Engine in 71 Newport? 400?
#2550437
09/15/18 10:02 PM
09/15/18 10:02 PM
Posts: 5,100 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
I have a chance to pick this car up. 71 Newport 2dr H/t that was rolled over light. I think this is a 400 but I'd like someone to verify it. Vin is pictured below. The balancer on the crank is what led me to believe its a 400... Thx all...
...FAFO...
Re: Engine in 71 Newport? 400?
[Re: skicker]
#2550440
09/15/18 10:12 PM
09/15/18 10:12 PM
skicker
"The Champ"
"The Champ"
Western Md.
I'd say it's a 383 then...I don't think its ever been out... The car has a Stromberg 2 bbl carb on it so that makes sense... Since this may be a cast crank 383 will the convertor also need to stay with the crank? Were they internally or externally balanced? I just pulled apart a 66 383 yesterday with an excellent steel crank and no offset weight on the balancer and no weights on the converter. Thx...Dan
...FAFO...
[Re: elmor353]
#2551141
09/17/18 05:12 PM
09/17/18 05:12 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
As far as I know ALL the cast crank engines were externally balanced. Gotta clarify a hair, the only cast crank engine mopar ever made that was NOT externally balanced was the 318, just so someone doesn't misread what you posted is all. Which is also not to say there weren't non-cast cranks motors that got external balance too.
[Re: skicker]
#2551727
09/18/18 11:40 PM
09/18/18 11:40 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
6bblgt makes a very good point....but "at a glance" that looks like a neutral balance harmonic balancer = 383 forged crank for 71. Is it symmetrical with no offset weight on it? And yes, your other crank would work just fine too. It would all work as-is, but I'd still balance it...but I balance everything.
70 Roadrunner convt. street car
440+6, NOS, 4-spd, SS springs
'96 Mustang GT convt. street car
'04 4.6 SOHC, NOS, auto, lowered
"Officer, that button is for short on-ramps"
[Re: skicker]
#2551771
09/19/18 01:07 AM
09/19/18 01:07 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
I too think it is a 383 forged crank. Here is the 400 cast crank balancer. Also the 383 cast crank was with 2-bbl and auto tranny and has the same style balancer as the 400 CC balancer.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: skicker]
#2551830
09/19/18 08:55 AM
09/19/18 08:55 AM
skicker
"The Champ"
"The Champ"
Western Md.
The balancer that's on it looks like the one that Mark posted. It is 2 bbl and auto. It still has the point distributor and starts and runs great with no smoke. Might be worth keeping as a back-up rather than taking it apart...
...FAFO...
[Re: skicker]
#2551930
09/19/18 02:06 PM
09/19/18 02:06 PM
Posts: 954 Chicago
PurpleBeeper
Chicago
OK then, if the balancer looks like Mark's picture, it's a cast crank 383. If it's low miles, then might be a good backup motor (maybe do a valve job). Otherwise, you could put your older forged 383 crank in there as long as you used a neutral balanced harmonic balancer (no weights)
[Re: skicker]
#2552093
09/19/18 10:18 PM
09/19/18 10:18 PM
skicker
"The Champ"
"The Champ"
Western Md.
I already got the car...sold the shell and kept the 383-727 and 8 3/4 center section along with the 11x2 1/2" backing plates and drums. I need to find a set of drum brake front spindles cause if I do I'm keeping the disc brakes also...
...FAFO...
