Blown Mechanical Injected smallblock ?? #2553876
09/23/18 11:02 PM
09/23/18 11:02 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
What's this thing telling me. In our first attempts to get it started I had something happen that I had never seen before. The injector and blower were frosting up? This combo is a Holley hat injector, 6-71 blower, on a 413ci smallblock running E85. What is it trying to tell me with the top end so cold?? Only ran it for a few moments.
Re: Blown Mechanical Injected smallblock ?? [Re: Blucuda413] #2553893
09/23/18 11:42 PM
09/23/18 11:42 PM
crabman173
crabman173
Call Mike at Alkydiggers in Nashville--best around for injection and the like
Or Spud Miller at FIE in the northwest US Fuel Injection Enterprises--other than that call Good Vibrations in Calif--or Mooneyham or Dyers
Re: Blown Mechanical Injected smallblock ?? [Re: Blucuda413] #2553902
09/24/18 12:03 AM
09/24/18 12:03 AM
Parts unknown
590 Challenger Offline
Parts unknown
When alcohol boils off from a liquid to a gas it has a refrigerant effect. The more you go through to colder it gets, My hat was covered in frost after each pass yesterday
Re: Blown Mechanical Injected smallblock ?? [Re: 590 Challenger] #2553905
09/24/18 12:07 AM
09/24/18 12:07 AM
Kirkland, Washington
Pacnorthcuda Offline
Yep...it's the low pressure (actually NEGATIVE pressure / vacuum) that causes the alky to boil off and freeze stuff up.
It's the exact same effect that causes "carburetor icing" under very specific conditions.
Re: Blown Mechanical Injected smallblock ?? [Re: Pacnorthcuda] #2553920
09/24/18 12:29 AM
09/24/18 12:29 AM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Isn’t this why you always see guys spraying the injectors when the top alcohol guys are running and staging at the track.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Blown Mechanical Injected smallblock ?? [Re: Blucuda413] #2553924
09/24/18 12:51 AM
09/24/18 12:51 AM
Washington
madscientist Offline
Washington
It's normal.
Re: Blown Mechanical Injected smallblock ?? [Re: madscientist] #2553970
09/24/18 08:53 AM
09/24/18 08:53 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By madscientist
It's normal.
Yes it is...lol.
I think you better get some help on your combo and tune up. I am sure it will save lot's of money and time if you have to ask this question. Haven't you ever noticed the injector doors being deiced before a run after the burnout?
Hopefully you bought your fuel system from a reputable dealer that offers lot's of support for newbies. All newbies need lot's of support when they first get started. Otherwise you are destine to spend big bucks getting it figured out...if your good.
Good luck
