Engine in 71 Newport? 400? #2550437
09/15/18 10:02 PM
09/15/18 10:02 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I have a chance to pick this car up.
71 Newport 2dr H/t that was rolled over light.
I think this is a 400 but I'd like someone to verify it.
Vin is pictured below.
The balancer on the crank is what led me to believe its a 400...
Thx all...
...FAFO...
Re: Engine in 71 Newport? 400? [Re: skicker] #2550439
09/15/18 10:05 PM
09/15/18 10:05 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
originally that was a 383 2bbl car
late in the '71 model year, cast cranks started showing up in the 383 2bbl
Re: Engine in 71 Newport? 400? [Re: skicker] #2550440
09/15/18 10:12 PM
09/15/18 10:12 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I'd say it's a 383 then...I don't think its ever been out...
The car has a Stromberg 2 bbl carb on it so that makes sense...
Since this may be a cast crank 383 will the convertor also need to stay with the crank?
Were they internally or externally balanced?
I just pulled apart a 66 383 yesterday with an excellent steel crank and no offset weight on the balancer and no weights on the converter.
Thx...Dan
...FAFO...
Re: Engine in 71 Newport? 400? [Re: skicker] #2550778
09/16/18 09:32 PM
09/16/18 09:32 PM
n.e. pa.
65rbdodge Offline
65rbdodge  Offline
n.e. pa.
I pulled a 383/2bbl from a 71 newport a while back it was a steel crank that’s now in to 400 in my dart
Re: Engine in 71 Newport? 400? [Re: skicker] #2551126
09/17/18 04:42 PM
09/17/18 04:42 PM
Keizer, Oregon U.S.A.
E
elmor353 Offline
elmor353  Offline
E
As far as I know ALL the cast crank engines were externally balanced. You will need a weighted torque converter for your application or you could get a B+M flexplate for that engine, then you could use any neutral balance torque converter. I have a cast crank 71 383 and used the B+M flexplate. I now have a neutral balanced high stall converter behind it. It's about $100 from Summit.
Re: Engine in 71 Newport? 400? [Re: elmor353] #2551141
09/17/18 05:12 PM
09/17/18 05:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Gotta clarify a hair, the only cast crank engine mopar ever made that was NOT externally balanced was the 318, just so someone doesn't misread what you posted is all.
Which is also not to say there weren't non-cast cranks motors that got external balance too.
Don't be the exception.
Re: Engine in 71 Newport? 400? [Re: Supercuda] #2551484
09/18/18 01:32 PM
09/18/18 01:32 PM
dogdays Offline
dogdays  Offline
Let's not forget that there were cast crank 273s as well.
As for the 383, the rods and pistons were the same weight so you should be able to use that steel 383 crank with neutral balance converter/flywheel and harmonic damper.
Don't let anyone tell you it needs to be rebalanced. Hundreds of these swaps have been done with success, just bolt and go.
Of course every Mopar engine could use a touchup on the balance but you'll not know the difference. The usual balancing tolerances are much closer than the original Mopar ones. Yet Mopars didn't have a problem with engine vibration back in the day when these engines were being built.
R.
Re: Engine in 71 Newport? 400? [Re: dogdays] #2551581
09/18/18 05:10 PM
09/18/18 05:10 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Most likely the 383 it came with but check it carefully. It COULD have a 230 block 383 like everyone goes gaga for in the 400s of that early era. Yes they do exist and yes I have seen them in the shop.
Todd
Re: Engine in 71 Newport? 400? [Re: skicker] #2551727
09/18/18 11:40 PM
09/18/18 11:40 PM
Chicago
PurpleBeeper Offline
Chicago
6bblgt makes a very good point....but "at a glance" that looks like a neutral balance harmonic balancer = 383 forged crank for 71. Is it symmetrical with no offset weight on it? And yes, your other crank would work just fine too. It would all work as-is, but I'd still balance it...but I balance everything.
70 Roadrunner convt. street car 440+6, NOS, 4-spd, SS springs '96 Mustang GT convt. street car '04 4.6 SOHC, NOS, auto, lowered "Officer, that button is for short on-ramps"
Re: Engine in 71 Newport? 400? [Re: skicker] #2551771
09/19/18 01:07 AM
09/19/18 01:07 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
I too think it is a 383 forged crank. Here is the 400 cast crank balancer.
Also the 383 cast crank was with 2-bbl and auto tranny and has the same style balancer as the 400 CC balancer.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: Engine in 71 Newport? 400? [Re: sasquatch] #2551774
09/19/18 01:14 AM
09/19/18 01:14 AM
moparmarks Offline
moparmarks  Offline
I've never heard of a 383 230 block. Just the 130 and 830 blocks. I have a couple early 400 230 blocks that were cast in 71.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Engine in 71 Newport? 400? [Re: skicker] #2551830
09/19/18 08:55 AM
09/19/18 08:55 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
The balancer that's on it looks like the one that Mark posted.
It is 2 bbl and auto. It still has the point distributor and starts and runs great with no smoke.
Might be worth keeping as a back-up rather than taking it apart... twocents
...FAFO...
Re: Engine in 71 Newport? 400? [Re: skicker] #2551835
09/19/18 09:07 AM
09/19/18 09:07 AM
moparmarks Offline
moparmarks  Offline
I can't see the weight in you pics but if it has it then is a cask crank.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: Engine in 71 Newport? 400? [Re: skicker] #2551930
09/19/18 02:06 PM
09/19/18 02:06 PM
Chicago
Chicago
OK then, if the balancer looks like Mark's picture, it's a cast crank 383. If it's low miles, then might be a good backup motor (maybe do a valve job). Otherwise, you could put your older forged 383 crank in there as long as you used a neutral balanced harmonic balancer (no weights)
Re: Engine in 71 Newport? 400? [Re: PurpleBeeper] #2552061
09/19/18 08:21 PM
09/19/18 08:21 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
Did you end up getting this car? Just wondering. If you part it I need a front subframe. Mine is rusty.
Re: Engine in 71 Newport? 400? [Re: skicker] #2552093
09/19/18 10:18 PM
09/19/18 10:18 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I already got the car...sold the shell and kept the 383-727 and 8 3/4 center section along with the 11x2 1/2" backing plates and drums. I need to find a set of drum brake front spindles cause if I do I'm keeping the disc brakes also...
...FAFO...
