Ignorant question about LBA valve body #2552853
09/21/18 02:05 PM
09/21/18 02:05 PM
Val-haul-ass... eventually
BradH Offline OP
BradH  Offline OP
<< Let me (again) preface an auto-trans related question by admitting that I'm an idjit about auto transmissions. >>
When I had a stock 727 w/ a Trans-Go TF-2 modified VB, I started my burnouts in 1st and never upshifted. I'd been told by a previous trans builder that this was the only safe way to do it w/o having a bolt-in sprag, and I never had any issues this way.
Then the trans was updated w/ a bolt-in sprag, among other things. I also switched to a Turbo-Action "Race Only" FMVB without low-band-apply (LBA) per Paul Forte's recommendation.
When I called Paul, I asked initially about the "Street/Strip" FMVB he offers that has LBA, but Paul asked me about how my trans was built, my car's usage, and how I expected to drive it. Since I told him I knew to start my burnouts in 2nd (never 1st) and shift to 3rd once the tires are spinning, he said not having LBA wouldn't be an issue and the car would also be slightly quicker w/o it.
My topic question: Why is LBA is still considered important by some (many?) trans builders with MVBs and never starting out in 1st gear during a burnout?
It sounds like the proper technique negates the need for LBA, but I must not understand all the implications. Thanks - Brad
Re: Ignorant question about LBA valve body [Re: BradH] #2552866
09/21/18 02:29 PM
09/21/18 02:29 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
They recommend the LBA to keep people from hurting themselves.
Re: Ignorant question about LBA valve body [Re: justinp61] #2552869
09/21/18 02:32 PM
09/21/18 02:32 PM
BradH Offline OP
BradH  Offline OP
OK... that's what Paul at T/A inferred when I asked him about why he didn't recommend the LBA FMVB instead after he asked me about my car, etc. whistling
Re: Ignorant question about LBA valve body [Re: BradH] #2552874
09/21/18 02:38 PM
09/21/18 02:38 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
i like the lba for street driving for the 1st gear braking,saves my poor old knee a little work.
Re: Ignorant question about LBA valve body [Re: bonefish] #2552878
09/21/18 02:47 PM
09/21/18 02:47 PM
BradH Offline OP
BradH  Offline OP
I wasn't sure what to expect when I switched valve bodies and no longer had engine braking. Turns out for me it wasn't strange at all, since I normally drive a manual trans car and usually put it in neutral as I approach a stop at low speed. The coasting sensation w/o 1st-gear engine braking feels pretty much the same.
Re: Ignorant question about LBA valve body [Re: BradH] #2552903
09/21/18 03:37 PM
09/21/18 03:37 PM
Minnesota
skep419 Offline
skep419  Offline
Minnesota
copied from another post
To help understand what is needed or not I've tried below to explain the problem of sprag roller clutch failure on a Torqueflite.
Let's see if I can go through this sprag clutch/drum explosion Torqueflite scenario and explain why the drum "may" explode with a sprag clutch failure and what can be done to help prevent this type of failure. This is going to be long and pretty basic for many, but you really should understand how something operates before you can take steps to prevent problems.
First off, a short tutorial on planetary gearsets. Planetary gearsets consist of a central sun gear that is in constant mesh with two or more planetary gears that "orbit" the sun gear and are in turn in constant mesh with and enlosed by an outer ring gear. Various gear ratios and direction changes can be seen by holding one member, driving another and taking the output off the remaining member. No need to go into specifics but the main idea with a planetary gearset is that in order to work one member is held while another is driven. The only exception is if two members are driven then the entire gearset turns as a unit (1:1 ratio).
