Big block oil pan fitment on a 73 Charger #2540785
08/24/18 09:28 AM
08/24/18 09:28 AM
North Carolina, USA
Silverbullet2 Offline OP
North Carolina, USA
A friend of mine is having problems clearing the front of the K member on his 73 Charger with aftermarket oil pans. He's tried 2. The last one the sump clears but the front hits before the motor reaches the mounts. Looks like 440 source, milodon, etc list the same pan for 66 up. Is there a specific pan for the later rubber mounted K member? Thanks!
Re: Big block oil pan fitment on a 73 Charger [Re: Silverbullet2] #2540867
08/24/18 01:35 PM
08/24/18 01:35 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
I believe you might need the small lesser quantity type pan, factory pan wise. The sump area is too far forward on 402 pan etc. A friend went through this. I have an F body and have a 187 type pan and it is close to K.
Re: Big block oil pan fitment on a 73 Charger [Re: Silverbullet2] #2540876
08/24/18 02:05 PM
08/24/18 02:05 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
73 up pan is shaped differently in the front , listing showing 66 up being the same is not correct.
What pan is he trying to use ?
He needs the 971 pan..
http://www.engine-swaps.com/Pages/ProductsType/OilPanSchematics.html
Re: Big block oil pan fitment on a 73 Charger [Re: Silverbullet2] #2540889
08/24/18 02:21 PM
08/24/18 02:21 PM
Guitar Jones Offline
Funny, I put a 7 quart Milodon on my 73 Charger without issue.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Big block oil pan fitment on a 73 Charger [Re: Silverbullet2] #2540981
08/24/18 06:05 PM
08/24/18 06:05 PM
North Carolina, USA
North Carolina, USA
It's a 512 in a 400 block, and a aftermarket 7qt pan. It probably needs more than the 4 qt factory pan.
Re: Big block oil pan fitment on a 73 Charger [Re: Silverbullet2] #2543113
08/29/18 04:42 PM
08/29/18 04:42 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
You never said that , how about a picture of where it's hitting , may just need a small tweak with a hammer to get it in ...
But then there is the issue with all that pan hanging out in space unprotected .... panic
