Page 2 of 3 1 2 3
Re: Need help tuning dominator for the street [Re: an8sec70cuda] #2536704
08/15/18 12:44 PM
08/15/18 12:44 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Most anyone can build a carb that runs good wide open. It takes a carb builder that really knows what hes doing to make the carb do everything correctly. I have bought carbs from a bunch of different venders and Dom beats them all hands down no contest. Guy really knows his [censored] and wont BS you like the others i have dealt with. Davinci told me no one could build a 3 circuit for street like he could. Biggest piece of [censored] catb ever. Dom fixed it.
Re: Need help tuning dominator for the street [Re: Canam800] #2536705
08/15/18 12:45 PM
08/15/18 12:45 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Ok I'm going to get a 6.5 power valve and drop the front jets. Should I still drop the intermediate jets? If so are they the same as Holley main jets? I haven't taken the bowl off yet so I'm not sure what kind of jet it is. After I get through the weekend I will probly just send it out to Thumper.
Thanks Brandon
Re: Need help tuning dominator for the street [Re: polyspheric] #2536733
08/15/18 01:36 PM
08/15/18 01:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By polyspheric
You might want to put a power valve in the front and jet down to 84 or so
What took everyone so long?
Because it's a crutch for a blubbery mess 3 circuit and if Chip is happy with his that's good but you are one of damn near none........ drumhit
Re: Need help tuning dominator for the street [Re: Canam800] #2536739
08/15/18 01:40 PM
08/15/18 01:40 PM
Do you know how to tell on the metering block if it will work with a power valve or not? Some will not and others will, not all the metering blocks are the same shruggy work scope
Re: Need help tuning dominator for the street [Re: Cab_Burge] #2536743
08/15/18 01:51 PM
08/15/18 01:51 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Not only that but make sure there's a hole in the p/v well to get a vacuum signal.......... thumbs
Re: Need help tuning dominator for the street [Re: Canam800] #2536745
08/15/18 01:52 PM
08/15/18 01:52 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The spec sheet posted shows it has a pvcr, so the PV should function....... just make sure it has a vacuum port in the cavity.
I doubt the motor would run “well” at part throttle if you leaned it out far enough to hurt anything.
Generally, big cam, big heads, big intake........ tuned so that it feels like it’s running pretty well at part throttle.........it’s usually still on the rich side.
Re: Need help tuning dominator for the street [Re: Canam800] #2536826
08/15/18 05:26 PM
08/15/18 05:26 PM
an8sec70cuda Offline
Mine has a PV on the primary side BTW. It is far from a blubbery mess.
Guess I'm the odd man out in this conversation...different observations about a couple different carbs I've had here.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Need help tuning dominator for the street [Re: Canam800] #2536833
08/15/18 05:47 PM
08/15/18 05:47 PM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
Ok so I have a 6.5 power valve coming and I had some jets. Do I need to change the intermediate fuel jets to drive it the 30 miles this weekend? If so should I put the intermediate air bleeds back in? They had me drill them with a .096 drill before I took them all the way out so they are bigger than the spec sheet now.
After the weekend I'm just going to have the carb done again.
Thanks for all the help
Brandon
Re: Need help tuning dominator for the street [Re: Canam800] #2536839
08/15/18 06:10 PM
08/15/18 06:10 PM
So. Burlington, Vt.
So. Burlington, Vt.
One thing at a time.
Just install the PV with like 85 jets and drive it...... see how it goes.
Tweak from there.
The pre-HP 3 circuit 4500’s didn’t have an air bleed in the int circuit.... just a hole where one could go.
Re: Need help tuning dominator for the street [Re: fast68plymouth] #2536842
08/15/18 06:22 PM
08/15/18 06:22 PM
Tweak from there.
iagree scope
Do that mod and then go drive it far enough at light part throttle cruising (1500 to 2500 RPM), not 30 miles, to see how the plugs look an if they clean up or not scope
I would put one new plug in after doing the mods to the carb. before driving it so you can see what it does also scope twocents
Let us know your results please thumbs
Re: Need help tuning dominator for the street [Re: an8sec70cuda] #2536851
08/15/18 06:40 PM
08/15/18 06:40 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Glad that works for you and apparently you got a good tune going............ thumbs Do you have a wide band to verify afr's at different engine speeds.......... beer Just asking to get info and understand how you verify that your 3-circuit is great on the street and has no blubbery or over rich issues cos if so, that's a good thing for sure just haven't seen it first hand.......... thumbs
Re: Need help tuning dominator for the street [Re: Canam800] #2537087
08/16/18 11:17 AM
08/16/18 11:17 AM
Deep DEEP SOUTH
LAD 524 Offline
LAD 524  Offline
Deep DEEP SOUTH
Looks like you're not alone Chip wink
The Dominator on my 572 Hemi is a Pro Systems 3 circuit as well. On the dyno with open headers, the AFRs from 4K and WOT up were perfect and the engine performed really well. I toyed with the idea of maybe going to a 2 circuit conversion but decided to have a go at dialling it in nicely in the car.
