1939-47 Dodge pickup sheet metal #2534874
08/11/18 11:54 PM
08/11/18 11:54 PM
WI
W
wannadrag Offline OP
W
WI
Going to pick up a 39 1/2 ton in the morning. The front fenders are rough, does the 39-47 stuff interchange and are the car fenders the same?
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2534923
08/12/18 02:01 AM
08/12/18 02:01 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Truck fenders will be required, and 39-47 used the same style, but 3/4 ton trucks and bigger trucks got fenders with larger wheel openings and the fenders are taller, top to bottom to clear the bigger tires. Gene
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2535333
08/12/18 09:13 PM
08/12/18 09:13 PM
WI
W
W
WI
pic of it
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2535390
08/12/18 11:11 PM
08/12/18 11:11 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
That truck looks a whole lot better then the last 2 I drug home! Did you get a title with it?
The one I'm building will be built without fenders because the fenders I have will take around 20 hours each (I'm a welder by trade) to make them usable, then they will need body work to be pretty. My truck is on a Dakota chassis, with an EFI 5.9 Magnum (360) and its computer controlled auto trans. If I don't like the fenderless drive, I will probably add some rear trailer fenders, and try some cycle style fenders that will turn with the front wheels.
In process build pictures, I need to update the pictures. Gene
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2535391
08/12/18 11:15 PM
08/12/18 11:15 PM
British Columbia, Canada
Old Ray Offline
Old Ray  Offline
She is gorgeous, ..beautiful, ...your a lucky dog !!! drool
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2535891
08/13/18 09:31 PM
08/13/18 09:31 PM
WI
W
W
WI
The cab is really nice and fenders mostly just dents,sat for years in northern WI in a area that's all sand. The C/L photos made it look way worse than what it is. Does have the typical frame rot by the leaf spring hangers in front of the rear axle which is a easy fix and the box I think may be Studebaker.
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2537424
08/16/18 10:34 PM
08/16/18 10:34 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Originally Posted By wannadrag
pic of it
If those rear fenders are as straight as they look in the pictures you hit the lottery! Good luck with the truck! up
Re: 1939-47 Dodge pickup sheet metal [Re: moparpollack] #2537715
08/17/18 03:18 PM
08/17/18 03:18 PM
WI
W
W
WI
Rear fenders are real close to perfect with a few small dings, front ones need some love with torch, hammer and dolly. Pass side has a pretty good crunch in it
pic of it
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2548365
09/10/18 12:29 PM
09/10/18 12:29 PM
Shelby, Ohio
2
2abodymcodes Offline
Shelby, Ohio
Love those old Dodge trucks. Here is mine, 1942 with Fat Man front suspension, 8 3/4 rear end with 69 roadrunner springs, late model 360 magnum and 904 tranny. I used the original frame but I boxed it in.
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2549083
09/12/18 12:10 AM
09/12/18 12:10 AM
Canada
demon Offline
demon  Offline
Canada
1/2 ton to 1 ton use the same fenders. 1 1/2 ton and bigger has fenders with larger openings and the running boards are not attached.
39-40 have the headlights set close together. 41-47 have the headlights far apart and also have a recess for the headlight bucket stamped into the fender.
Re: 1939-47 Dodge pickup sheet metal [Re: demon] #2549247
09/12/18 02:36 PM
09/12/18 02:36 PM
dogdays Offline
dogdays  Offline
That truck is SO COOL!
R.
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2560599
10/07/18 10:48 PM
10/07/18 10:48 PM
WI
W
W
WI
Well here is the look I was after,89 Dakota chassis and using the V6 so the engine is in the stock location.
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2560795
10/08/18 10:54 AM
10/08/18 10:54 AM
85086
Lil Herman
Lil Herman
85086
Looks great! beer
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2615336
01/31/19 10:16 PM
01/31/19 10:16 PM
WI
W
W
WI
Made some progress the last few weeks finally got it running,just need some glass,lights and warm weather for a test ride
Re: 1939-47 Dodge pickup sheet metal [Re: wannadrag] #2615348
01/31/19 10:46 PM
01/31/19 10:46 PM
Old Ray Offline
Old Ray  Offline
Looks good ! up
Re: 1939-47 Dodge pickup sheet metal [Re: Old Ray] #2665352
06/12/19 10:12 PM
06/12/19 10:12 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
Great looking trucks in this thread!
I have a '41 with a 318/904 on the stock straight axle suspension. I'm adding the Scarebird kit for disc brakes on the front. I have a long ways to go on it. Anything sheetmetal seems difficult to locate for these trucks. It took years to even locate a replacement leaf spring for the front end.
Re: 1939-47 Dodge pickup sheet metal [Re: DusterKrazy] #2665628
06/13/19 07:29 PM
06/13/19 07:29 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
We are fortunate with this era Dodge trucks. This is the cab/chassis most of the WW2 Dodge military trucks were built from. The military trucks have a huge following, so parts are still being reproduced by a few good companies.
www.vintagepowerwagons.com reproduces a lot of mechanical parts that work on our civilian trucks. www.robertsmotorparts.com also reproduces a lot of civilian truck parts, when your looking for new stuff, I go to each of them 1st. Being the reproduction people, almost everyone that offers parts from these trucks get them there, mark up the price and sell it to you. However, there are some smaller operations that also reproduce parts for these (and other Dodge trucks), these two are the major suppliers, but not the only suppliers.
A lot of the mechanical parts can still be bought new, maybe reproduction, but pretty accurate stuff, some with improvements built in to correct the original flaws.
Unfortunately, most body stuff (and nearly any other repoed part) is made on short runs, if you happen to be in the market as a run is going on, its your lucky day. After the production run ends, the parts become scarce (and pricey) until the next run is made. The only reproduction fenders I've seen are fibreglass, and also fall under the short run issues. Gene
