Re: Bump starter switch?
[Re: Mopar_Ray]
#2530997
08/03/18 03:01 PM
08/03/18 03:01 PM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
one to the starter big wire and one to the selinoid (spellin)
[Re: bonefish]
#2531006
08/03/18 03:19 PM
08/03/18 03:19 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
one to the starter big wire and one to the selinoid (spellin) Thanks, That’s how I have it hooked up and it does bump the starter, but I thought the key had to be in the run position and it bumps the starter with no key. Just don’t want to burn up anything?
[Re: burdar]
#2531018
08/03/18 03:42 PM
08/03/18 03:42 PM
Posts: 512 Illinois
Mopar_Ray
Illinois
The big wire has power all the time. It comes directly from the battery. Your bump switch is bypassing the ignition switch. It's working as it should.
If you have the key turned on, the engine could potentially start. Be careful! Thanks, MSD igiition is on a switch and off
[Re: Mopar_Ray]
#2531165
08/03/18 08:39 PM
08/03/18 08:39 PM
Posts: 18,678 Fresno, CA
Jim_Lusk
Fresno, CA
I usually disconnect the yellow ("I" terminal) wire and jump from the big post to the "I". This runs the least amount of current through the starter switch. This also requires the NSS to be working correctly.
[Re: Jim_Lusk]
#2533218
08/08/18 11:44 AM
08/08/18 11:44 AM
Posts: 5,789 Hamilton, Ontario Canada
Magnum
I usually disconnect the yellow ("I" terminal) wire and just from the big post to the "I". This runs the least amount of current through the starter switch. This also requires the NSS to be working correctly. ^Best method for the 2 reasons mentioned.