In a Torqueflite there are two plantary sets mounted together that share a common sun gear. This arrangement is known as a Simpson geartrain and is also common in Ford C4's and C6's and many other automatics. Two planetary sets are required in order to get the required number and ratios needed for use in an automatic. Clutches in automatic transmissions are used to drive OR hold a planetary element while bands and sprag clutches are strictly holding devices. The torqueflite Front Clutch(sometimes refered to as the High/Reverse clutch) is the drive device for the common sun gear. The Rear clutch is the driving member for the front planetary ring gear. The intermediate or kickdown band is the holding device for the common sun gear while the rear band and the sprag clutch share the holding duties for the rear planetary carrier. The output members are the front planetary carrier and the rear planetary ring gear(splined to the output shaft).
Now I could go through the various power flows while in different gears, but for this discussion it is more important to know what clutches, bands and sprag clutches are in play and what happens when a sprag fails. Sprag clutches are basically one way clutches that allow movement in one direction only. The "Sprag" in a torqueflite is not a true sprag but a roller clutch. It works by forcing rollers up on hardened ramps that in turn cinch down on an inner race stopping it's rotating motion in one direction. If the rotating motion on this roller clutch reverses direction, the holding force is immediately released. This is one of the main reasons for it's use in an automatic, the instant release feature when the load is removed makes it simpler to adjust shift firmness as there is no overlap to contend with.
Torqueflite's use a roller clutch that is mounted in the rear of the case. The outer race of this clutch which contains the ramps is splined to the case. Clamped between the case and the outer race is a metal retainer that has small "legs" that are bent upwards betweeen the ramps and the inner race of the clutch. These "legs" are the anchor for the wave springs that serve to push the clutch rollers up the ramps when the inner race tries to turn clockwise and thus clamp the inner race from turning. If there is a counter clockwise motion on the inner race, the rollers push back down the ramp and collapse the wave springs and release the inner race.
One last thing to know is what devices are in play when in various gears. First off a stock transmission.
Shift lever in Drive, Low gear - Rear Clutch and Roller Clutch
Shift lever in Drive, 2nd gear - Rear Clutch and Intermediate band
Shift lever in Drive, 3rd gear - Rear Clutch and Front Clutch
Shift lever in reverse - Front Clutch and Rear Band applied
Shift lever in Low (1) - Rear Clutch and Rear band+roller clutch
With the shift lever in 2, the car will start in low just like it would in the drive position, shift to 2nd and stay in that gear.
For a manual valve body, the difference is all the automatic features have been removed so putting the lever in low, the car starts and remains in low until the shift lever is moved. In second, the car starts in second and stays in second while in third or drive, the unit starts and stays in third. The difference in the Low Band Apply (LBA) valve bodies is that they apply the rear band in low while the non-LBA valve bodies do NOT apply the rear band in low. This is an important difference as you will see shortly. The reason for the non-LBA manual valve bodies is to speed up the one-two shift since there is no overlap to contend with using the roller clutch as a holding device.
Now we have all the basics in place we can continue with what happens that causes a roller clutch failure and ultimately a Front Clutch drum explosion. Anytime there is an excessive shock applied to the roller clutch there is a possibility of the shock load being transmitted to the "legs" that hold the springs in the roller clutch. This shock could be something breaking in the drivetrain, the tires suddenly gripping coming out of the water box etc. The key is the sudden shock load is only a problem when the vehicle is in low gear and utilizing the roller clutch only as the holding device. If you break an axle or shock the trans coming out of the burnout box in second gear, there is little to no chance of damaging the roller clutch. This is why the old-timers will say to always do a burnout with a Torqueflite in second gear and never roll out of the burnout box while letting off the throttle allowing the tires to grab suddenly. Same goes for the LBA valve bodies with low gear burnouts or driveline breakage. Since the rear band is also applied there is less of a chance of damaging the roller clutch because the band is assisting and absorbing some of that shock.
