Re: Another carb CFM question
[Re: LowDeck451]
#2546812
09/06/18 06:07 PM
09/06/18 06:07 PM
Posts: 4,213 New York
polyspheric
New York
For a street-only car, the only serious mistake is making the primaries too big. Factory engines as small as 230" have used QuadraJets.
Boffin Emeritus
[Re: LowDeck451]
#2546935
09/06/18 10:17 PM
09/06/18 10:17 PM
polyspheric
New York
The place where air speed matters is inside the primary booster.
Boffin Emeritus
[Re: lewtot184]
#2546974
09/06/18 11:29 PM
09/06/18 11:29 PM
Thumperdart
State of confusion
Too add to this, a too small of a carb on a hot motor can be real sensitive and a bear to tune sometimes because of the high velocity however I have Dommy's on cars/trucks that the "pros" said would never work for the reasons you mentioned above as in not enuff velocity..........I've had 1250 Dommy's on my dart for street testing with good results and why is that............ i'd say your keeping the rpm up. That's one of the criteria and I have a fairly loose 5200+ vert, 12.1 comp, 4.11 gears, fairly light etc........Like Mr.PBody said, he had a 1050 on a 300 something cubic in. small block BUT super light, good heads and combo plus high rpms. I've learned a couple hard humbling lessons lately about high winding SB Mopars. They love CFM and Shiloh and Tory will attest, they have HUGH carbs that some big blocks cant utilize and they run stellar #'s for their combinations.............Fun stuff, so the whole "theory" CFM calculators don't seem to take these things into account at least the ones some speak about on here........ ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif)
[Re: polyspheric]
#2546975
09/06/18 11:31 PM
09/06/18 11:31 PM
Thumperdart
State of confusion
The place where air speed matters is inside the primary booster. Important for sure and that sets up the rest of the tune...........
[Re: LowDeck451]
#2547276
09/07/18 05:38 PM
09/07/18 05:38 PM
Posts: 570 UK
rb446
UK
Not only do SB mopars like cfm as my stock CR 340 did (850DP+2/10ths over a 750DP).. we had a well known racer with a Mk1 Ford Cortina running a Rover 3500c (215ci buick V8) stick car, lots of rpm etc. He amongst all the other racers kept on about my 850 carb being too big, so I persuaded him to try my 850 straight on his little 215ci motor,.....result.. 2/10ths faster, he couldn't believe it, throttle response wasn't as good as his 600 carb of course but I proved a point to them all back then in 1984.
1969 'Cuda 446ci, best 9.96@133.9 in 1990 1971 340 'Cuda, best 11.01@122.8 in 1987
[Re: rb446]
#2547456
09/08/18 01:39 AM
09/08/18 01:39 AM
Thumperdart
State of confusion
Not only do SB mopars like cfm as my stock CR 340 did (850DP+2/10ths over a 750DP).. we had a well known racer with a Mk1 Ford Cortina running a Rover 3500c (215ci buick V8) stick car, lots of rpm etc. He amongst all the other racers kept on about my 850 carb being too big, so I persuaded him to try my 850 straight on his little 215ci motor,.....result.. 2/10ths faster, he couldn't believe it, throttle response wasn't as good as his 600 carb of course but I proved a point to them all back then in 1984. Yes sir, see it a lot where a "calculated" computer program spits out cfm recommendations but there are too many variables to nail YOUR specific cfm needs........
[Re: crackedback]
#2547664
09/08/18 06:30 PM
09/08/18 06:30 PM
Thumperdart
State of confusion
Yep........And monkey see monkey doer's follow not realizing it....
[Re: LowDeck451]
#2547683
09/08/18 08:37 PM
09/08/18 08:37 PM
polyspheric
New York
"Smallest carb CFM to possibly run"? Definitely not, MUCH smaller works perfectly well.
Boffin Emeritus
[Re: Thumperdart]
#2547689
09/08/18 08:48 PM
09/08/18 08:48 PM
Posts: 12,327 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Why does Holley still say to use a power valve half the idle vacuum and recommend CFM be based on that old equation? Shouldn't both be updated? Or better yet, be eliminated all together. I'm not sure either one was ever accurate. But we sure know better than to use them today. Bring the ![ozbbq ozbbq](/ubbthreads/images/graemlins/custom/OzBBQed.gif) on!
Master, again and still
[Re: DaveRS23]
#2547702
09/08/18 09:40 PM
09/08/18 09:40 PM
Posts: 3,916 usa
lewtot184
usa
Why does Holley still say to use a power valve half the idle vacuum and recommend CFM be based on that old equation? Shouldn't both be updated? Or better yet, be eliminated all together. I'm not sure either one was ever accurate. But we sure know better than to use them today. Bring the ![ozbbq ozbbq](/ubbthreads/images/graemlins/custom/OzBBQed.gif) on! they're trying to make their product idiot proof. dumbing people down seems to be the American way anymore.
[Re: LowDeck451]
#2547753
09/08/18 11:32 PM
09/08/18 11:32 PM
Posts: 2,086 CA
crackedback
CA
You can put a 1bbl carb on a 440 and it will run perfectly well... Won't do much for power, but some have to pick everything apart. 390's ran great on the older Busch series cars. Not as well as if they had a worked 750+ carb on them... but perfectly well. ![stirthepot stirthepot](/ubbthreads/images/graemlins/custom/stirthepot.gif)
[Re: LowDeck451]
#2547894
09/09/18 12:34 PM
09/09/18 12:34 PM
polyspheric
New York
So annoying - someone had the correct answer, and it wasn't you.
Boffin Emeritus
