Page 1 of 3 1 2 3
For anyone who thinks that TIG wedling steel is difficult #2541704
08/26/18 06:53 PM
08/26/18 06:53 PM
Charlotte, North Carolina
sgcuda Offline OP
sgcuda  Offline OP
Tried using my new welder today on aluminum. If you have a problem welding steel, try welding aluminum. It's like I never welded before in my life. LOL! But all it takes is practice.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541708
08/26/18 07:01 PM
08/26/18 07:01 PM
Washington
madscientist Offline
Washington
You are using A/C and 100% helium aren't you?
I stopped using Argon.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541721
08/26/18 07:18 PM
08/26/18 07:18 PM
sgcuda Offline OP
sgcuda  Offline OP
A/C and 100% Argon
[image][/image]
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541725
08/26/18 07:20 PM
08/26/18 07:20 PM
sgcuda Offline OP
sgcuda  Offline OP
I'm welding on 110 volts. It has a 220 volt adapter but I didn't get my garage rewired yet. Welding at 120 amps. Pulse turned off.
[image][/image]
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541743
08/26/18 08:30 PM
08/26/18 08:30 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Go here and watch some of his videos, I think you'll see the benefit of using pulse on aluminum. Your fine with argon.
http://www.weldingtipsandtricks.com
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541746
08/26/18 08:41 PM
08/26/18 08:41 PM
sgcuda Offline OP
sgcuda  Offline OP
Yeah. I subscribe to Jodi's site. Just haven't been on in a while.
[image][/image]
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541759
08/26/18 09:33 PM
08/26/18 09:33 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
With aluminum clean means EVERYTHING!!!!!!
1970 Duster
Edelbrock headed 408
6.143@110.85 mph
9.73@135.05 mph shifting at 6700 RPM
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541761
08/26/18 09:34 PM
08/26/18 09:34 PM
Minnesota, USA
humpty Offline
humpty  Offline
Minnesota, USA
Looks like you got it figured out pretty good by the last practice pass on be right! I just got an AC tig myself and hope to start burning some aluminum soon. And Jody’s site rocks!
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541766
08/26/18 09:39 PM
08/26/18 09:39 PM
Fulton County, PA
CMcAllister Offline
CMcAllister  Offline
Fulton County, PA
110? Might be tough on stuff thicker than sheet metal Aluminum takes some heat.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541785
08/26/18 10:14 PM
08/26/18 10:14 PM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Do Yourself a favor and get a MIG Welder with at least 250 in the Model # (scales with the thickness in mils (.001") for material) along with amps available from welder and get a spool gun to go with it. TIG welding aluminum is difficult and doesn't get any easier once You learn how. What do You want to fabricate?
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541802
08/26/18 10:36 PM
08/26/18 10:36 PM
sgcuda Offline OP
sgcuda  Offline OP
I want to build up the normal stuff. Intakes, gas tanks, linkage, stuff like that. I'm planning on getting a 220 outlet put in soon.
[image][/image]
Re: For anyone who thinks that TIG wedling steel is difficult [Re: Dduster] #2541812
08/26/18 11:02 PM
08/26/18 11:02 PM
Trumussia
jcc Online content
No politics
jcc  Online Content
No politics
Trumussia
I completely disagree. If you want to weld fast, with limited welding skills, with little regard for weld integrity or cosmetics, mig is the ticket.
If you have patience ( why women often have great tig skills), are willing to practice, and be rather anal on cleanliness ( solvent cleaning, ss sire brush right before welding, brush the tig rod, very clean gloves, etc) Tig is the ticket.
A comment was made earlier about 100% helium, that would not be a good suggestion, I often use a 80/20 Argon/Helium mix as it has better heat for thicker alum items. I use a 625A Miller Syncrowave Tig, my mig machine is used 98%? for steel.
Cover all your exposed skin, skin cancer is a [censored].
OP, I see worthy progress, be careful about grading your own welds until have broken a few.
