Re: Wiped cam...how to tell
[Re: Moparmaniacc]
#2544097
09/01/18 01:34 AM
09/01/18 01:34 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
First off, wheres the leak? MA Mopar never installed additional gaskets with the valley pan, why should you? On your cam lobes, just look at each one , if it looks like it's been ground on then the cam is junk along with the lifter. Timing chain stretch, they all stretch some.Unless you have 50,000 miles on it, it should be OK You need a degree wheel and the cam specs to tell how the cam is installed .
[Re: Moparmaniacc]
#2544099
09/01/18 01:37 AM
09/01/18 01:37 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
The FSM, which you should have at hand, has the spec for timing chain stretch and how to check.
As for the cam being dialed in, there are probably 10000 write ups on the internet detailing how to do it with video, audio, text and probably even in crayon. Find one.
[Re: Moparmaniacc]
#2544102
09/01/18 01:44 AM
09/01/18 01:44 AM
Posts: 43,112 Bend,OR USA
Cab_Burge
Three different answers, #1 look at the lobes, especially the top of them for wear , pitting, rounded off and see if the bottom of the lifters look okay. DO NOT mixed or switch the lifters from lobe to lobe #2 On checking the chain stretch with the valley pan off take a wrench or socket on the big crankshaft bolt and rock the crank back and forth and watch the camshaft, if it moves right away your good, if not you have chain stretch #3 The only way I know of on checking the cam timing and cam lobe separation angle is to check it yourself BTW., a retarded cam will suck power big time on BB and most all and any other Mopar V8 As far as using the fibre intake gaskets on your motor is their oil sucked into the intake ports from the lifter valley? If not you don't need the gaskets If so use them , one on each side at a time to see if you need one or not I always put and use them on the head surface first under the valley pan and then, if needed, on top of the valley pan If you put to thick of gaskets and valley pan the intake manifolds bolts won't go in or go in really hard Good luck Let us know your results please
[Re: Moparmaniacc]
#2544125
09/01/18 03:17 AM
09/01/18 03:17 AM
RapidRobert
But what i really want to know if is, if the poower is way down, how can I tell if my cam is wiped? Aside from a visual & what the guys said, more info please, power always down/all of a sudden? what speed pieces on the eng. tune up good? WOT or daily driver power down? If you can fit the thin .015 side gaskets (one on either side of the valley pan on each side (4) total) I would use em.
[Re: Moparmaniacc]
#2544203
09/01/18 12:02 PM
09/01/18 12:02 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Like Robert said , if the gaskets fit use them
I let the engine build , heads , aftermarket intake dictate the use of gaskets
No , they didn't install gaskets from the factory , but everything was also brand new , everything
Compression test also will give you good information
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
