Re: G's Mopar build thread (hemi, gerst, '69 Charger)
[Re: pro451bee]
#2522690
07/16/18 06:07 PM
07/16/18 06:07 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
I used a cheap sand blaster to get the nooks and crannies on my bee and it turned out nice with much less work. I have a small sand blaster! That's a good idea! ps: How did you prep the primer after the sandblasting? Finer grade sand?
[Re: gsmopar]
#2529897
08/01/18 11:21 AM
08/01/18 11:21 AM
Posts: 35,062 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
I bought and installed a new front suspension from Carl earlier this year
He was very helpful and it came over right on time as planned
Nice stuff, installed easily
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
[Re: gsmopar]
#2535257
08/12/18 08:14 PM
08/12/18 08:14 PM
Posts: 798 WA
pro451bee
WA
Don't you love the way the factory crunched the metal into shape.Fire wall looks just like my super bee.As far as primer after the blasting just clean and apply,will stick like crazy.Looks like it turned out rather Nice!
[Re: gsmopar]
#2535530
08/13/18 11:13 AM
08/13/18 11:13 AM
Posts: 13,496 Marion, South Carolina [><]
an8sec70cuda
CHIP '70 hemicuda, 575" Hemi, 727, Dana 60 '69 road runner, 440-6, 4 speed, Dana 60 '71 Demon 340, no drivetrain, on blocks behind the barn '73 Chrysler New Yorker, 440, 727, 8.75 '90 Chevy 454SS Silverado, 476" BBC, TH400, 14 bolt '06 GMC 2500HD LBZ Duramax
[Re: gsmopar]
#2535559
08/13/18 11:49 AM
08/13/18 11:49 AM
Posts: 1,688 Philadelphia
radar
Philadelphia
Looks killer!! I have instagram for my online portfolio at work- I should start a garage profile if it does image hosting like photobucket used to. I go back and forth on how to do engine bays. Sometimes I want to hide and smooth stuff but usually I end up going for simple and easy to work on. It’s crazy how much work it is to make it look super clean and sanitary. I’m sure yours will be top notch judging by the work so far. https://instagram.com/p/ie7fbOAW6z/
[Re: gsmopar]
#2545446
09/04/18 12:01 AM
09/04/18 12:01 AM
Posts: 8,793 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
How much weight does the Gerst setup save you in weight off the front end?
1969 Dart GTS 340 1969 Coronet R/T X9 N-96 1999 Dodge Dakota R/T RC 2015 Dodge Dart GT 2019 Ram 2500 Big Horn
[Re: OhioMopar]
#2545452
09/04/18 12:23 AM
09/04/18 12:23 AM
gsmopar
Arizona, USA
How much weight does the Gerst setup save you in weight off the front end? I'll have pre/post weight when I get finished. However, I'm going from a cast wedge with aluminum heads to a aluminum block hemi.
[Re: gsmopar]
#2547981
09/09/18 03:49 PM
09/09/18 03:49 PM
Posts: 2,905 Pattison Texas
CSK
Pattison Texas
I like this project, race car !!!!! lookin great
[Re: gsmopar]
#2550838
09/16/18 11:35 PM
09/16/18 11:35 PM
Superfreak
Superfreak
Looks good. What size tires on the back?
