroit
I run a 315/60-15 (~30" tall, ~13.5 section IIRC) on a 15x10 7.625 BS. springs relocated, fabricated tubs, patch panels relocated.
For the height you will need to stretch the opening, get creative with patch panel placement, or move the rear back
Some pics posted in this thread:
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2174786/1.html
Faster, Faster until the thrill of speed overcomes the fear of death...
71 Swinger - slowly collecting dust/parts
66 Belv. II - just a streetcar
88 Mustang - turbo LS beater
Re: biggest tire on 1967 plymouth belvedere?????? [Re: 67mprfan] #2555920
09/28/18 11:53 AM
09/28/18 11:53 AM
moparx Offline
moparx  Offline
how much sidewall clearance do you have on the inner rails ? TIA.
beer
Re: biggest tire on 1967 plymouth belvedere?????? [Re: moparx] #2555980
09/28/18 02:02 PM
09/28/18 02:02 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
66-67 bbody are toughest car to get some tire in the rear. small wheelhouse area....restrictive outer quarter panel design,hidden hump high in wheelhouse area,frame rail almost inline with inner wheelhouse... lol you can fit a larger tire in the front than you can in the rear! chop,cut rebuild, narrow housing, frame rails moved in, leaf springs moved in, larger wheel tub, trim outer quarter panel lip, stretch outer quarter panel opening...thats a start...
Re: biggest tire on 1967 plymouth belvedere?????? [Re: Joesixpack] #2556002
09/28/18 02:51 PM
09/28/18 02:51 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
15x8.5 centerline with 4 inch backspace...stock tub and spring location
Re: biggest tire on 1967 plymouth belvedere?????? [Re: Joesixpack] #2556003
09/28/18 02:52 PM
09/28/18 02:52 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
way to tight
Re: biggest tire on 1967 plymouth belvedere?????? [Re: Joesixpack] #2556004
09/28/18 02:55 PM
09/28/18 02:55 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
tough sell
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2556060
09/28/18 05:57 PM
09/28/18 05:57 PM
ohio
JMracin Offline OP
JMracin  Offline OP
ohio
Thanks, I think the narrowed rear and 10.5 is my best bet at this point.
'17 challenger rt
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2556318
09/29/18 04:47 PM
09/29/18 04:47 PM
Puyallup, WA
Puyallup, WA
Mini-tubs with springs into the frame rails and proper backspacing will allow a 28x10.5. The extra ht of a 29.5 looks killer, but again, would likely require more work.
Good luck, post some pics of what you end up with! πŸ‘
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2556506
09/30/18 01:21 AM
09/30/18 01:21 AM
Omaha Nebraska
Brian_wo Offline
Brian_wo  Offline
Omaha Nebraska
Tubs moved to the frame rail,springs moved in and with a 7 1/4” back spacing you can get a 10” wide rim in there but a 9” fits a little better.
Back when I did it the only 10” wide rim with 7 1/4 β€œ backspacing was a centerline.
The current 67 I am working on i am going for a 10” wide rim with only 3 or 4 inches of backspacing and I will narrow the rear to fit.
who is that guy?
Re: biggest tire on 1967 plymouth belvedere?????? [Re: JMracin] #2556564
09/30/18 11:07 AM
09/30/18 11:07 AM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Not mine but thought I'd share it
