Re: Transmission removal without a lift
[Re: gzig5]
#2538396
08/19/18 01:42 AM
08/19/18 01:42 AM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
I used to be able to do it on the floor,but when the age catches up the mind says yes,,,and the body says NO.That being said I used the floor jack till I bought the M/C jack.Either way I had to tilt the tail up to clear the bellhousing to get it out fromunder and twist the trans to clear the headers.Just need to be carfull with the trans getting on & off the jack you're using.
[Re: gzig5]
#2538444
08/19/18 07:32 AM
08/19/18 07:32 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Looks like the same craftsman motorcycle jack I use....I paid $89 for it
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
