Re: 6.1 45* oil filter adapter
[Re: Fishstix]
#2550298
09/15/18 01:41 PM
09/15/18 01:41 PM
Posts: 990 Norwalk, Ohio
sycboi
Norwalk, Ohio
The nipple the oil filter screws onto is just threaded into the block. It does have to come out to install the factory oil filter adapter. Whatever you use to take it out, vise grips or the like, make sure they are in good working order. That threaded nipple is really in there. I used my Knipex Cobra (or Alligator) Pliers to remove it. They have an amazing bite though...
SuperBeast
An enforcer for the Mopar Mafia!
[Re: Fishstix]
#2550336
09/15/18 03:48 PM
09/15/18 03:48 PM
sycboi
Norwalk, Ohio
Actually I have the Knipex Cobra Pliers. The only difference is the adjustment part of them. Either will work though. As far as the rag around the threaded nipple to protect it, good luck with that. Just bite directly into the nipple itself. If you ever need a new one they are available readily for around $10. The one in there is most likely never coming out unscathed...
SuperBeast
[Re: Fishstix]
#2550407
09/15/18 07:43 PM
09/15/18 07:43 PM
sycboi
Norwalk, Ohio
Good vice grips and I was victorious. Excellent man. Progress!
SuperBeast
[Re: Fishstix]
#2552840
09/21/18 01:45 PM
09/21/18 01:45 PM
sycboi
Norwalk, Ohio
5.7 Hemis don’t either, at least none that I’ve ever seen...
SuperBeast
[Re: Fishstix]
#2553157
09/22/18 02:19 AM
09/22/18 02:19 AM
sycboi
Norwalk, Ohio
Both the 5.7’s I removed them from were pre-vvt engines. Maybe that’s the difference...
SuperBeast
[Re: Fishstix]
#2553261
09/22/18 03:23 PM
09/22/18 03:23 PM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
03-08 5.7 have the same pipe as the 6.1's the VVT 5.7s and 6.4s have the New pipe with the hex head.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
