Re: NEED SMALLBLOCK HELP
[Re: oddjob]
#2547916
09/09/18 01:36 PM
09/09/18 01:36 PM
RapidRobert
Vac leak possibly. recent onset? any part/tuning changes preceding this happening?
[Re: oddjob]
#2548087
09/09/18 08:49 PM
09/09/18 08:49 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
I'm using a stock dist. with over 200,ooo miles. This just might be an issue. Any other parts with this condition?
I have mechanical Aptitude. I can screw up anything.
[Re: oddjob]
#2548302
09/10/18 11:29 AM
09/10/18 11:29 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
applying vacuum advance at idle can cause a similar issue with a stock distributor.
[Re: oddjob]
#2549923
09/14/18 12:06 PM
09/14/18 12:06 PM
Posts: 15,487 Florida
scratchnfotraction
may want to check to make sure it did not get 318 intake gaskets on 360 heads/intake ports.
could have internal vac leak.
what mopar intake? spredbore or squarebore or both?
might check 4150 base gasket on intake flange for leaks
