doubling up valve cover gaskets #254168
03/15/09 11:04 AM
03/15/09 11:04 AM
Plano, Texas
Dallasdart Offline OP
Plano, Texas
Does anyone do this? I have a 360 with eddy heads and eddy valve covers and the covers hit the RPM intake at the runners. Either I grind the intake or double up the gaskets. any input would help
72 Dart Swinger 360 Project
Re: doubling up valve cover gaskets [Re: Dallasdart] #254169
03/15/09 11:49 AM
03/15/09 11:49 AM
Plano, Texas
Plano, Texas
bump...I'm trying to fire this baby up today.
Re: doubling up valve cover gaskets [Re: Dallasdart] #254170
03/15/09 12:05 PM
03/15/09 12:05 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
grid the lip off the valve covers
Re: doubling up valve cover gaskets [Re: Dallasdart] #254171
03/15/09 12:20 PM
03/15/09 12:20 PM
Yes I'd(carefully) glue 2 together & give it a shot. If it doesn't leak you're up & running today.
Re: doubling up valve cover gaskets [Re: RapidRobert] #254172
03/15/09 12:26 PM
03/15/09 12:26 PM
tx
craigsmytcudas Offline
tx
Yeah what he said , glue the gaskets togeather and valve cover let sit with weight on the cover for a few mins then install .c
Re: doubling up valve cover gaskets [Re: 05dakota] #254173
03/15/09 12:28 PM
03/15/09 12:28 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Yep, just in the areas where the intake runner sits...
Re: doubling up valve cover gaskets [Re: 1_WILD_RT] #254174
03/15/09 08:48 PM
03/15/09 08:48 PM
SW MO
closer9 Offline
closer9  Offline
SW MO
I put MP aluminum covers on my 318 with a Performer intake. I just ground the areas that rubbed with a Dremel, and all is well... You can't even tell once it's all assembled. I personally wouldn't double the gaskets, but if it works...
Daily:
'19 Frontier 4WD
Belle:
'67 Belvedere Convertible, 318/727 in Go ManGo!
Other:
'64 C10, 283/3 on the tree
Re: doubling up valve cover gaskets [Re: closer9] #254175
03/15/09 09:40 PM
03/15/09 09:40 PM
Niagara, Ontario Canada
mrpatel Offline
mrpatel  Offline
I did on my motor for rocker arm clearance. Glued them together with yellow aka "gorilia snot" or weather striping adhesive. Works fine with no leaks.
Re: doubling up valve cover gaskets [Re: Dallasdart] #254176
03/16/09 04:36 AM
03/16/09 04:36 AM
Martinez, California
Challenged Offline
Challenged  Offline
I have eddy heads on my 340 with a sixpack. The shop that built my motor had to use 2 gaskets (cork) so the valve cover would clear the intake. Also they put studs in the heads instead of using bolts. Sounds like an inherent problem with eddy heads.
