470 build #2546895
09/06/18 08:48 PM
09/06/18 08:48 PM
Ste-Sophie, Quebec, Canada
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
After another fatal break with my 408, I decided to move into
BB territory ! yesss
Decided to go with a 470 ci from a 400 block, and I can't find to much
infos on that combo such as dyno test or best intake or whatever specific
on that combo....so I don't really know what kind of numbers I should expect...
Why do I see few datas on this one ?
Here is a quick overview of my parts so far:
400 block
440 forged crank, main turned down to 400 specs and 2.2 rod journals
offset grinded to 3.9 stroke
6.700 chevy rods with 2.2 journals
Fully ported Eddy RPM's 84 cc chambers
14 cc dome pistons for a cr of 12.6:1
HS rockers
no cam yet
no tq converter
no carb
Where am I going with that ? what cam would you pick ?
Trow me some ideas...
Dan
67 Barracuda......no engine...loll
Re: 470 build [Re: Wedgeman] #2546898
09/06/18 08:53 PM
09/06/18 08:53 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Mine is a 470
unported Victors , made 620 hp
car runs 10.50's in 90 degree heat
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 470 build [Re: Wedgeman] #2546956
09/06/18 10:56 PM
09/06/18 10:56 PM
AndyF Offline
AndyF  Offline
Search for 470 and you'll find dozens of threads on this board.
Re: 470 build [Re: Wedgeman] #2546977
09/06/18 11:33 PM
09/06/18 11:33 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
AndyF literally wrote the book on the 451. Not much difference there. Might try searching some of his past posts.
Re: 470 build [Re: AndyF] #2546979
09/06/18 11:35 PM
09/06/18 11:35 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
Guess I should have read throught the entire thread before posting.
Re: 470 build [Re: Wedgeman] #2547001
09/07/18 12:29 AM
09/07/18 12:29 AM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Here's one I had a few years ago:
400/470, 10.7-1 comp, ported Indy SR standard port window, victor intake, 950 quick fuel, Straightline Perf solid flat tappet 255@.050/.575 lift. Went 11.0 at 122 in street car over 40000lb with 4200 converter, 4.10 gear, and 275/60 drag radials.
2 kids and a dog
Re: 470 build [Re: mgoblue9798] #2547039
09/07/18 01:58 AM
09/07/18 01:58 AM
AndyF Offline
AndyF  Offline
I've written 8 magazine articles on 470 engines in the last year. You can find most of them on the Hot Rod website or on my website:
http://arengineering.com/tech/
Re: 470 build [Re: TonyS451] #2547048
09/07/18 03:00 AM
09/07/18 03:00 AM
Dearborn Hts, MI
Sledge_57 Offline
Sledge_57  Offline
Dearborn Hts, MI
I know the wagon was chubby Tony but had no idea it weighed 40,000 lbs LOL
Loved that car btw, Mine was similar to Tonys but less compression, worse heads and not tuned well (didn't weigh 20 tons either laugh )
It ran 11.67 (died of indigestion, swallowed the air cleaner stud)
Doug
1967 "Pedal Car" 500" low deck , TF 727, 4.30 Locker
Best to Date: 11.67 @ 114.9 1.64 60ft
"Kids in cars cause accidents. Accidents in cars cause kids..."
Re: 470 build [Re: Wedgeman] #2547122
09/07/18 11:43 AM
09/07/18 11:43 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
As mentioned already above, there are plenty of 470 posts on here, if you spend some time using the Search function.
You don't provide any specifics for performance goals, intended usage (street/strip or track-only), and limitations/constraints. That's going to make it difficult for people to give suggestions for parts combinations.
Try providing more of the missing info and that should help get more applicable input. twocents
Re: 470 build [Re: Sledge_57] #2547210
09/07/18 02:27 PM
09/07/18 02:27 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
Hey Doug, thanks! I knew I shouldn't post without my reading glasses. I wasn't aware your 67 ate a carb stud, Ive been away for a while. Got it up and running again? Always been a fan of the 67 B bodies, glad you still have it.
2 kids and a dog
Re: 470 build [Re: BradH] #2547236
09/07/18 03:33 PM
09/07/18 03:33 PM
ohio
67mprfan Offline
67mprfan  Offline
ohio
Not a post highjack but too give him and me some direction mine is a 67 Plymouth B going to use it for street/strip My car already has D60 4:30 gears and Cal tracs will be running around a 29/10.5 tire with either 10-12 wide rims
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it.
