Electronic Ignition ECU of choice? #2552615
09/20/18 11:43 PM
09/20/18 11:43 PM
Texas
GoodysGotaCuda Offline OP
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My Warlock feels like it's dropping spark above 3,500rpm and surges pretty hard. I'd like to go ahead and get a backup ECU to have on hand and try while I'm looking for the root cause.
Is a parts store version a reasonable choice, or is there a particular vendor to seek out? Not looking for a $200 RevNAtor unless it's going to rock my world.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2552636
09/21/18 12:10 AM
09/21/18 12:10 AM
I would go ahead & get a spare (I think rockauto just had a sale on em) & throw it on there to see if that is it. Not a fan of shotgunning parts at an issue but a spare ECU is always a good plan. Is the current one OE?
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2552639
09/21/18 12:14 AM
09/21/18 12:14 AM
Stevensville, ON
Frank Raso Offline
Frank Raso  Offline
Stevensville, ON
The HEI system is better than the Mopar EI and the Mopar electronic distributor wires directly up to it. I have a GM HEI module from a wreck in my car.
See HEI Ignition Upgrade.
Re: Electronic Ignition ECU of choice? [Re: Frank Raso] #2552647
09/21/18 12:34 AM
09/21/18 12:34 AM
State, country, etc.
gss Offline
gss  Offline
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2552863
09/21/18 02:22 PM
09/21/18 02:22 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
$$$ but I couldn't be happier with my FBO 688 box. Might be overkill for your purposes though.
Re: Electronic Ignition ECU of choice? [Re: BcudaChris] #2553542
09/23/18 10:24 AM
09/23/18 10:24 AM
Wethersfield,CT
Ray440 Offline
Ray440  Offline
Wethersfield,CT
Here are the choices fro Rockauto. Has any tried the Standard Motor LX101? I think my orange box is going bad and was going to give this one a try.
www.rockauto.com/en/catalog/plymouth,1974,roadrunner,5.2l+318cid+v8,1240704,ignition,ignition+control+module+(icm),7172
1969 Plymouth Road Runner 440 auto
2017 Ram 1500 Quad Cab 5.7 Hemi
Re: Electronic Ignition ECU of choice? [Re: Ray440] #2553624
09/23/18 01:55 PM
09/23/18 01:55 PM
Charlotte, NC
Kowal Offline
Kowal  Offline
Charlotte, NC
If you don’t mind paying up...Bouchillon Performance still has some original Mopar units for sale...not off brand.
'69 Hemi Charger 500, ‘70 U code Challenger R/T
(These and a bunch others at www.dkowal426.com)
P.J. O'Rouke: "The old car ran perfectly, right up until it didn't."
Re: Electronic Ignition ECU of choice? [Re: Ray440] #2553626
09/23/18 01:57 PM
09/23/18 01:57 PM
Those are made in china now but I had one & it was fine till I sold the truck. Actually any 4 pinner (& a spare in your glove box) of any brand/type will suffice. The RA link wont open.
Re: Electronic Ignition ECU of choice? [Re: BcudaChris] #2553635
09/23/18 02:13 PM
09/23/18 02:13 PM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
What is this and where can it be bought?
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2553642
09/23/18 02:30 PM
09/23/18 02:30 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Here is the one i have on the road runner. It has dual circuits in case one fails. up
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2553643
09/23/18 02:32 PM
09/23/18 02:32 PM
WA
tman Online content
tman  Online Content
WA
You can get the FBO at Mancini. Right now its 10% off with Promo code #FALL. Today is the last day of the promo code. You can Google that box for info.
Re: Electronic Ignition ECU of choice? [Re: RapidRobert] #2553645
09/23/18 02:36 PM
09/23/18 02:36 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
It does if you cut and paste
Don't be the exception.
Re: Electronic Ignition ECU of choice? [Re: Supercuda] #2553646
09/23/18 02:37 PM
09/23/18 02:37 PM
thanks bro
Re: Electronic Ignition ECU of choice? [Re: Magnumguy] #2554093
09/24/18 02:27 PM
09/24/18 02:27 PM
BcudaChris Offline
BcudaChris  Offline
http://4secondsflat.com/Ignition.html
HRR688 ignition system
Don is also a great resource for all things carbureted fuel system and ignition related (and I'm sure for many other related things). The personal support that comes with his products is great.
Over the phone he's spotted more than one little thing I was overlooking out of frustration and he's got me on track.
If you're running a Mopar distributor, his tuning plate is the bomb too.
Chris
Re: Electronic Ignition ECU of choice? [Re: GoodysGotaCuda] #2554125
09/24/18 04:24 PM
09/24/18 04:24 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
For the cheap driver applications I've recently become a fan of the GM HEI module - Ford TFI coil - Mopar electronic distributor combination after trying it on my 440 C body. Makes a very nice strong spark. It is a $20 module, a $9 coil and it wires right up with parts store spade connectors. It's also easy to hide if desired.
Rich H.
Esse Quam Videri
