vent windows and frames #2549435
09/12/18 11:44 PM
09/12/18 11:44 PM
Ontario, Canada
GVH Offline OP
GVH  Offline OP
Ontario, Canada
A question was checking inter change in Hollander manual They show the vent windows on 66 B Body interchanging with numerous yr up to 70 . Does that mean the frames are same also or only the vent windows . Thanks
Re: vent windows and frames [Re: GVH] #2549880
09/14/18 09:55 AM
09/14/18 09:55 AM
Mass
charge70 Offline
charge70  Offline
Mass
I believe that the frames are not the same.66/67 have a different part# than 68-70 frames.Also,I checked Tony's Parts.He has the repro vent frames and his application shows 68-70 only.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
