Fuel Sending Unit Recommendations #2550997
09/17/18 12:07 PM
09/17/18 12:07 PM
The Historic Hudson Valley
MONC Offline OP
MONC  Offline OP
Anyone got a recommendation as to where I can get a quality Fuel Sending Unit?
The last one I bought was crap.
Are they all made in China and just distributed to everyone, or are there differences out there?
This is for 70-74 E-body.
THanks
Mopar
Or
No
Car
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551063
09/17/18 02:11 PM
09/17/18 02:11 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Very timely post, I just went through this.
Stay away from OER would be my suggestion. the 3/8" sender I got from them couldn't be inserted as the pickup tube is short and between the float and the sock, the assembly diameter is bigger than the hole in the tank. You have to remove the float and try and get it back in there once the sock and arm are in the tank (easier with the tank out I'd guess). The float also gets hung up on the sock. I tried my best to make it work, but no go. Best I could get was way over full for 20 miles or so, then 1/16 of a tank. I think I got it to work, but then it leaked under the lock ring. Didn't want to waste another Saturday wrench session jacking with it and looked around.
Someone on here recommended the unit from Van's Auto. I second that. The part was cheaper by about $10 and it went right in the hole and dropped right into position. The lock ring design is also superior, as it has a couple of bumps on the humps, if you follow me, that give it a little extra friction and a bit of a lock to lock the lock ring in place. Works perfectly and is calibrated to be at the bottom of the E line on my Barracuda when there is 1.5gal left in the tank.
There's my $0.02
I'm trying to figure out how to get Classic to take the OER sender back.
Last edited by BcudaChris; 09/17/18 02:15 PM. Reason: fix bad grammar and poor sentence construction.
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551070
09/17/18 02:27 PM
09/17/18 02:27 PM
Long Island New York
Mag162 Offline
Mag162  Offline
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551100
09/17/18 03:39 PM
09/17/18 03:39 PM
BcudaChris Offline
BcudaChris  Offline
added this vendor to my list...
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551151
09/17/18 05:31 PM
09/17/18 05:31 PM
MONC Offline OP
MONC  Offline OP
Thanks for the feedback.
I don't see an E body FSU available at Vans on line, nor at tristarradiator .
Mopar
Or
No
Car
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551211
09/17/18 07:14 PM
09/17/18 07:14 PM
WA
tman Offline
tman  Offline
WA
Can always try Dave at Roseville and ask how his units are working out.
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551231
09/17/18 07:56 PM
09/17/18 07:56 PM
DE
Ply72rr Offline
Ply72rr  Offline
DE
https://vansauto.com/product/sending-unit-516-70-74-e-body/
https://vansauto.com/product/sending-unit-38-70-74-e-body/
Re: Fuel Sending Unit Recommendations [Re: BcudaChris] #2551235
09/17/18 08:06 PM
09/17/18 08:06 PM
BcudaChris Offline
BcudaChris  Offline
Always fun to quote myself. I ordered the OER sender in November 17. Classic gave me a store credit right away, no questions and said keep the junk sender.
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551236
09/17/18 08:12 PM
09/17/18 08:12 PM
New Jersey, USA
Y
yella71 Offline
yella71  Offline
Y
New Jersey, USA
If you don't have a good core unit send me a PM
71 challenger convertable, 64 sport fury 383 ci with factory air 99 sebring convertable 89 CTD pup
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551278
09/17/18 09:56 PM
09/17/18 09:56 PM
BDW Online content
BDW  Online Content
Get a good working original,
I have 1 for cheap, switched to a FI tank.
Re: Fuel Sending Unit Recommendations [Re: MONC] #2551697
09/18/18 10:30 PM
09/18/18 10:30 PM
MONC Offline OP
MONC  Offline OP
Thank you Ply72, not sure why l couldn't find it.
Appreciate the offer BDW
Mopar
Or
No
Car
