Re: Rear End Strength
[Re: 70charger512]
#2553201
09/22/18 12:14 PM
09/22/18 12:14 PM
Posts: 4,807 Moved to N.E. Tennessee
GomangoCuda
Several people have mentioned That a back brace is a waste of time. Not exactly. It will not help ring and pinion life. It's real purpose on both 8 3/4 and 9" rears is to brace the housing so that it won't tow in and bend. Good power and dead hook can/will bend them.
[Re: 70charger512]
#2553208
09/22/18 12:34 PM
09/22/18 12:34 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Not all 4 speed Gen II Hemi cars used a Dana All GenII Street & Race Hemi cars did (1966-71) seems like they might have learned something after introducing the Hemi in 1964/65 Race hemis.
[Re: 70charger512]
#2553219
09/22/18 01:11 PM
09/22/18 01:11 PM
Posts: 295 Spanaway, Washington State
patosmith
Since everyone loves dana 60’s so much, has anyone bought a complete dana 60 (or 8 3/4 if that option is still open to some) from moser engineering? I have a 72 Challenger with a big block stroked to 505. The car will see the strip a couple of times a year. I bought a Moser dana 60 and I am very happy with it.
[Re: ScottSmith_Harms]
#2553220
09/22/18 01:15 PM
09/22/18 01:15 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Not all 4 speed Gen II Hemi cars used a Dana All GenII Street & Race Hemi cars did (1966-71) seems like they might have learned something after introducing the Hemi in 1964/65 Race hemis. try quoting my whole post, I said what you did before your edit. For the record
All? Hmm wonder what they put in Hemi cars before they started using the Dana?
Wonder why they started using the Dana?
Not all 4 speed Gen II Hemi cars used a Dana.
But the point is, the 8 3/4 was failing in that application nd Chrysler went with the Dana.
[Re: CSK]
#2553234
09/22/18 01:40 PM
09/22/18 01:40 PM
Posts: 15,976 Chilliwack B.C. Canada
RUNCHARGER
You're running a 550HP stick. I don't know why everyone thinks they are smarter than the thousands that have went before them and want to run an 8 3/4 or for that matter a stock 9 inch. Spend a few thousand on your 8 3/4 beefing it up and changing the gear in it. Then when it breaks spend the $2k on a Dana 60 (better off an S60). I just don't get why guys fight this after all these years. What is the love for the 8 3/4?
Sheldon
[Re: RUNCHARGER]
#2553249
09/22/18 02:27 PM
09/22/18 02:27 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
You're running a 550HP stick. I don't know why everyone thinks they are smarter than the thousands that have went before them and want to run an 8 3/4 or for that matter a stock 9 inch. Spend a few thousand on your 8 3/4 beefing it up and changing the gear in it. Then when it breaks spend the $2k on a Dana 60 (better off an S60). I just don't get why guys fight this after all these years. What is the love for the 8 3/4? Most race cars are nickel and dimed together and then the same for performance, if everyone that started out with 400 hp and didn't add a spool or limited slip to there 8 3/4 but jumped into a Dana instead. So if and when more power came along they would be bucks ahead? Looking back that would have worked for me but some guys will run the same combination for thirty years and some are always looking for more. It's usually one motor combination that puts you over the practicality of the 8 3/4. It's never one part, drive shaft, might be time to look for room for more tire, better suspension, it's a never ending spiral of costs. I know only a few racers that dont run on a very limited budget. So its nickel and dimed together and cry when it breaks. As an edit: it has gotten easy to make power over the last twenty years, easy to overpower your chassis combination.
Have a great day Iowan
"obsolete is neat"
[Re: Iowan]
#2553253
09/22/18 02:43 PM
09/22/18 02:43 PM
RUNCHARGER
Yes: I think that's the deal alright. If the OP said he had a 425HP 440 and an automatic I can see adding a good sure grip and set of gears. However he is running 550HP right away and changing to a manual trans. So please save $$$ and go directly to a Dana 60 and a good driveshaft.
