transmission fluid #2554853
09/26/18 12:52 AM
09/26/18 12:52 AM
waynesboro va
jonesboys Offline OP
waynesboro va
always used type f whats best ?727 street strip 9.0 converter full man valve body bb engine
Re: transmission fluid [Re: jonesboys] #2554898
09/26/18 04:09 AM
09/26/18 04:09 AM
You chose correctly up
I've always used it since 1974 per directions from the old Mopar drag race seminars put on by the factory Mopar drag race engineers up scope
Re: transmission fluid [Re: Cab_Burge] #2554935
09/26/18 10:32 AM
09/26/18 10:32 AM
an8sec70cuda Offline
iagree Type F in my 8 sec street car w/ a 727.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: transmission fluid [Re: an8sec70cuda] #2554941
09/26/18 10:59 AM
09/26/18 10:59 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Didn’t we have a long post on this subject about a week ago. Lol 😂
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: transmission fluid [Re: jonesboys] #2554955
09/26/18 11:26 AM
09/26/18 11:26 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Yep! and I still run the red stuff!
Re: transmission fluid [Re: J_BODY] #2555058
09/26/18 03:09 PM
09/26/18 03:09 PM
waynesboro va
waynesboro va
thats what i thought type F just wondering if the newer stuff was any better
Re: transmission fluid [Re: pittsburghracer] #2555068
09/26/18 03:36 PM
09/26/18 03:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
And the week before that.
Re: transmission fluid [Re: jonesboys] #2555199
09/26/18 08:54 PM
09/26/18 08:54 PM
A727Tflite Offline
A727Tflite  Offline
Sort of like Prometheus’s punishment.
Re: transmission fluid [Re: jonesboys] #2555225
09/26/18 09:44 PM
09/26/18 09:44 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
ATI!
Re: transmission fluid [Re: pittsburghracer] #2555236
09/26/18 10:05 PM
09/26/18 10:05 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
You never know. Someone may have released a miracle fluid in that weeks time. wink
Still run Type F from wally world per a recommendation here. up
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: transmission fluid [Re: jonesboys] #2557382
10/02/18 01:50 AM
10/02/18 01:50 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
John Deer hydraulic fluid . 7 years now
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: transmission fluid [Re: go green] #2557419
10/02/18 04:17 AM
10/02/18 04:17 AM
Me thinks you make a lot more power than most poster son here, your needs are different, huh whistling grin
Re: transmission fluid [Re: jonesboys] #2557449
10/02/18 09:20 AM
10/02/18 09:20 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I run Type F, but use Redline's synthetic version. I believe ATI's synthetic ATF is also Type F, FWIW.
Street use with the additional heat & slippage from a high stall converter rules out standard (non-synthetic) ATF for me. I also use an accessory trans cooler. But that's my approach and others may not agree.
Re: transmission fluid [Re: BradH] #2557476
10/02/18 10:37 AM
10/02/18 10:37 AM
A lot of street use w/ a 5k stall converter here w/ conventional (non-synthetic) Type F and no issues. Been doing that since 2003 or so.
CHIP
Re: transmission fluid [Re: an8sec70cuda] #2557570
10/02/18 12:00 PM
10/02/18 12:00 PM
BradH Offline
BradH  Offline
Synthetic is a "peace of mind" thing for me. Years ago I recall seeing some tests showing at what temperature conventional ATF started to break down vs synthetic, and that persuaded me that I'd be better off w/ synthetic.
Re: transmission fluid [Re: jonesboys] #2557574
10/02/18 12:03 PM
10/02/18 12:03 PM
BradH...I don't doubt the synthetic is better w/ heat. Just throwing it out there that the normal stuff works fine.
CHIP
Re: transmission fluid [Re: BradH] #2557684
10/02/18 02:41 PM
10/02/18 02:41 PM
PA.
"Little"John
"Little"John
PA.
If I can’t hurt Dextron 3 or type F I think you are fine. A powerglide and transbrake really test how good your fluid is. Zero issues
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: transmission fluid [Re: pittsburghracer] #2557696
10/02/18 02:58 PM
10/02/18 02:58 PM
BradH Offline
BradH  Offline
Is that before or after you drove 100+ miles one way to the track every weekend for a month?
All I'm pointing out is that I don't think we're all looking at it from the same perspective. The OP said a street/strip car w/ a high-stall converter, which fits with my experiences.
As I said above, not everyone is going to take the same approach that I do (and that applies to a LOT of things laugh2 ), so I don't know why people feel the need to reply in a manner that insinuates that I'm "wrong" and they're "right".
People -- obviously -- should run whatever they want. I'm glad others have good results doing different things than I do, since I know how much it can cost to make bad choices that hurt reliability & performance. However, the guy asked for an opinion and I provided mine because his application sounds very similar to mine.
Re: transmission fluid [Re: jonesboys] #2557710
10/02/18 03:22 PM
10/02/18 03:22 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Advice From Rossler's site - I have aked him many times same answer for TF's
Synthetics are Acceptable but Not Required.
900 HP OR LESS - Recommended Fluids
Dexron3/Mercon
Racing Fluid (B & M or TCI)
Ford- Type F
50/50 Mix of Dexron 3/Mercon and Ford – Type F
900 -1,500HP - Recommended Fluids
Ford- Type F
1,500HP and up - Recommended Fluids
Specialty Racing Fluid
Racing Fluid (B&M or TCI)
Hydraulic Oil (10W-20 or 30 Weight)
10-20 or 30 weight synthetic fluid acceptable on all level horsepower the heavier weight fluid the better lubrication to gears and components you must use a slightly higher viscosity fluid to equal lubrication value of conventional non synthetic fluid. The less horsepower you have the lighter viscosity fluid you can use as horsepower increases so should the viscosity of the fluid. Although some turbo powered cars and cars equipped with lock up torque converters need the thinner fluid for spooling and stall speed adjustment purposes. Unfortunately this is a necessary evil that can shorten the life of the transmission planetary gears.
Re: transmission fluid [Re: BradH] #2557714
10/02/18 03:30 PM
10/02/18 03:30 PM
One of the aircraft mags I use to get had a article about synthetic oils that said standard petroleum based oil molicules would start to break down at 325F and that the synthetic based oil molicules, back then, mid 1990s, would start to break down around 525+ F shruggy
I do remember reading about the dye in all automatic trans fluids back in the early to mid 1960 that stated that the dye would start to change colors at 275F and go from red to brown and become black at or above 325f shruggy
