Re: Starting line ratio ??? [Re: 03heavy] #2530583
08/02/18 06:12 PM
08/02/18 06:12 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
12.49 in my truck with 28" tires and its totally uncontrollable on the street
Re: Starting line ratio ??? [Re: 03heavy] #2530632
08/02/18 08:09 PM
08/02/18 08:09 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
Shouldn't SLR be somehow equatable to power to weight ratio?
Seems like you should be able to get something that would compute to an approximate 60 ft time
Re: Starting line ratio ??? [Re: 03heavy] #2530660
08/02/18 08:53 PM
08/02/18 08:53 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
Originally Posted By 03heavy
From what I’m seeing the most guys using a 3 speed
With a aggressive rear axle ratio and a trans brake have trouble
With the 60’s Or from what I can tell anyways
You use a 904/727 or a glide whitedart
I have both a 904 and a Powerglide.. I think the issue is shocks. And Springs.. I believe it was Al that said by the best shock you can afford and I agree 100%.. also have worked with John Calvert with getting the correct leaf spring for my car..
In the 8s N/A.with Brett miller W8's
5.07 at 133 at 2700lb
Re: Starting line ratio ??? [Re: 65Fury440] #2530708
08/02/18 10:49 PM
08/02/18 10:49 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
Except that doesn't take into account
A; Tire type/size
B; Suspension type
C; Shocks
D; Weight distribution
E; Trans type stick/auto
F; Converter/clutch
G; Starting line RPM
H; trans brake/foot brake
It's no secret that just like anything else in racing there are different levels of tuning. The fast guys put as much power to the starting line as possible. That is power x SLR x torque stall ratio. Others run huge tires and less gear for consistency. That being said as power goes up you will reach a limit of how much SLR the track can take. Some guys can go both quick and consistent with SLR that others say won't work. Depends on how hard you want to work at it.
Doug
Re: Starting line ratio ??? [Re: A727Tflite] #2530794
08/03/18 01:19 AM
08/03/18 01:19 AM
Originally Posted By Transman
Cab, how fast did the car run in 1988?
What cam did you use back then ?
That car ran a best of 11.23 at 119.+ MPH at that race, it had a bunch of string sucked up into the fuel pickup that I was not aware of until after I sold it right after that race. All the other M.W. Mopars running in B/SA at that race where running 122.+ MPH but I contributed that to them having the bigger 1964 carbs, intake and camshaft realcrazy
I had all of them cover by .17 ET, but I was my car was down 3.0 MPH whiney I ran the Firestone 30x9x15 slicks tubeless that where around 96.3 inches in circumference with 16 to 18 lbs. in them on a ten inch rim.
The cam was a Lunati legal cheater cam with the lash set at .012 and .014 hot, that car was completely legal up
I loved that car, I won a bunch of races with it and made a lot of money racing it boogie
The good old days whistling shruggy
Re: Starting line ratio ??? [Re: Cab_Burge] #2530810
08/03/18 02:32 AM
08/03/18 02:32 AM
A727Tflite Offline
A727Tflite  Offline
Thanks for the reply.
Sounds like it was a 63 car.
Re: Starting line ratio ??? [Re: 03heavy] #2530815
08/03/18 03:12 AM
08/03/18 03:12 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
03heavy,
For the type of racing you want to do, don't get hung up on killing the 60ft. clocks. I've done a ton of index racing over the years, and getting the car to react the same every time in the first 10 feet is more critical to good reaction times than an impressive 60ft.
My car is ladder bar/coil over, so I realize you have more challenges to make it work, and the .4 pro tree is a pain for these types of classes. In addition to driving my car on Drag Week, and spraying it on occasion, I knew I would end up index racing as well, and I love the D Gas 10.60 index .4 tree racing at NHRA Nostalgia races, and I've also done some of the 10.0 stuff at Street Car Takeover.
My 428 small block made 615Hp at 6700, and is over 500 ft.lbs of torque from 4400 to 6200 on the dyno. The top picture on my previous post was the car leaving on the trans brake, with the two step at 4200, NA. My sixties are typically 1.40-1.43 in this configuration, but my best light is .042 in a .4 tree without rolling in a little. The car just has too much front travel right now, and perhaps a little more tire pressure in the rear would help. For reference my best NA ET is 10.39-128. I think the converter is 300rpm too tight, and the 3.89 gear is too tall for max effort. Best on nitrous is 9.43-139. The 8" converter can't really hold the torque, and the 3.89 gear is too short to pull all the way to the stripe! Such is the the plight of a multi-use street car!!
