air claener pie tin measurement ? #2534535
08/11/18 12:34 PM
08/11/18 12:34 PM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
I have a 1972 motor home 440 air cleaner, it looks like the top space where a pie tin would go is 10 inches. over the years where there different measurements.
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: air claener pie tin measurement ? [Re: sparcy] #2534573
08/11/18 01:50 PM
08/11/18 01:50 PM
Conway, SC
T2R9 Offline
T2R9  Offline
Conway, SC
I just measured one. 10' center to center on the bevel. 10-3/8" outside lip to lip. I think they are all the same.
Should drop right in if you can find one.
Re: air claener pie tin measurement ? [Re: T2R9] #2537075
08/16/18 10:55 AM
08/16/18 10:55 AM
dracut mass usa
sparcy Offline OP
sparcy  Offline OP
dracut mass usa
Thank you that's the measurement I need. the research I have done they all look the same. I took 2 6 cly air cleaner bottoms cut the air snorkles off and put them on the 440 air cleaner made my own Dual air filter. My friend I got it off, it was the grand parents motor home. A 1979 he pulled the engine and trans for a project never used it. IT has a 727 trans with a short tail bolt on yoke. The Motor home, had 33k on it. The air cleaner has a INFO sticker on it with year 1972.
Cleanmedia
FWD bad strut bushing .... jsta replace ... ???
by Doc Fiberglass. 10/13/19 10:48 PM
Roll cage mounted switches
by cdwmotorsports. 10/13/19 09:08 PM
One day you are fine and the next you are final.
by MidPenMopar. 10/13/19 08:27 PM
Moparts Recent Posts
CA PSPS Power Outage
by pittsburghracer. 10/14/19 01:10 AM
1968 PLYMOUTH ROADRUNNER 4 SPEED SHOWROOM
by RTSrunner. 10/14/19 12:14 AM
