Hotwireauto harness #2536897
08/15/18 09:02 PM
08/15/18 09:02 PM
Canada
WO23Coronet Offline OP
Canada
The Hotwireauto harness/computer they sell is for the 03-08 Hemis (seems they like to use 06 LX car parts). Can they be used on the 5.7 Eagles/6.4’s? I know you’d have to use early 5.7/6.1 sensors so I guess my question is can those sensors be used on Eagle/Apache engines? You’d have to lock out the cam and switch the crank sensor (4 bolt 6.1 would work), am I missing anything? I’m picking up a ‘90 club cab short box that I want to transplant a Gen III into mad would like to use the Nag1 transmission as well (possibly)
Re: Hotwireauto harness [Re: WO23Coronet] #2538608
08/19/18 05:52 PM
08/19/18 05:52 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
I have a Hotwire harness on my 2014 Eagle. The only thing I had to change was the crank sensor to a 2010 version. I kept the VVT but no MDS.
"It's funny how one project eventually leads (or forces) you into another one.
It's really just one endless project designed to induce insanity and bankruptcy."
Re: Hotwireauto harness [Re: kpzbee] #2538681
08/19/18 09:03 PM
08/19/18 09:03 PM
Canada
Canada
Really! From their website it reads like it’s only pre eagle. What trans do you have? Is it programmable?
Re: Hotwireauto harness [Re: WO23Coronet] #2559994
10/06/18 06:21 PM
10/06/18 06:21 PM
Wooster, Ohio
K
kpzbee Offline
kpzbee  Offline
K
Wooster, Ohio
They have it available with 545 and the Nag. Unfortunately I had to use a 4L60e to fit under my tunnel and it's on a standalone controller. My ecm is a 09-10 Charger/Chally stick shift so it's standalone as well.
