Re: Corner weights
[Re: DblOJoe]
#2552150
09/20/18 12:06 AM
09/20/18 12:06 AM
Posts: 11,691 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
How light on the RR? How fast? How hard right, guardwall bait or just a little correction?
Unless the car is down in the 8s, that should be close. But, that is just a baseline and the car will tell you what fine tuning it wants. If it's still out of whack, other things, like a dead shock or junk tires, can make it do weird things too.
Re: Corner weights
[Re: DblOJoe]
#2552180
09/20/18 01:11 AM
09/20/18 01:11 AM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
30# is a pretty good change. Should be better if not good. May need another tweak.
