Stock Fuel Pumps #2548571
09/10/18 11:17 PM
09/10/18 11:17 PM
Mid TN
2BblHarold Offline OP
Mid TN
Through 5 years, I've gone through 3 fuel pumps while driving just the occasional lap around the neighborhood. Pretty stockish setup. New tank and sender worked fine for a year, and I'm fairly good about keeping good gas in it. I have not removed the original gas lines but have of course replaced all the rubber lines. I seem to be able to blow my lungs through them OK.
So are today's replacements just junk, especially with ethanol? Are any known to be better quality?
Lucky for me, my no-start situations have occured in the garage, and twice a fresh pump fixed it. I'm holding off on buying pump #3 til I hear back from yous folks.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548574
09/10/18 11:22 PM
09/10/18 11:22 PM
md
mopars4ever Offline
mopars4ever  Offline
md
SB or BB?
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548589
09/11/18 12:04 AM
09/11/18 12:04 AM
Mid TN
Mid TN
Small
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548615
09/11/18 12:56 AM
09/11/18 12:56 AM
I would say a combination of ethanol & general poor quality these days. I don't have a recommendation but if you get a name for one made in the good ole US of A that'd be the way I would go.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548724
09/11/18 12:11 PM
09/11/18 12:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
You could call the Edelbrock tech line and ask if their pump 1720 is alcohol compatible, 1-800-416-8628. Info online doesn't say, though for the Holley pump it does say not compatible, but I suspect they mean 100% not E10.
I have run into this very issue myself with off the shelf stock pumps.
Don't be the exception.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548732
09/11/18 12:38 PM
09/11/18 12:38 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I have been using the Holley small block pump for years with no problems. The diaphragm is super thick. May be too much pressure for stock carb I dunno. I have a holley carb.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548829
09/11/18 03:40 PM
09/11/18 03:40 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We use nothing but Holley pumps.Had 3 bad Carter hi buck pumps bad in a rwo.2 BBs 1 SB.Will admit one lasted a week.Put my 30 year old Holley on and it still worked.The one on my 440 has been on 20 years now.My kids 360 has been on the same.Still work great.Remans depends on the reman company.Used quite a few at work and had no problems.Going thru that many pumps something is wrong.Do they just quit leak etc?Rocky
Chrysler Firepower
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548839
09/11/18 03:50 PM
09/11/18 03:50 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Who remans fuel pumps?
No one.
Where can you get a reman fuel pump?
No where
What are you talking about?
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548919
09/11/18 06:28 PM
09/11/18 06:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Lots of ethanol-friendly pumps out there.
https://www.ebay.com/itm/FUEL-PUMP-DODGE...OL/310817756207
Re: Stock Fuel Pumps [Re: John_Kunkel] #2548944
09/11/18 07:28 PM
09/11/18 07:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Gonna tell us how to fit a B/RB pump onto an LA?
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548955
09/11/18 08:04 PM
09/11/18 08:04 PM
Northern NJ
StukaJU87 Offline
StukaJU87  Offline
Northern NJ
Scott
1969 Super Bee, 383/4 speed
Re: Stock Fuel Pumps [Re: 2BblHarold] #2548976
09/11/18 09:01 PM
09/11/18 09:01 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
A no name fuel pump from some Ebay seller who is so savvy that this is quote from the listing
"Surface Finish: MADE FOR UNLEADED ETHANOL GAS"
I would hope that cast aluminum and sheet metal could handle ethanol.
Try googling the manufacturer and PN and verify it. Good luck.
Just get a DELPHI MF0010 at rockauto, it specifically says "including alcohol fuels and blends" and it's substantially cheaper than some mystery Ebay seller.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2549926
09/14/18 12:13 PM
09/14/18 12:13 PM
Mid TN
Mid TN
Thanks folks! I will look into these options. :0)
Re: Stock Fuel Pumps [Re: 2BblHarold] #2550141
09/14/18 11:34 PM
09/14/18 11:34 PM
BDW Online content
BDW  Online Content
I had similar issue, going through pumps on my 340.
Finally figured out the fuel filter shouldn't be installed before the pump.
After I moved the filter to the factory spot, no more issues.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2550164
09/15/18 12:46 AM
09/15/18 12:46 AM
Mid TN
Mid TN
Summit has a Carter built stock looking unit, about $20, lots of good reviews. If it craps out, then I'll up the $$ to a Holley unit. Really trying to keep things stockish looking tho.
Re: Stock Fuel Pumps [Re: 2BblHarold] #2550230
09/15/18 10:24 AM
09/15/18 10:24 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
The Delphi unit I posted is stock looking, cheaper than the Carter and listed as being ethanol compatible. Not sure why you want to keep rolling dice.
