1971 Charger Road Wheel Part # #2542034
08/27/18 03:04 PM
08/27/18 03:04 PM
Ct, Hartford
birdfan70 Offline OP
Ct, Hartford
Hoping to clear up some confusion I am having concerning the correct part # for my car. I have a 71 Charger that originally came with road wheels. The build sheet has the code 79 in it but when I look up 71 14x6 road wheel part #s nothing ends in 79. I always thought the build sheet ended with the part #. Thanks in advance.
Re: 1971 Charger Road Wheel Part # [Re: birdfan70] #2542072
08/27/18 04:28 PM
08/27/18 04:28 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
79 is correct for the 14x6.0" ROAD wheels for 1971 b-bodies with the G70-14s
the broadcast sheet number is for the "assembly" - I've never seen a chart that shows the actual wheel assembly numbers
GG lists the 14x6.0" ROAD wheel as #3461359
Re: 1971 Charger Road Wheel Part # [Re: birdfan70] #2542099
08/27/18 05:43 PM
08/27/18 05:43 PM
Ct, Hartford
Ct, Hartford
Thanks, what is throwing me off is I have another 71 that has factory 15 rallyes. The broadcast sheet for wheel is (90) and the part # on the rim is 390, also the spare is a 15 spare (50) part # 450. Even the trim rings match up, just not this #. Hope this makes sense.
