Re: 68 hp manifolds fit 67 motor?
[Re: moparx]
#2536175
08/14/18 02:28 PM
08/14/18 02:28 PM
RapidRobert
As said outlet clocking may be (90 deg) turned tho that might be a C body thing. ports/mounting would be the same & the only other potential difference could be the location of the vertical down outlet. at worst just different head pipes needed.
[Re: marcjames]
#2536190
08/14/18 02:56 PM
08/14/18 02:56 PM
Posts: 4,275 Morrow, OH
markz528
Morrow, OH
Everyone I know uses 67 440 hp manifolds on a 67 - one year only. I don't believe 68 will work well. I have both on the shelf. Will try to take a picture of them side by side later tonight.
[Re: NANKET]
#2536429
08/14/18 09:33 PM
08/14/18 09:33 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
Pasenger side is the same part number. Drivers side is different part number, will fit and work, but the pipe on left side is different clocking, same 2.5" diameter. This. This will either require a 68 head pipe, or possibly a custom one.