The above explains what not to do, but what happens if you disregard this advice and shock the driveline? Again, the problem is the small tin legs in the roller clutch. The shock load can bend these legs back which reduces the spring pressure on the rollers. Now the rollers are not being pushed up the ramp or can simply flip out of place which in turn allows the inner race to rotate in the direction it would normally be locked. The problem with this is that now the wheels become the holding device and the weels are connected to the output shaft which is spined to the front planet carrier as well as the rear ring gear. If you follow the power flow with the Rear clutch applied and the front planet held and calculate the ratios involved, you will see that this combination results in the Front Clutch drum rotating in reverse at a ratio of over 2 times the input speed. The stock clutch drums in a Torqueflite are made of powdered iron, basically iron filings that have been heated and squeezed into shape. It's a cheap way to make complex shapes but it is not as strong as a billet piece. At some RPM point these powdered iron pieces fly apart with devastating power.
So what do you need to do to minimize the chance of witnessing first hand one of these explosions? If you read and undertood the above, you can see that a simple bolt in sprag/roller clutch will do little to nothing to prevent a roller clutch failure of this type. Rarely is the problem of the outerrace turning in the case a factor in a drum explosion. Not to say that a bolt in roller clutch is not a good thing, just that it will not help with this type of failure. The stock and most aftermarket roller clutches for the 727 utilize 12 rollers and springs. The super sprags from A&A and Coan have 16 elements. These units may offer some relief from this type of sprag failure simply because with the added elements there is less room for the legs to bend back far enough to allow the rollers to slip or fall out of place. The 16 element clutches are probably a good idea not only for this reason but also their added holding power. Next would be to consider a billet aluminum, steel or steel jacketed aluminum front clutch drum that will handle the extreme RPM that a roller clutch failure may transmit to the front drum. A trans blanket or shield is always a good idea and a requirement in some classes. Last of all, heed the advice of the old-timers!! They've run these 727's for years and still have their toes. Knowing how to do a burnout properly and checking the roller clutch after any driveline failure regardless of what parts you have in the transmission only makes good sense.
Lastly, the LBA valve bodies can also help prevent drum explosions because as mentioned they reduce the shock to the sprag. They may not totally eliminate the possibility of a roller clutch failure but even if the roller clutch did fail, the band would hold enough to reduce the overall freewheeling of the rear planet carrier that would in turn reduce the RPM of the front clutch drum.
Hope this helps clairify some of the misconceptions that the TF is a timebomb just waiting to explode.
Re: Ignorant question about LBA valve body [Re: BradH] #2552904
09/21/18 03:38 PM
09/21/18 03:38 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
The issues arise when you have a post-trans driveline failure in first gear. If you can guarantee no failure behind the transmission, or a reason to pedal the car in first gear, then everything is going to be A O K. Now...the question is, can you make those guarantees?
Re: Ignorant question about LBA valve body [Re: TRENDZ] #2552925
09/21/18 04:30 PM
09/21/18 04:30 PM
BradH Offline OP
BradH  Offline OP
Cool, a detailed technical explanation of what's going on inside. I'll make a point of reading this later at my leisure to try and understand it better. Thanks - Brad
Re: Ignorant question about LBA valve body [Re: BradH] #2552928
09/21/18 04:34 PM
09/21/18 04:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Basically, with the lba, if something in the driveline breaks on the launch when you’re still in low..... there’s less of a chance for pieces to exit the trans case.
Re: Ignorant question about LBA valve body [Re: fast68plymouth] #2552932
09/21/18 04:37 PM
09/21/18 04:37 PM
BradH Offline OP
BradH  Offline OP
OK, so there's the Reader's Digest condensed version.
Re: Ignorant question about LBA valve body [Re: BradH] #2552977
09/21/18 06:00 PM
09/21/18 06:00 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
You can have a roller clutch fail due to a driveline failure, and still function well enough to get you to the starting line after repairing the rear, driveshaft or whatever. Then when you shock it, it completely fails and the RPM spike as the engine freewheels. If you are not quick enough getting your foot out of it, at some point the drum speed reaches sufficient RPMs (2.45 or whatever low gear you're using x engine RPM) for the stock drum to disintegrate.