"Perfection is the enemy of Excellence" German Engineer
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541819
08/26/18 11:15 PM
08/26/18 11:15 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
Ya won't be doing that with a mig ... stick with your tig and practice, practice, practice. Pulse is your friend. Some of the inverter machines have a "clean" function for doing aluminum, this works like a charm - doesn't mean YOU don't have to clean the stuff first, it just makes it that much better.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: jcc] #2541827
08/26/18 11:26 PM
08/26/18 11:26 PM
Washington
Washington
For welding aluminum helium makes more heat at the weld. I even use now for steel. I wouldn't go back.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541882
08/27/18 06:50 AM
08/27/18 06:50 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Helium is way too expensive to be wasting on welding anything other than heavy aluminum parts. Any ferrous metal you can weld almost any thickness with maybe 150-175 amps, it's going to be multiple passes no matter how much power you have.
I like a 50/50 Ar/He mix for heads, blocks and intakes. Straight He just seems to have crappy arc behavior.
MIG is for production, it's just a different process, no need for condescension. MIG takes plenty of skill to do it properly, a**clowns with a MIG gun have caused more "parts failure" than we'll ever know.
60+% of welding success is prep work. The most valuable welder's tool is probably his grinder. S/F....Ken M
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541884
08/27/18 07:19 AM
08/27/18 07:19 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
If you used a stainless wire brush before that last weld on the right you would look like an expert
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541890
08/27/18 07:58 AM
08/27/18 07:58 AM
sgcuda Offline OP
sgcuda  Offline OP
I have been brushing with a SS brush, but it was a Harbor Freight piece in the $1 bin, so quality might be questionable. It seems that there are a lot of personal choices on gas. I'm guessing that a lot of it has to do with technique. I have been using straight Argon, but also have a Ar/CO2 mix that I've been using for my Mig. Maybe I'll try using that.
I immediately noticed that welding steel is a very quiet, gentle process. Aluminum, I'm guessing it has to do with using A/C, is very noisy and seems to be a pretty angry burn. At least it's my perception. I think I'm backing out of the pedal to make it feel like welding steel, but what I am really doing is killing the heat and losing the puddle. I need to learn how to "Stay into the gas pedal". Lol!
And another thing I noticed, aluminum might dissipate heat faster, but it sure does transfer the heat to the rest of the material faster. I can feel it pretty well through the gloves.
[image][/image]
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541893
08/27/18 08:47 AM
08/27/18 08:47 AM
MR_P_BODY Online content
MR_P_BODY  Online Content
As soon as the material turns shiney its ready
to lay the rod into it.. all I use on alum is
100% argon.. I've been doing alum for a long
time.. I enjoy doing alum.. yes a good SS brush
helps alot
EDIT
Also lean the tip of the torch to the heavier/thicker
material that will give you a better jump(jump is
the point where the second material or filler rod
joins as one.. at that time the heat is much more
consistent
Also on your tungsten.. dont grind it to a point
loke you do on the MIG.. use a piece of bronze and
flip the machine to reverse then hold the tip
vertical and hit the pedal for a moment.. this will
give your tip a nice round point(the current will run
around in a circle which heats much nicer and that
will make for a easier jump for the rod)
wave
Re: For anyone who thinks that TIG wedling steel is difficult [Re: sgcuda] #2541908
08/27/18 09:31 AM
08/27/18 09:31 AM
Washington
Washington
Are you shaping the tungsten into a ball for the aluminum? A/C will always make more noise.
I forget how much more I'm paying for helium but it want enough to bother me.
Re: For anyone who thinks that TIG wedling steel is difficult [Re: madscientist] #2541913
08/27/18 09:45 AM
08/27/18 09:45 AM
Yes.. you will feel the transfer into your gloves
pretty quick.. I use a couple of different materials
to keep that low.. either a block of wood or a brick
from a catalyst(the brick has very low transfer) they
were easy for me to get in the exhaust lab)
wave
Page 1 of 3 1 2 3
Taller Spindles- but small caliper brackets
by hulmule. 02/19/20 11:30 AM
FEB 22 - Winter Classic Swap Meet. Who's going?
by sixpackjeff. 02/19/20 11:28 AM
What oil to use
by dragon. 02/19/20 10:53 AM
67 R/T Needs a bit of work
by 65pacecar. 02/19/20 10:09 AM
Moparts Recent Posts
Daytona 500
by jcc. 02/19/20 12:22 PM
Unsafe site warnings on Moparts
by Doc Fiberglass. 02/19/20 12:19 PM
Any good paint and body men out there?
by topside. 02/19/20 12:18 PM
Buying a used race car
by Doc Fiberglass. 02/19/20 12:14 PM