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Starting line ratio ??? [Re: WHITEDART] #2531039
08/03/18 04:10 PM
08/03/18 04:10 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Shocks and springs and tuning are critical to getting the best from your combination. But if the combination (i.e. low gear ratio) is out of whack, one way or the other, it becomes difficult or impossible to get the car to run as quick as it's capable of or even control the tire. The suspension and transmission parts - including available gear ratios, tuning, converters and tech, coming out of the very high horsepower Pro Mod and drag radial world, is crazy. All about tire management.
Re: Starting line ratio ??? [Re: 03heavy] #2531053
08/03/18 04:38 PM
08/03/18 04:38 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
Thanks guys for the insight
And whitedart you have a nasty machine ( Been checking it out on YouTube )
Mines gonna go together as planned
But now I have a little more direction
Will call Calvert and talk about the springs suggestions and probably get a good DA shock
on it before I even put it on the ground
Re: Starting line ratio ??? [Re: CMcAllister] #2531157
08/03/18 08:27 PM
08/03/18 08:27 PM
Texas
0
03heavy Offline OP
03heavy  Offline OP
Texas
Whitedart I found some of your videos from under the car while launching
Not sure if they were the glide or the 904 they were about a year old
The videos are helpful
Gonna set mine be up like yours
Nice to know the lower blocks aren’t a issue
Who’s shock are you using
Any-who thanks
Re: Starting line ratio ??? [Re: 03heavy] #2531199
08/03/18 09:25 PM
08/03/18 09:25 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
At the time those videos were taken I believe I was on a 28.10.5 Tire.. with viking da shocks. Set up with drag radial valving the lowering blocks are made by Calvert they are half inch thick made of steel and designed to be stacked.. if you're going to stack blocks make sure you get the steel ones. When you speak to Calvert you will want to talk about the type of racing you are planning on doing. As well as the weight of the vehicle and right height lower the better
.. beer
Re: Starting line ratio ??? [Re: WHITEDART] #2531234
08/03/18 10:27 PM
08/03/18 10:27 PM
Washington
madscientist Offline
Washington
.. beer
What's wrong with the aluminum lowering blocks? I only need 1/2 to maybe 3/4 inch drop so I won't need to stack them. Is aluminum ok if I don't stack them?
Re: Starting line ratio ??? [Re: 03heavy] #2531258
08/03/18 11:08 PM
08/03/18 11:08 PM
baldwinsville new york
a493demon Offline
a493demon  Offline
I have alum 1 inch on mine and no issue so far
Re: Starting line ratio ??? [Re: madscientist] #2531261
08/03/18 11:10 PM
08/03/18 11:10 PM
bean town ....Ca
W
WHITEDART Offline
WHITEDART  Offline
W
bean town ....Ca
I have been told it's not the best of ideas
Re: Starting line ratio ??? [Re: WHITEDART] #2531272
08/03/18 11:33 PM
08/03/18 11:33 PM
iagree I've heard the same thing on race cars up
Re: Starting line ratio ??? [Re: WHITEDART] #2531274
08/03/18 11:35 PM
08/03/18 11:35 PM
Washington
Washington
Ok thanks. Glad I heard this because I'm just getting ready to order them. I'm buying steel.
Thank you
Re: Starting line ratio ??? [Re: 03heavy] #2531430
08/04/18 11:57 AM
08/04/18 11:57 AM
New York
polyspheric Offline
polyspheric  Offline
New York
Aluminum captured between 2 exactly flat, very rigid parallel structures is safe.
Otherwise not.
Boffin Emeritus
Re: Starting line ratio ??? [Re: 03heavy] #2531503
08/04/18 02:48 PM
08/04/18 02:48 PM
New Hampshire, USA
O
oldiron Offline
oldiron  Offline
O
New Hampshire, USA
SLR = 14
but then....someone left the torque converter out
66 Belvedere Vert, 4 Speed/Jerico, slowly, very slowly, getting faster - NA LD Wedge
New New Best: 10.56 @129
68 B'cuda 4 gear Jerico - Another New Best of 9.86 & Trying to slow up
https://www.youtube.com/watch?v=T4jDLKwd9Gs
