Original 340 Spark Plug Wires-Coil Boot #2533623
08/09/18 09:21 AM
08/09/18 09:21 AM
Land of 10,000 Lakes
44D6PAKCUDA Offline OP
Did original/OE 1970-1 340 coil wires have the red boot like the big block wires had? Thanks !
Re: Original 340 Spark Plug Wires-Coil Boot [Re: 44D6PAKCUDA] #2533653
08/09/18 10:53 AM
08/09/18 10:53 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, but keep in mind that it was a very dark brick red, often confused with black at a glance.
Re: Original 340 Spark Plug Wires-Coil Boot [Re: ScottSmith_Harms] #2534814
08/11/18 10:52 PM
08/11/18 10:52 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Do you have any pictures of these red coil boots? I can't say that I've ever seen one. I know some of the mid to late 50's engines had a red boot on the #1 wire at the dist cap.
Re: Original 340 Spark Plug Wires-Coil Boot [Re: cudaize] #2534818
08/11/18 11:00 PM
08/11/18 11:00 PM
SE PA
cudaize Offline
cudaize  Offline
SE PA
Actually never mind the picture. I remembered that I had an NOS big block wire set in the basement and this one has the red coil wire boot, guess I never looked at it closely.
Re: Original 340 Spark Plug Wires-Coil Boot [Re: cudaize] #2534825
08/11/18 11:09 PM
08/11/18 11:09 PM
You know I could cut them down for a 340 smile
Re: Original 340 Spark Plug Wires-Coil Boot [Re: 44D6PAKCUDA] #2534845
08/11/18 11:39 PM
08/11/18 11:39 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Here's a couple I have... variations in shade of boot in each but both are factory.
Re: Original 340 Spark Plug Wires-Coil Boot [Re: mccannix] #2534966
08/12/18 10:03 AM
08/12/18 10:03 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Jim, you wouldn't want to cut those down for your Cuda.
Those are Chrysler Canada Ltd wires installed on cars built at the Windsor Ontario Plant.
I have a set of 70 and 71's of those as well, but as you know US built cars have the Chrysler Corporation script instead.
