Re: 771 horse stock stroke 360 motor, pump gas
[Re: B3422W5]
#2555171
09/26/18 07:51 PM
09/26/18 07:51 PM
Posts: 12,478 Kalispell Mt.
HotRodDave
Kalispell Mt.
I been saying it for years... a magnum block has more meat where it is needed and is at least harder if not stronger iron as well as more consistant castings. I even posted pictures and nobody seems to care, now I cant post pics anymore so you would have to look back a couple years in my old posts.
[Re: B3422W5]
#2555175
09/26/18 07:59 PM
09/26/18 07:59 PM
Posts: 4,457 Washington
madscientist
Washington
Just talked to Jack..... little more info he doesnt mind me sharing.
Bullet cam. He consulted with Tony at BES regards it. One of Tony’s former guys, John Lohone( sp) now works for Jack and will make the trip down with him. One time Nascar engine builder He said the valves clear with a ton of room. Very well centered in the bore, a big positive for the heads. Said they would clear a stock bore That Holley manifold was indeed only made for W2. He has about 40 hours converting it from oval to square. Tons of work involved there. I had thought they must have offered it in a standard head form at one time, but just W2 Using cyro treated Hughes rockers. Really likes them. Told me he made a plate for the front of the timimg cover where he can pop off the water pump and move cam in not much more than ten minutes. Said the motor is ultra sensitive to cam timing. Currently has it advanced 4 degrees, makes 750 this way but good bit more torque. Couple degrees can make or take 20 horsepower Is likely to move it around down in Charlotte. Said it will break 800 horse spinning it to 8k. Some very trick oiling mods. Had it on Bischoffs dyno recently and Tony told him it had the capability to win the competition. Was very impressed. Yeah, every bit of 40 hours to get a Pro Dominator square. Usually takes some welding too.
[Re: HotRodDave]
#2555179
09/26/18 08:03 PM
09/26/18 08:03 PM
Posts: 11,786 Portage,michigan
B3422W5
Portage,michigan
I been saying it for years... a magnum block has more meat where it is needed and is at least harder if not stronger iron as well as more consistant castings. I even posted pictures and nobody seems to care, now I cant post pics anymore so you would have to look back a couple years in my old posts. Funny you would say that. Jack told me the metallurgy in the magnum blocks is better. Said they are notably harder, and extra meat to use 4 bolt splayed caps
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam, footbrake street/strip car Best so far, 10.32 1/4 1.41 best 60 foot 6.56 at 104.17
[Re: madscientist]
#2555180
09/26/18 08:04 PM
09/26/18 08:04 PM
B3422W5
Portage,michigan
Bullet cam. He consulted with Tony at BES regards it. One of Tony’s former guys, John Lohone( sp) now works for Jack and will make the trip down with him. One time Nascar engine builder He said the valves clear with a ton of room. Very well centered in the bore, a big positive for the heads. Said they would clear a stock bore That Holley manifold was indeed only made for W2. He has about 40 hours converting it from oval to square. Tons of work involved there. I had thought they must have offered it in a standard head form at one time, but just W2 Using cyro treated Hughes rockers. Really likes them. Told me he made a plate for the front of the timimg cover where he can pop off the water pump and move cam in not much more than ten minutes. Said the motor is ultra sensitive to cam timing. Currently has it advanced 4 degrees, makes 750 this way but good bit more torque. Couple degrees can make or take 20 horsepower Is likely to move it around down in Charlotte. Said it will break 800 horse spinning it to 8k. Some very trick oiling mods. Had it on Bischoffs dyno recently and Tony told him it had the capability to win the competition. Was very impressed. Yeah, every bit of 40 hours to get a Pro Dominator square. Usually takes some welding too. Yep, he did lots of welding
[Re: HotRodDave]
#2555182
09/26/18 08:13 PM
09/26/18 08:13 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You can still post pics.. your just doing it wrong.. after you make your post just click on file management then click on browse.. on your computer find your pic.. then add the pic.. then hit add then finish it off like you normally would by hitting submit... very simple but doing it this way I have all my pics on MY computer first
[Re: B3422W5]
#2555193
09/26/18 08:41 PM
09/26/18 08:41 PM
B3422W5
Portage,michigan
[Re: B3422W5]
#2555196
09/26/18 08:42 PM
09/26/18 08:42 PM
B3422W5
Portage,michigan
First picture i have tried, nothing happens when i click on it
[Re: B3422W5]
#2555233
09/26/18 10:00 PM
09/26/18 10:00 PM
HotRodDave
Kalispell Mt.
I cant finger out how to get them from phone to cunfuser and when I try to add em straight from stupid phone its telling me something about 2 terrebytes too big or something
[Re: B3422W5]
#2555290
09/26/18 11:18 PM
09/26/18 11:18 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
Yikes 40 hours on the Pro Dominator, I have one that is converted to EFI and I would love to run some Victors but that is a lot of work it sounds like.
