Will stock valve covers fit on Indy 440-1 heads? #2547614
09/08/18 02:29 PM
09/08/18 02:29 PM
Sask, Can.
72demon416 Offline OP
Sask, Can.
The Indy brochure says they fit on Sr’s but has anybody ever tried them on the 440-1?
If not, where is the problem? the shape of the mating flange or height or ?
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2547674
09/08/18 07:42 PM
09/08/18 07:42 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
I have MoPar Performance valve covers on my -1 heads
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: FastmOp] #2547681
09/08/18 08:30 PM
09/08/18 08:30 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I'm going to use 440source covers on my B1 engine
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2547723
09/08/18 10:31 PM
09/08/18 10:31 PM
Sask, Can.
Sask, Can.
Alright, that answers that. Thanks guys.
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2547744
09/08/18 11:07 PM
09/08/18 11:07 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
-1 and SR have the same vc rail.
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: fast68plymouth] #2547781
09/09/18 12:59 AM
09/09/18 12:59 AM
Sask, Can.
Sask, Can.
Thank you sir!
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2547816
09/09/18 07:40 AM
09/09/18 07:40 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Stock VC's will work.
69 GTX 68 Road Runner
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2547896
09/09/18 12:35 PM
09/09/18 12:35 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Gasket pattern is stock, and for the most part, yes, stock valve covers will work. Depending on valve lift and rocker design, I would be checking clearances for rockers and shaft hold downs. How stock are you talking? OE valve covers or aftermarket replacements? I've had Milodon stamped aluminum valve covers that needed massaging fitting my shaft hold downs and Harland Sharps on 915 heads.
[image][/image]
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2548030
09/09/18 06:50 PM
09/09/18 06:50 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Sometimes you need to space the stock one,but depending on the look you want these fab covers are real cheap,I bought a set of polished fab covers for $130 eek
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: hemi-itis] #2548243
09/10/18 02:35 AM
09/10/18 02:35 AM
Sask, Can.
Sask, Can.
I purchased OEM repro stock covers a few months ago as going back to stock appearing was/kinda is my goal, then I got thinking what if I find a good buy on a set of 440-1’s at a swap meet or something and decide to change my direction- hence the question. Yeah I know, stock appearing and Indy heads don’t go together but I needed a answer to my late night random thought.
Thanks everybody!
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2548246
09/10/18 02:50 AM
09/10/18 02:50 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Depends on how "stock" you want the engine to look.
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: JERICOGTX] #2548247
09/10/18 02:55 AM
09/10/18 02:55 AM
Sask, Can.
Sask, Can.
Yeah, sorta like that. For this car I’ll probably stick a little closer to stock appearing then what I’ve done in the past (like your pic) but I will likely try hide some heads. Are those, ez’s, sr’s, 440-1’s?
Looks good no matter what!!
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2548251
09/10/18 04:01 AM
09/10/18 04:01 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
They are SR heads.
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: JERICOGTX] #2548295
09/10/18 11:08 AM
09/10/18 11:08 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Now that is cool! I like how you even painted the meziere water pump to blend w the rest. Sneaky and I like it!
2 kids and a dog
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2548342
09/10/18 12:56 PM
09/10/18 12:56 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Bondo up the Indy logo and paint it all. These are Indy covers. Though this is to racey you can get the idea.
Doug
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: dvw] #2548353
09/10/18 01:13 PM
09/10/18 01:13 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Doug
Who's thermostat swivel upper radiator hose fitting is that? I like it
Re: Will stock valve covers fit on Indy 440-1 heads? [Re: 72demon416] #2548359
09/10/18 01:22 PM
09/10/18 01:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Cheapy from Summit. It was the cheapest one I could find. As I Remember it was around $30. 6 years no leaks.
Doug
