Race gas octane #2554533
09/25/18 04:00 PM
09/25/18 04:00 PM
W.Va
fowl play Offline OP
W.Va
Need opinions on octane.13 to one 414 inch small block. Any difference going from 110 Sunoco to 112? Thanks
Re: Race gas octane [Re: fowl play] #2554555
09/25/18 04:22 PM
09/25/18 04:22 PM
NE Ohio
DoubleD Online content
DoubleD  Online Content
NE Ohio
With 110 and 13-1 you are on the edge of the fuel spec - 112 is rated for up to 15-1
Probably will make the same power and you will not notice any difference between the two depending on how conservative you are with your jetting and timing. If you get aggressive with the tune the added octane helps.
I have 13-1 in my HEMI and run VP 112 - the main thing about buying race gas is where you get it from and how pure it is - I buy sealed barrels or cans - I never completely trusted the stuff at some tracks or local gas stations
Re: Race gas octane [Re: fowl play] #2554561
09/25/18 04:30 PM
09/25/18 04:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I ran a 13.1 to 1 W5 headed smallblock for years with 110 with zero issues. 32 degrees timing, 7400-7500 at the stripe.
95% of the time i was pumping the sunoco out of 55 gallon drums i would buy. Known good fuel.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Race gas octane [Re: fowl play] #2554600
09/25/18 05:37 PM
09/25/18 05:37 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
I run Sunoco 112 in mine , buy it by the drum ..
$500 buddy deal
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Race gas octane [Re: fowl play] #2554622
09/25/18 06:10 PM
09/25/18 06:10 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Sunoco was so lousy, I would not try to get away with running it on the edge. Maybe it's different now. Switching to VP made life easier.
Re: Race gas octane [Re: fowl play] #2555266
09/26/18 10:55 PM
09/26/18 10:55 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I've run Sunoco with good results. Its not oxygenated like the VP and requires some attention. I'm experimenting with Klotz additive and 93 pump gas. At 12.5 no problems and it will be cheaper than Sunoco or VP. No bad plug coatings. It lasts indefinitely in the metal can. There may be a few HP with the race gas but I'm just running an index.
Re: Race gas octane [Re: fowl play] #2555278
09/26/18 11:06 PM
09/26/18 11:06 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
For a quarter of the price try it on Avgas, see if it goes slower
1963 Plymouth Max Wedge
1971 Barracuda
Re: Race gas octane [Re: fowl play] #2555341
09/27/18 01:01 AM
09/27/18 01:01 AM
MR_P_BODY Offline
MR_P_BODY  Offline
It will mater more on your cam and where the
center line is.. I was running 14.1:1 on E-85
with no issues at all
wave
Re: Race gas octane [Re: fowl play] #2555399
09/27/18 07:32 AM
09/27/18 07:32 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've been running Renegade fuel for 6 years. Personally we run Pro 114, 15-1. Very consistent. they have 112,113 and more. 114 here is $550 a drum.
Doug
Re: Race gas octane [Re: fowl play] #2555560
09/27/18 02:48 PM
09/27/18 02:48 PM
I was told years ago by several of Ma Mopar factory backed SO CA drag racers to run the lowest octane fuel possible that did not ping or mark up the spark plugs, lean and cold plugs worked the best, fastest, with BB ,Hemi or SB thumbs
Re: Race gas octane [Re: A/MP] #2556630
09/30/18 01:59 PM
09/30/18 01:59 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
http://apkgroup.com/msds/english/MSDS%20by%20Supplier/Winner%27s%20Circle%20(Klotz%20Synthetics)%20(WNC)/KL602(05-08-2017).pdf
Hopefully it has iso-octane (reference fuel of 100 RON/MON) and not n-octane (-17 MON, -20 RON).
https://en.wikipedia.org/wiki/Octane_rating
Floyd Lippencott IV