68 Barracuda Formula S 340
[Re: MR_P_BODY]
#2555309
09/26/18 11:50 PM
09/26/18 11:50 PM
Posts: 3,398 cheshire, ct
davesmopars
cheshire, ct
You can still post pics.. your just doing it wrong.. after you make your post just click on file management then click on browse.. on your computer find your pic.. then add the pic.. then hit add then finish it off like you normally would by hitting submit... very simple but doing it this way I have all my pics on MY computer first Pictures do not work for me either. something to do with the new iPhone so I just gave up
Keeper of the 440 M code Cuda registry mcodecuda@yahoo.com
[Re: A/MP]
#2555311
09/26/18 11:53 PM
09/26/18 11:53 PM
Porter67
This really saves on buying an X or R block. People should not confuse themselves into thinking a oem block can even come close to what a X or R is or can take. The main webs, the filled inner pan rails, the thicker decks, cylinder wall thickness. The nickle content. From side by side on a stand compassion to parts attrition on freshen up its all easily spotted. The main reason we see x or r blocks in these times that cant go 4.100 safe is because they are seconds from the days when they were easy to get and were set aside from core shift as culls. I just stopped by the machine shop to check my new 318 build. They are building a stock block 340 that will make 700 + with Pro Charger. Pro Gram 4 bolt main caps and the outer bolts are re-positioned at an angle to pick up more meat in the block. This really saves on buying an X or R block.
[Re: Porter67]
#2555374
09/27/18 02:51 AM
09/27/18 02:51 AM
madscientist
Washington
This really saves on buying an X or R block. People should not confuse themselves into thinking a oem block can even come close to what a X or R is or can take. The main webs, the filled inner pan rails, the thicker decks, cylinder wall thickness. The nickle content. From side by side on a stand compassion to parts attrition on freshen up its all easily spotted. The main reason we see x or r blocks in these times that cant go 4.100 safe is because they are seconds from the days when they were easy to get and were set aside from core shift as culls. Absolutely. There isn't a production block out there, other than a T/A block that should be considered for serious power. The main line will flex like jack the bear so you need to run looser main clearances, the decks are too damn thin for boost (IMHO) and putting 4 bolt caps on ANY production block is a desperate act. In fact, I won't do it. There isn't enough material there, even if you use a 5/16 bolt and it's offset. Isn't worth it as the support isn't there. AFAIK there is ZERO difference in the cast iron used between LA blocks and magnum blocks. They hone the exact same. They are both harder than a Ford and significantly harder than a Chevy, but they ain't an X or an R block and you'd know it as soon as you hone one. Other than lack of availability there is no reason to use a production block in a serious power application unless you just can't get something. I just stopped by the machine shop to check my new 318 build. They are building a stock block 340 that will make 700 + with Pro Charger. Pro Gram 4 bolt main caps and the outer bolts are re-positioned at an angle to pick up more meat in the block. This really saves on buying an X or R block.
[Re: madscientist]
#2555442
09/27/18 10:42 AM
09/27/18 10:42 AM
MR_P_BODY
I've been giving the idea to sleeve all 8 on my TA block... its the last one I have and they are hard to find any of them but it would be a good block then.. the last sleeve I had done was $110 a hole so I would guess its about $1000 to do all 8 now days
[Re: B3422W5]
#2555464
09/27/18 11:26 AM
09/27/18 11:26 AM
Posts: 12,318 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Use studs, add bolts, whatever. When what you are bolting it to is flimsy, the benefit is limited. When the mating surfaces are fretted, the caps are dancing around.
[Re: pittsburghracer]
#2555473
09/27/18 11:40 AM
09/27/18 11:40 AM
Posts: 3,570 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I’m sure all the info isn’t out there on this dyno Queen yet.
My understanding is that the current owners plan for this engine is to race NHRA Super Street. However plans can change. He and his family have lots of experience racing Stock and perhaps Super Stock.
[Re: B3422W5]
#2556282
09/29/18 02:32 PM
09/29/18 02:32 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
Any idea what the valve stems Dia is ?
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
[Re: ric3xrt]
#2556289
09/29/18 02:59 PM
09/29/18 02:59 PM
B3422W5
Portage,michigan
Any idea what the valve stems Dia is ? Hollow stem, but dont know the diameter
[Re: 9secondsatellite]
#2556333
09/29/18 06:04 PM
09/29/18 06:04 PM
B3422W5
Portage,michigan
very impressive for sure but it states 100 octane like one other person stated earlier. i don't know what pump that's from. just saying. my thought would be 93 octane at best if pump gas is the claim. excluding e85. Motor runs on pump swill but the competition fuel is 100 octane