Beyond that, with the power levels being produced by the AH cars and other combinations, the Torqueflites are seeing higher torque loads than ever. I believe in that application LBA is mandatory simply because the capacity of the roller clutch is likely being exceeded. Engine torque is nearly doubled by the converter and then multiplied some more by the planetaries. If someone knows the real torque rating of one, I'd like to know.
Re: Ignorant question about LBA valve body [Re: CMcAllister] #2552991
09/21/18 06:41 PM
09/21/18 06:41 PM
BradH Offline OP
BradH  Offline OP
Part of the upgrades, in addition to the bolt-in sprag and different VB, was replacing the stock drum w/ a billet steel piece.
All I'd planned to due to the trans before putting it back in service was pulling the VB so I can put a restrictor in the passage that affects the 2-3 shift overlap.
Now I'm starting to wonder about switching to a LBA-type VB. Most companies don't promote forward manual VBs for performance applications, but that's what I'd like to stay with. The idea of converting my Slap-Stick to a reverse pattern seems weird since I've always had a standard shift pattern w/ an auto, but I see there's a Shift R Gate plate to do it.
Sh!t... sometimes it's better if I never ask a question in the first place.
Re: Ignorant question about LBA valve body [Re: BradH] #2553008
09/21/18 07:41 PM
09/21/18 07:41 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
mine is a 518, but it is LBA, & standard pattern, Trans go kit that I put in.
not sure if they make a kit for a 727 ?
Re: Ignorant question about LBA valve body [Re: CSK] #2553298
09/22/18 05:39 PM
09/22/18 05:39 PM
BradH Offline OP
BradH  Offline OP
The Trans-Go TF-3 mod kit probably retains LBA, but I don't plan on modifying another OEM unit.
Another question: What is inherently better about a reverse manual vb vs a forward manual?
Re: Ignorant question about LBA valve body [Re: BradH] #2553333
09/22/18 07:23 PM
09/22/18 07:23 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The reverse MVB upshifts away from Neutral and the forward MVB upshifts toward Neutral which invites operator error and hitting Neutral at WOT.
Re: Ignorant question about LBA valve body [Re: John_Kunkel] #2553410
09/22/18 11:20 PM
09/22/18 11:20 PM
BradH Offline OP
BradH  Offline OP
I wasn't thinking about the shift pattern. I found something on the CRT site that says a FMVB can't have high enough line pressure for high HP applications. shruggy
Re: Ignorant question about LBA valve body [Re: BradH] #2553422
09/22/18 11:52 PM
09/22/18 11:52 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Line pressure can be raised or lowered with an adjustment or spring change.
Re: Ignorant question about LBA valve body [Re: BradH] #2553424
09/22/18 11:59 PM
09/22/18 11:59 PM
Liverpool, NY
SILVER67 Offline
SILVER67  Offline
Liverpool, NY
Doesn't T/A sell a fwd full manual that you can street drive and race ?
Re: Ignorant question about LBA valve body [Re: BradH] #2553460
09/23/18 01:51 AM
09/23/18 01:51 AM
MR_P_BODY Offline
MR_P_BODY  Offline
A stock trans has LBA .. what do you want.. I'm
running a 518 without lock up.. it has OD.. its
a 4800 stall.. my 727 RMVB with a trans brake..
no LBA
wave
Re: Ignorant question about LBA valve body [Re: BradH] #2553493
09/23/18 03:41 AM
09/23/18 03:41 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Brad we just took out the no low band apply V/B out and put a low band apply V/B in my sons Dart. It is a reverse manual V/B. I can say the car feels the same on the 1-2 shift as there is no overlap as the low/reverse band seems to release fast enough that the shift feels the same as it did with the no low band apply V/B. Him and I plan to go to the track Oct the 13th as he wants to race it with the new V/B in it. He bought the V/B from A & A as they had about the best price we found and it is working great so far. Ron
