Re: 340/6 radiator way too small for 440?
[Re: 70B5Cuda]
#2544493
09/02/18 02:53 AM
09/02/18 02:53 AM
Posts: 1,066 Newton, KS
70B5Cuda
Newton, KS
I've been ridiculously busy lately but this week I made some progress. I pulled the water pump housing and the part number is 3698468, which came on 73-78 Mopar big blocks. I was kind of hoping that it had an after market housing that was the culprit but that doesn't seem to be the case. The big ports were clear/clean.
I pulled the heads and the head gaskets are in good shape with no signs of leaks. My 906 heads are pretty much junk. Most valves seats are sunken; the valves are all cut at different lengths, and I have a couple guides that are working themselves out. The heads "smell hot". I know that's unscientific but you know what I mean. I drained the oil for the first time. The oil only has about 20 miles on it but I wanted to see what was in the oil. It was surprisingly clean but smelled rich.
1970 Barracuda B5 6.1 Hemi/6 speed 1969 Charger survivor in R6 383/727-wrecked 12/24/18 1968 Charger in original burgundy paint "Ribeye" 1968 Charger w/ 6.1L, TR-6060, 9" 1968 Roadrunner w/ 6.1L/6 speed 2011 Dodge Ram w/ 6.7L
[Re: 70B5Cuda]
#2544607
09/02/18 01:24 PM
09/02/18 01:24 PM
Posts: 1,285 Pacific NW USA
CompSyn
Pacific NW USA
How about the water pump? Can you describe the type/condition of the water pump?
[Re: CompSyn]
#2544624
09/02/18 01:39 PM
09/02/18 01:39 PM
70B5Cuda
Newton, KS
How about the water pump? Can you describe the type/condition of the water pump? It's a brand new pump but its a cheap cast parts store unit.
[Re: 70B5Cuda]
#2546698
09/06/18 02:22 PM
09/06/18 02:22 PM
Posts: 425 Eastern Ontario
shaker340
Eastern Ontario
Latest for me was radiator flush and new temp sender and seeing 200 for a 25 to 30 degree improvement. A lot of crud came out of radiator during the flush.
I tested the temp sender/gage to a cooking thermometer in boiling water to confirm gage accuracy.
Mike
2008 Challenger SRT8 1940 Chrysler Royal coupe
