Re: 1971 E body dash pad options [Re: Morty426] #2556266
09/29/18 01:44 PM
09/29/18 01:44 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Originally Posted By Morty426
Originally Posted By azmopars
We will be at the Fall Fling with all of our E body dash pads including the 70 Challenger. So stop by and check them out. They are new foam and vinyl, not filled in and you can easily see for yourself. These are like our other pads and are made on a heavier vinyl than what is used elsewhere.
Thanks, Bob
Bob - where will you be? Do you have a vendor name?
Chris, Bob is ABCMoparts... if you meet up with him, some feedback on the 70 E body pads would be appreciated by the Moparts collective that can't attend...
Mike
Re: 1971 E body dash pad options [Re: Morty426] #2556633
09/30/18 02:04 PM
09/30/18 02:04 PM
mohave county, AZ
azmopars Offline
azmopars  Offline
mohave county, AZ
ABC Moparts. Since Van Nuys is a relaxed venue I will be in the general swap area. I will have arm rest pads and dash pads out.
Re: 1971 E body dash pad options [Re: flitesweep] #2556786
09/30/18 09:26 PM
09/30/18 09:26 PM
Georgia
69bfan Offline
69bfan  Offline
Georgia
Bob can be found in spaces J105 through 110 at Fall Carlisle for anyone with questions or wanting to look at his various dash pads.
www.restorationpartsandmaterials.com
Correct Mopar weatherstripping is our specialty, but we stock and supply a wide assortment for all of your restoration needs.
www.dalescudashop.com
Correct style exhaust tips and hardware, fresh air seals, go wings, Cuda & Challenger rear window louvers, hood pin kits
Re: 1971 E body dash pad options [Re: flitesweep] #2590611
12/11/18 10:53 PM
12/11/18 10:53 PM
Ohio
1970Swinger Offline
1970Swinger  Offline
Ohio
Matter has been resolved
Re: 1971 E body dash pad options [Re: flitesweep] #2590740
12/12/18 09:13 AM
12/12/18 09:13 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
Do you have pictures you could post of this problem? I was hoping we would finally get an ebody dash worth having.
Re: 1971 E body dash pad options [Re: flitesweep] #2592049
12/14/18 08:46 PM
12/14/18 08:46 PM
Ohio
1970Swinger Offline
1970Swinger  Offline
Ohio
matter has been resolved
Re: 1971 E body dash pad options [Re: flitesweep] #2592216
12/15/18 08:41 AM
12/15/18 08:41 AM
Abilene, Texas
Abilene, Texas
Thanks for the pictures. I assume that is an a body pad?
Re: 1971 E body dash pad options [Re: flitesweep] #2592436
12/15/18 05:56 PM
12/15/18 05:56 PM
Ohio
1970Swinger Offline
1970Swinger  Offline
Ohio
