71 b-body vs ebody
#2539523
08/21/18 12:17 PM
08/21/18 12:17 PM
Posts: 573 Spencer, Indiana
LastChanceGarage
Spencer, Indiana
Are the amd firewalls for a ebody close to the same on a 71-b-body ? Wanting to delete the ac and change to a standard heater only firewall. Are the top cowl the same?
1969 GTX 1971 super bee 1972 Duster 1973 Charger Rallye 400 auto 1995 Dakota Sport 5.2 auto
Re: 71 b-body vs ebody
[Re: moparmarks]
#2539575
08/21/18 02:00 PM
08/21/18 02:00 PM
LastChanceGarage
Spencer, Indiana
Will the amd non ac firewall they list for a ebody work on a bbody?
[Re: LastChanceGarage]
#2539583
08/21/18 02:20 PM
08/21/18 02:20 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Will the amd non ac firewall they list for a ebody work on a bbody? IIRC Goodmark has a non AC 71 B body lower firewall... Sherman carries an AC 71 B body firewall, not sure if they have a non AC...check them out, why bother with the E body wall?
[Re: DAYCLONA]
#2539588
08/21/18 02:25 PM
08/21/18 02:25 PM
LastChanceGarage
Spencer, Indiana
Was looking on AMD’s website and they listed nothing for the 71 bbody firewall, I’ll check Sherman out, really only need the right side Thanks
#2539594
08/21/18 02:32 PM
08/21/18 02:32 PM
Posts: 12,493 Western Colorado High Desert
moparmarks
No one makes the 71-4 B body firewalls. They market E body a/c walls and they are the same as 71-3 B body but they haven't done the research to know this. I have. 74 B is different. For a 71-3 B non a/c wall, used is the only option.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: moparmarks]
#2539607
08/21/18 02:55 PM
08/21/18 02:55 PM
LastChanceGarage
Spencer, Indiana
I might have a patch piece for non a/c. I'll check. Thank you, looking for a heater box too of course but mainly wanting to get the sheet metal work done on the car.
[Re: moparmarks]
#2539795
08/21/18 10:40 PM
08/21/18 10:40 PM
340clone
No one makes the 71-4 B body firewalls. They market E body a/c walls and they are the same as 71-3 B body but they haven't done the research to know this. I have. 74 B is different. For a 71-3 B non a/c wall, used is the only option. Interesting. What is different about the '74?
#2539802
08/21/18 10:53 PM
08/21/18 10:53 PM
Posts: 7,979 Scranton, PA
Montclaire
Scranton, PA
Pretty sure the shape of the mounting plate on the column is different - 73 same plate as 71-72 but uses the thick biscuit, 74 uses a different plate and a thin biscuit. Is 74 b-body the same all the way to 79?
