Distributor adapter to run 440 dist in 400 block? #2545352
09/03/18 09:28 PM
09/03/18 09:28 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Can't seem to find these anywhere anymore.Anybody have a source
Thanks,
George
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2545363
09/03/18 09:52 PM
09/03/18 09:52 PM
Andrewh Offline
Andrewh  Offline
http://www.cuda-challenger.com/cc/index.php?topic=83336.0
they don't make them anymore, but here are the plans.
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2545364
09/03/18 09:53 PM
09/03/18 09:53 PM
You can cut down the shaft. this will let you set the shaft tang/intergear slot interface dead on (no rotational slop) for no spark scatter when setting the initial at idle.
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2545435
09/03/18 11:43 PM
09/03/18 11:43 PM
Bowling Green, KY
cudaboy Offline
cudaboy  Offline
Bowling Green, KY
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2545830
09/04/18 08:44 PM
09/04/18 08:44 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Thanks guys!
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2546403
09/05/18 09:39 PM
09/05/18 09:39 PM
Central NC
gch Offline OP
gch  Offline OP
Central NC
Thanks for the offers and info.Had a friend bugging me to death for one.Turns out it is for a MSD distributor so I told him to buy one from Mancini for the MSD distributor.
Thanks again.
Re: Distributor adapter to run 440 dist in 400 block? [Re: gch] #2547845
09/09/18 10:56 AM
09/09/18 10:56 AM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
I had the same problem. I contacted MSD and bought the replacement shaft and just changed it. It's pretty easy to do.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
