Smallest pit/tow vehicle #2552578
09/20/18 11:03 PM
09/20/18 11:03 PM
On the parachute mount
N
n20mstr Offline OP
n20mstr  Offline OP
N
What's the smallest quad/4 wheeler that will pull a 3000lb car around the pits ? Looking for small because my trailer is at capacity/weight now
....BAD A$$ STREET CAR.....
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552671
09/21/18 01:21 AM
09/21/18 01:21 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
Remember the small 4 wheeler Eddie use to pull the Bird with ?
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552692
09/21/18 03:10 AM
09/21/18 03:10 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Your a regular at the track,,,you see what they are using.Talk to a few to get the pros & cons of each be it a golf cart or quad up
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552731
09/21/18 10:21 AM
09/21/18 10:21 AM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Guy at my track has one of these .. he pulls his car with it
http://www.ricksesv.com/
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552745
09/21/18 10:40 AM
09/21/18 10:40 AM
MR_P_BODY Offline
MR_P_BODY  Offline
How much room is left after you are loaded up..
I have a golf cart and after I'm loaded up with
the GC is in I only have a few inches to play
with and my race car is small.. if I were to
replace the cart I would look at a small quad..
something that has gears so it can pull a car..
my cart will pull about 4000#
wave
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552782
09/21/18 12:04 PM
09/21/18 12:04 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
5.53 @ 125 1/8th on the launch control..more left in her!
Re: Smallest pit/tow vehicle [Re: Eric] #2552812
09/21/18 12:41 PM
09/21/18 12:41 PM
southeast ky
mills.mopar Offline
mills.mopar  Offline
southeast ky
See if the picture works...
I built this a few years ago.. not very practical but it's fun
Jeff
If you love it lube it
68 dart
37 dodge coupe
71 challenger
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552837
09/21/18 01:43 PM
09/21/18 01:43 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I use my golf cart with a push bar & I also have a retractable tow strap on the back for other peoples cars not set up with a chute mount push bar. I also have four wheelers I could use too if needed.
I see more and more people using Smart cars with a push bar & they actually smaller than a golf cart & the people usually get to sit in the staging lanes with the A/C (not a bad idea).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552873
09/21/18 02:38 PM
09/21/18 02:38 PM
N
n20mstr Offline OP
n20mstr  Offline OP
N
I'm concerned with the weight. My trailer is 5200 empty and the car is 2850 . This puts me at 8050, tools, nitrous, etc I'm close to 9,000 loaded. I don't want a pit vehicle that's 800lbs. That Yamaha breeze looks good, as long as it can pull my car. Hopefully they are light, under 500lbs?
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552917
09/21/18 04:24 PM
09/21/18 04:24 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
2004 Yamaha Breeze Automatic 2WD Specifications
Identification
Wheelbase (in/mm) 42.5 / 1079.5
Dry Weight (lbs/kg) 298 / 135.2
Fuel Capacity (gal/l) 1.9 / 7.2
wink
Re: Smallest pit/tow vehicle [Re: n20mstr] #2552919
09/21/18 04:25 PM
09/21/18 04:25 PM
Pittsburgh PA
Eric Offline
Eric  Offline
Pittsburgh PA
I got mine from Bob George and I'm sure it's pulled it's share of B bodies lol
Re: Smallest pit/tow vehicle [Re: Eric] #2553070
09/21/18 10:15 PM
09/21/18 10:15 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
You
Identification
wink
This should alleviate any concerns about pulling power.
http://www.vegascarts.com/V-Twin-Install-Kits-for-Yamaha-G2-G9-G14-G16-G22-s/1867.htm
Kevin