67 Belvedere that worked it's way in the 10's
Re: 470 build [Re: Wedgeman] #2547266
09/07/18 04:59 PM
09/07/18 04:59 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
400 block, offset ground steel 413 crank to 3.90 stroke, home ported e-brocks, 12.1.1 comp, victor intake w/adapter, .680-.660 276-281 Isky solid roller, 1200 Dommy, 727 with a 5200+ 4.11's and a 29" tires......3050 lbs and so far 6.15 @ 112 so far and it's tired.......... beer
Re: 470 build [Re: Wedgeman] #2547272
09/07/18 05:19 PM
09/07/18 05:19 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Don't drive around too much, mainly for fun at the track the week-end..
Trying to go as fast as I can... D60 4.56 gear 30in tires,
3000 lbs with driver.......foot brake
Dan
Re: 470 build [Re: Wedgeman] #2547317
09/07/18 07:09 PM
09/07/18 07:09 PM
Dan
Focus on making the motor make peak HP above 7000 RPM, intake(single plane with a 4500 flange), custom built 4500 type dominator carb. and 8 inch race converter up
Your parts should support and make close to 700 HP at or near 7000 RPM with the correct cam, carb. and intake up
Re: 470 build [Re: Wedgeman] #2547319
09/07/18 07:13 PM
09/07/18 07:13 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Using the 6.700 rods with a 3.9 stroke....do I need to notch the cylinder for rod clearance ?
Re: 470 build [Re: Wedgeman] #2547329
09/07/18 07:29 PM
09/07/18 07:29 PM
You shouldn't shruggy
But make sure to check everything everywhere, especially around the oil pick up boss scope
You know who Murphy loves to pick on, correct whistling scope
I don't worry about rod side clearances any more unless they are less than .012 or tighter on steel rods, .020 or les on aluminum rods twocents scope
Re: 470 build [Re: Wedgeman] #2547357
09/07/18 08:27 PM
09/07/18 08:27 PM
W
Wedgeman Offline OP
Wedgeman  Offline OP
W
Yeah....and some folks told me not to worry either about rod to rod clearance being too big ! even at .060 !?
Re: 470 build [Re: Wedgeman] #2547475
09/08/18 03:03 AM
09/08/18 03:03 AM
My first 400 block stroker build had a set of CAT brand H beam steel BB Chevy 6.800 long rods, the side clearances ranged from right at .054 down to .032 shock
I was warned by every keyboard engine guy on here back in 2001 or so, not the real engine builders on here tsk , about how it wouldn't work and it would cause a massive loss of oil pressure according to what they had read, they where wrong haha
The rod bearing to crankshaft clearances have a lot more to do with oil pressure loss than the rod side clearances due shruggy
I've been drag racing and building Mopar V8 since 1964, I've only seen one stock engine that had any where near the maximum side clearances, max of .016. it was a early built 1966 426 Street Hemi motor that had between .012 and .016 rod side clearances work
All the rest of the stock production passenger car motors had over .024 and a lot more all the way up to .036 work
Re: 470 build [Re: Wedgeman] #2547499
09/08/18 08:53 AM
09/08/18 08:53 AM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Rod side clearance is more just for proper rod location without it moving too much side to side, not for maintaining oil pressure. Depending on what rods are used, clearance to block might be something to look at. Rods with through bolts and nuts create more interference than rods with cap bolts. But using the smaller BBC pin will help keep the overall rod width a lot narrower.
Re: 470 build [Re: Wedgeman] #2547536
09/08/18 11:39 AM
09/08/18 11:39 AM
The Great White North
RAMM Online happy
RAMM  Online Happy
Yep, built more than a few of these and rod side clearance is never an issue--like I told you at least twice, maybe three times.
I was going to suggest you call me as we have been in contact via email before, but all you do is ask the same questions over and over to as many people as will listen--until you get the answers you want to hear. There are plenty of good engine builders in Quebec, please look them up. You could take your heads to one shop and then the crank to another, then maybe order the pistons off E-bay, grab the used rods from Kijiji, and so on and so forth. Projects managed like this ALWAYS turn out awesome.
p.s. Maybe look up Nick Panaritis @ Indy Auto, he's a true Mopar guy with a dyno and a Youtube channel. Maybe if you have him build it , you will be on one of his videos. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