Sheldon
[Re: 70charger512]
#2553256
09/22/18 03:00 PM
09/22/18 03:00 PM
Iowan
Lost in Time
He's got to break it a few times before he learns.
"obsolete is neat"
[Re: jcc]
#2553307
09/22/18 06:15 PM
09/22/18 06:15 PM
Posts: 26,522 Rio Linda, CA
John_Kunkel
Rio Linda, CA
It has yet to be proven what exactly could be deflecting with a 8.75. I am not convinced the ring is not also a contributor here. I agree, deflection of both undoubtedly contributes to gear tooth failure and the avalanche that follows. I believe that, under severe stress, the carrier bearing preload disappears and allows the ring gear to be deflected enough to lose the contact patch.
[Re: John_Kunkel]
#2553311
09/22/18 06:24 PM
09/22/18 06:24 PM
Supercuda
About to go away
About to go away
up yours
It has yet to be proven what exactly could be deflecting with a 8.75. I am not convinced the ring is not also a contributor here. I agree, deflection of both undoubtedly contributes to gear tooth failure and the avalanche that follows. I believe that, under severe stress, the carrier bearing preload disappears and allows the ring gear to be deflected enough to lose the contact patch. Does it matter what is deflecting? Once either or both deflect it is all over.
[Re: Supercuda]
#2553335
09/22/18 07:28 PM
09/22/18 07:28 PM
John_Kunkel
Rio Linda, CA
Well, I'm thinking of the "straw that broke the camel's back" analogy, one part deflecting might not be as bad as the combination of two parts deflecting.
As far as being "all over" with any deflection, it's a matter of degree.
[Re: 70charger512]
#2553561
09/23/18 11:33 AM
09/23/18 11:33 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
Since everyone loves dana 60’s so much, has anyone bought a complete dana 60 (or 8 3/4 if that option is still open to some) from moser engineering? Like said before, if the car never hooks you'll likely never break the 8.75. If it hooks at all, it won't last long. Your power w/ a manual trans WILL kill an 8.75...not if, but when. I have a Moser 60 in my cuda that I bought in either 2003 or 2004. No complaints, but if I had to do it over again, I'd get a Strange S60. The only reason is the Strange unit has side adjusters for setting the backlash which is much easier to work with. I have 2 road runners that I used truck Dana 60 rears and cut them down to fit. Work great and a lot cheaper if you don't mind the extra work.
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: GomangoCuda]
#2553562
09/23/18 11:35 AM
09/23/18 11:35 AM
an8sec70cuda
Several people have mentioned That a back brace is a waste of time. Not exactly. It will not help ring and pinion life. It's real purpose on both 8 3/4 and 9" rears is to brace the housing so that it won't tow in and bend. Good power and dead hook can/will bend them. By the time you start bending the 8.75 housing, you've already been breaking ring and pinions. For the money it costs to bandaid an 8.75, you could have built a Dana for it and forgotten about it.
[Re: 70charger512]
#2553658
09/23/18 02:52 PM
09/23/18 02:52 PM
Posts: 8,652 fredericksburg,va
cudaman1969
fredericksburg,va
Since you're going to use a clutch, there is a gizmo out witch is called the door closer. It fits on the clutch rod to slow down engagement just enough to reduce breakage of componites. Wish I had the manufacturs name, but look it up on line. I will use it on my car when done. If you dead hook with an 8-3/4, you'll be picking parts off the ground, stay away from the radials. My 64 (auto) broke all the ring gear teeth off after 10 passes, had ladder bars, spool, strange axels and 14-32 slicks, 842 case. Out it came and Dana back in reusing the axels.
[Re: cudaman1969]
#2553662
09/23/18 03:14 PM
09/23/18 03:14 PM
Posts: 1,894 South Bend
John Brown
South Bend
Clutchtamer?
