Re: Timing light for Multiple Spark systems????
[Re: Challenger 1]
#2543341
08/30/18 07:47 AM
08/30/18 07:47 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
I bought a Flaming River self powered light from speedway. I didnt see the red ferret style until I searched again today.
Im sure the flaming river will get the job done. I might buy a Ferret later on.
A flaming river timing light is like using a bic lighter to see your timing marks especially during the day outside like at the races. Amen brother, bought one of these POS's from Summit...junk...wasn't bright enough to see the timing marks on either the GTX or Dakota, both were in the shop. Poorly made, cheap (over priced) junk...took it back same day.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: Challenger 1]
#2543426
08/30/18 01:48 PM
08/30/18 01:48 PM
Posts: 610 long time lurker, short time p...
PorkyPig
A flaming river timing light is like using a bic lighter to see your timing marks especially during the day outside like at the races. I bought a Flaming River light because everyone at the time was saying that was the way to go. Pray for cloudy weather when you need to use it in daytime. I still have an old Craftsman dialback but never bothered to check if they show different readings.
[Re: 71birdJ68]
#2543526
08/30/18 05:40 PM
08/30/18 05:40 PM
Posts: 11,611 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I just bought a like new Ferret model 84 and the instructions are extremely vague, anybody know how this thing works? Well, looking at a picture looks like use the mode button to set it up for 4 stroke. Use UP and DOWN to adjust the number of degrees from zero. I.E. if you want to set timing at 38*, plug 38 into the back of the light and the timing marks should line up a TDC when the timing is at 38. Set to zero to use as a regular light to set with the marks.
[Re: Moparnut426]
#2543839
08/31/18 01:14 PM
08/31/18 01:14 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
The problem with the dial back lights is....... they can read inaccurately....... and you don’t know it.
I’ve had a couple of customers torch pistons as a result. Verified faulty light operation after the fact by comparing their dial back light vs a non-dial back light. One of them was off about 17-18deg at high rpms. Showed 38 deg at 6000rpm....... was really 55deg with a non-dial back light....... hence the burnt pistons.
I have one of the cheap red Actron non-dial back lights Jegs used to sell for $39. I had a nice old chrome Craftsman non-dial back light I bought in like 1980 that disappeared one day, and the Actron is what I got to replace it.
[Re: Moparnut426]
#2543876
08/31/18 02:33 PM
08/31/18 02:33 PM
fast68plymouth
So. Burlington, Vt.
The test I did was with the dial back at zero. That doesn’t remove the dial back electronics from the circuit.
The first time I ran into this was with my old school Snap On dial back light on a motor with a crank trigger. Revving the motor would just show the timing gradually retard as the rpm went up. And not like one or two degrees either......... like 10-15.
I knew nothing was physically moving since it was a crank trigger, so it had to be either in the electronics or the light. This was the first time I had ever seen anything that made me suspect the light was reading incorrectly.
I called MSD, they said........ try another light without a dial back. I said, but I’ve never had an issue with this one....... they said, yeh.... but try another light. Tried a non-dial back light...... and the timing didn’t move at all.
That led me to trying both lights on several other motors at the dyno, and I never could get it to repeat what it did on the motor with the crank trigger........ but from then on, I knew I couldn’t be “sure” the dial back light was reading correctly....... so I stopped using it on the dyno.
It was a couple years later when I did the test with the light from the guys with the melted pistons.
[Re: Moparnut426]
#2543966
08/31/18 07:30 PM
08/31/18 07:30 PM
Posts: 16,491 On the run…
BloFish
On the run…
So the only modern day option is flaming river, so long as it isn’t daylight when you need to use it. There are two Ferret Industries on eBay, are they not the correct units?
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: Moparnut426]
#2543974
08/31/18 07:56 PM
08/31/18 07:56 PM
fast68plymouth
So. Burlington, Vt.
I see the Actron non-dial back light CP7527 is still available from several vendors.
Probably not as nice as a Ferret, but it’s another option.
[Re: fast68plymouth]
#2544416
09/01/18 10:09 PM
09/01/18 10:09 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I still use a digital Snap-On unit and I checked it against the Flaming River unit and they were both dead on the same marks. I used to use an old dial back Snap-On and I always trusted it but it quit and they don't repair them anymore. So I traded up to the Digital push button back around 18 years ago and it still works perfect. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#2544485
09/02/18 01:22 AM
09/02/18 01:22 AM
Posts: 993 Addison,IL
OUTLAWSSAA
Addison,IL
I still use a digital Snap-On unit and I checked it against the Flaming River unit and they were both dead on the same marks. I used to use an old dial back Snap-On and I always trusted it but it quit and they don't repair them anymore. So I traded up to the Digital push button back around 18 years ago and it still works perfect. Gus I have that same Snap On light that I can not use with my MSD ignition. Timing mark is all over the place. Bought the cheapo Flaming River and the problem was gone.
[Re: Moparnut426]
#2552698
09/21/18 04:05 AM
09/21/18 04:05 AM
Posts: 339 Gilroy,CA.
mopardude318
Gilroy,CA.
ive been lookin for one as well. I think if I can get the MSD 8991 or 8992 from jegs might be okay.
here's a ferret 86 on ebay but don't know if this is the right one.
https://www.ebay.com/itm/FERRET-86-DIGITAL-TIMING-LIGHT-TACH-ADV-DWELL-VOLTS-TIMING-LIGHT-MADFE-IN-USA/282743245127?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D1%26asc%3D20131231084308%26meid%3Dab290307e0e9428d9d4060183ee729e3%26pid%3D100010%26rk%3D3%26rkt%3D4%26sd%3D323389559167%26itm%3D282743245127&_trksid=p2047675.c100010.m2109
408 Stroker 533 HP 520 FT LBS...........................1970 Dart RMS AlterKation
