Re: Drag Week 2018
[Re: JERICOGTX]
#2543742
08/31/18 09:19 AM
08/31/18 09:19 AM
Posts: 10,095 MN
JERICOGTX
MN
Going to be a fun trip Jay! If all goes well, I'll get to see 4 new Drag Strips, and a few new states I've never been to.
69 GTX
68 Road Runner
Re: Drag Week 2018
[Re: JERICOGTX]
#2543911
08/31/18 04:31 PM
08/31/18 04:31 PM
Posts: 7,526 Minnesota
Hemi_Joel
Minnesota
Yup, after more than 5 years since i Started the project, I finally made it to the track. Thanks to Kevin and Jeff for all the help! I made 3 passes, none of them were full clean runs. There are issues to work out, but nothing really bad. I couldn't get the T56 Magnum to shift clean under power, their is a mystery oil leak to find and fix, and the Nut behind the wheel needs dialing in. But I'm satisfied. Nothing blew up, I didn't crash, and I have a to-do list.
I am going to remove some counterweight from the clutch and see if that helps it shift.
I was trying to use my GoPro as a data logger, filming all the gauges. For some reason, it didn't record the Innovate MTX-l a/f gauges well. It just showed a lot of flashing. Maybe the shutter speed of the camera aligns with the digital gauge in a bad way?
There sure is lot's of work yet to do before drag week, I need to get busy.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Drag Week 2018
[Re: JERICOGTX]
#2543969
08/31/18 07:41 PM
08/31/18 07:41 PM
Posts: 14,539 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Old coupe, old hemi, clutch pedal......... drag week.
You are a brave man!! 😎
Re: Drag Week 2018
[Re: fast68plymouth]
#2543975
08/31/18 07:56 PM
08/31/18 07:56 PM
Posts: 20,273 PA.
pittsburghracer
"Little"John
"Little"John
PA.
You are a brave man!! 😎 I’m betting Walmart won’t stock a lot of emergency spares for that one.
1970 Duster Edelbrock headed 408 5.984@112.52 422 Indy headed small block 5.982@112.56 mph 9.38@138.67
Re: Drag Week 2018
[Re: JERICOGTX]
#2543982
08/31/18 08:18 PM
08/31/18 08:18 PM
Hemi_Joel
Minnesota
There's a fine line between bravery and pure foolishness. I'm not yet sure which side of that line this absurdity sits on.
Re: Drag Week 2018
[Re: Hemi_Joel]
#2543983
08/31/18 08:26 PM
08/31/18 08:26 PM
Posts: 6,621 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
There sure is lot's of work yet to do before drag week, I need to get busy. I have an antique by today's standards LC1 that could data log to a laptop serial port.(told you it was antique) Does yours have USB or Bluetooth capability to interface with a phone, tablet or laptop? I think their datalogging software was called Logworks. Kevin
Re: Drag Week 2018
[Re: Hemi_Joel]
#2543984
08/31/18 08:31 PM
08/31/18 08:31 PM
fast68plymouth
So. Burlington, Vt.
There's a fine line between bravery and pure foolishness. I'm not yet sure which side of that line this absurdity sits on. I think you’ll know which side you’re on with that thing in the next couple weeks. Either way, I’m looking forward to watching it go down the track on the live feeds.
Re: Drag Week 2018
[Re: JERICOGTX]
#2543985
08/31/18 08:44 PM
08/31/18 08:44 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I think its crazy, but crazy and drag week go together just fine!
I still don't have a transmission in my car. I am hoping that is remedied tomorrow, and if not we will probably take the one from my Dad's car and put it in mine.
68 Barracuda Formula S 340
Re: Drag Week 2018
[Re: Twostick]
#2543989
08/31/18 08:52 PM
08/31/18 08:52 PM
Hemi_Joel
Minnesota
Kevin
I phoned Innovate to get the data logging capability of the MTX-l A/f ratio meter clarified. It comes with a serial cable that will connect it to a computer, but it will not store data. So it has to be connected to the computer while making the pass. I didn't like that idea, so I bought their #3875 pocket logger that will store and playback the A/F data without having to use a computer.
Re: Drag Week 2018
[Re: Hemi_Joel]
#2544073
09/01/18 12:41 AM
09/01/18 12:41 AM
Posts: 2,265 IL
furious70
IL
Kevin
I phoned Innovate to get the data logging capability of the MTX-l A/f ratio meter clarified. It comes with a serial cable that will connect it to a computer, but it will not store data. So it has to be connected to the computer while making the pass. I didn't like that idea, so I bought their #3875 pocket logger that will store and playback the A/F data without having to use a computer. In my Coronet I have their analog gauge so that I could at a glance know I was ok. It's really hard to get a good ground for it and the logger though so it read off a half step or so. For a visual that's ok, just lined a mark up to it so I could be sure I was at or on the right side of 'no holes in pistons'
70 Sport Fury 68 Charger 69 Coronet 72 RR
Re: Drag Week 2018
[Re: JERICOGTX]
#2544465
09/02/18 12:05 AM
09/02/18 12:05 AM
Hemi_Joel
Minnesota
Squirrel, I HOPE you can bring your Hemi! I tested again today, at an 1/8 mile track. The ET's were nothing to write home about, but it got back into the trailer under its own power after 5 passes, so that's a good thing.
Re: Drag Week 2018
[Re: JERICOGTX]
#2544471
09/02/18 12:25 AM
09/02/18 12:25 AM
Bad340fish
Tulsa OK
I can't wait to see the coupe run Joel, or the Almost Funny Car Jim.
I got a trans in today and fit the new hood.
Re: Drag Week 2018
[Re: JERICOGTX]
#2545455
09/04/18 12:34 AM
09/04/18 12:34 AM
Posts: 2,265 IL
furious70
IL
perfect christening in the rain!