I have dual Widebands - one in each collector, this helped a lot as a tuning guide.
Once in the car the IABs and Int circuit needed a little tweaking along with equal reductions in jetting on both the Pri and Sec side - with a full exhaust now on the car, it really made a difference to the fuelling. The IFRs, HSABs and PVCR jet I left untouched so far.
It has a 5.5 PV in front as well, I now have it idling hot at around low 15s and cruises hi 14s/low 15s as well. There is little to no real load at idle or part throttle and despite what others have told me, I'm letting the car tell me what it likes using AFRs as a guide. The car loves the current setup, no surging, great transition and super nice plugs and clean oil. Hell, if I keep the right foot out of it it ain't half bad on the benzene consumption lol.
I'm now creeping up on the WOT and its nearly there but still a tad on the rich side need to get to the track to dial it in further. I'm guessing the PVCR jet will need to be a little smaller so I'll see what happens.
In my case I had to be super patient and persistent, make one change at a time, document each change, drive it and see what the car/engine was telling me. A bit of work - for sure, Worth it ? ABSOLUTELY !
I've found most guys don't have the patience (or time) to take the time to understand each circuit and its effects and then to dial it in properly with the right tools/parts.
Each engine is different ...gotta give it what it likes and use AFRs as a guide.
Re: Need help tuning dominator for the street [Re: Canam800] #2537105
08/16/18 12:06 PM
08/16/18 12:06 PM
New York
polyspheric Offline
polyspheric  Offline
New York
It's a debate.
Who agrees with me on almost every product? Holley.
Who does not? People in a "State of confusion".
Biggest reason to remove PV: you have no idea what it does.
Boffin Emeritus
Re: Need help tuning dominator for the street [Re: LAD 524] #2537165
08/16/18 01:55 PM
08/16/18 01:55 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
You're right about the patience part for sure and again, if YOU are happy that's all that matters but every single 2 circuit conversion is still that, a 2 and no one as far as I know has ever changed back to a 3. Forest on here went 8-flat at almost 171 mph with a 2 I converted for him and it's cleaner n meaner than ever and that's just ONE example......I also know the HEMI's have a different fuel demand than a wedge and like more fuel from my testing........... thumbs
Re: Need help tuning dominator for the street [Re: Canam800] #2537942
08/18/18 12:12 AM
08/18/18 12:12 AM
Lanse,mi
Canam800 Offline OP
Canam800  Offline OP
Lanse,mi
I just sent the carb to thumper. Decided not to mess with it and just have it set up right.
Thanks for the help
Re: Need help tuning dominator for the street [Re: Canam800] #2538003
08/18/18 03:53 AM
08/18/18 03:53 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxxx and I will hook ya up the best I can then you will have back to back real world info so we can ALL learn along the way....... thumbs
Re: Need help tuning dominator for the street [Re: Thumperdart] #2538063
08/18/18 11:49 AM
08/18/18 11:49 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
I was hanging out at the local speed shop yesterday while they were dynoing a fresh 540 shebby boat engine. The owner had them install Holley Dominator size multi port injection and they were trying to tune it.
Well, first they were just trying to get it to run well enough, long enough to start tuning. They were on their second day trying to get it lined out. They swapped a carb on to break it in and get some initial details.
They had tried about everything they knew to try, had called Holley several times and had switched back to the carb to make sure that the EFI was the problem.
I'ld hate to pay that bill. And did I mention that the boat had twin engines? So, they have this to do again. Anyone care to guess what the customer will have in his EFI when it's all said and done? $6,000? $8,000? Could it go $10,000?
Master, again and still
Re: Need help tuning dominator for the street [Re: DaveRS23] #2538068
08/18/18 12:05 PM
08/18/18 12:05 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Yep, I get those calls a lot and they see the light after all including the several I converted from corn to gas.........Kevin at CSU has a saying and in MOST cases I agree but I can't post it here but he's not a fan either..........EFI has it's place just never on my plate nor would I ever suggest it EVER............. down fan
Re: Need help tuning dominator for the street [Re: DaveRS23] #2538092
08/18/18 12:44 PM
08/18/18 12:44 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
They should have called me. I could have remote connected and tuned The Holley EFI over the Internet. I'm doing two remote sessions like this every day. Unless there's a mechanical issue this works every time. efiexpert.com
Re: Need help tuning dominator for the street [Re: Mopar_Rich] #2538247
08/18/18 09:26 PM
08/18/18 09:26 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Why doesn't Holley tech recommend you in certain cases, Rich? Why does the customer have to figure out who to call when he's struggling with their product?
I will say that when they called the engine's owner, he suggested that they call Holley tech a couple of times to see if they could get a more competent tech. Apparently, this isn't his first experience with them.
Page 2 of 3 1 2 3
