valley pan install? #2533209
08/08/18 11:28 AM
08/08/18 11:28 AM
ny
marcjames Offline OP
ny
I am installing a felpro 1215 valey pan do you guys use the gaskets that come with it or just use RTV 67 440 motor stock I want to block of the exhaust passage to the intake thanks mark I put a quick fuel carb
Re: valley pan install? [Re: marcjames] #2533213
08/08/18 11:38 AM
08/08/18 11:38 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Never used the papers even with aluminum heads and or intake.I install mine dry.I use the pan that has the block off built in.Just a bit of silicone in the 4 corners and a bit where the hold downs go.Never a problem since the 60s when I started working on them.Rocky
Chrysler Firepower
Re: valley pan install? [Re: marcjames] #2533214
08/08/18 11:42 AM
08/08/18 11:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
don't use the papers unless the manifold has been milled to compensate for them.
Re: valley pan install? [Re: marcjames] #2533238
08/08/18 12:30 PM
08/08/18 12:30 PM
USA
Suregrip391 Offline
Suregrip391  Offline
USA
Just did this on a 383 using a felpro Valley Pan. I agree with all of the above. No leaks! Just clean up your surfaces. Torque to proper spec and sequence. I used “the right stuff” in the corners and hold down area. I hear the stuff in the small tube that comes with the gasket is not that good but I never had any personal experience with it to comment on it’s sealing ability.
Re: valley pan install? [Re: marcjames] #2533295
08/08/18 02:37 PM
08/08/18 02:37 PM
Set the intake gaskets on the head and use some Gasket Cinch to hold them in place and then install the valley pan loosely to see if it fits snugly or has a gap between the gasket and pan with the intake manifold place on top of the pan scope If it is loose try adding the other gasket on top of the pan, if it is tight with one and the manifold bolt holes look like they are near the top of the valley pan remove the gasket and see if that fits better scope
Every motor is different so you need to check the fit and use what fits the best up
