Page 1 of 3 1 2 3
Torsion bar anchor slipping? #2530048
08/01/18 04:22 PM
08/01/18 04:22 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Posted this in 'Suspension" but no looks yet.
This on a 70 Charger RT, changed to heavier bars this year to remedy what we thought was a sagging bar on driver's side.
Now sagging is apparent on that side again.
Figured bar anchor in rear cross member was the culprit, but today's inspection revealed movement in lower control arm asbly.
Looks like we can loosen the suspension to the point where you install a new bar and weld the perimeter of the front anchor.
Does this sound like a fix, or am I missing something?
Thanks, Joe
PS. New adjusting blocks and bolts
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530083
08/01/18 05:06 PM
08/01/18 05:06 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If you are describing what I think you are describing it is supposed to move.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530133
08/01/18 06:43 PM
08/01/18 06:43 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
The part that receives the front of the torsion bar is a separate piece from the lower control, arm it is pressed/welded into the control arm at the pivot point and exerts the twisting force to the T-bar.
If it is allowed to move, how does it transmit the twisting force??
Thanks, Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530139
08/01/18 07:00 PM
08/01/18 07:00 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
via the adjuster, see the red part? That rides on the ball of the adjuster bolt and it's part of the T bar socket, it (socket and lever) will rotate with no load on it.
Don't be the exception.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530142
08/01/18 07:07 PM
08/01/18 07:07 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Well then, that lends credence to the suggestion that the K-frame may be at fault, I'll look tomorrow.
Thanks, Joe
But....is that lever and socket one piece?
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530156
08/01/18 07:29 PM
08/01/18 07:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
No, they can't be or you couldn't install it into the LCA when it's assembled. Good point
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530302
08/02/18 01:17 AM
08/02/18 01:17 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Yes, the lever and socket are one piece. I have seen stripped threads in the adjuster.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530329
08/02/18 02:40 AM
08/02/18 02:40 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Adjusters are new, old adjusters were fine, I think the problem is elsewhere.
Adjusting lever is a casting, I don't think the T-bar socket is cast.
The FSM shows them as separate pieces.
Thanks, Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530332
08/02/18 02:44 AM
08/02/18 02:44 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Check the mounting sleeve in the K-frame itself. I've seen many break loose and spin.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530366
08/02/18 09:30 AM
08/02/18 09:30 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That piece in the lower control arm should be stationary and should move with the control arm as it moves thru it's arc twisting the T bar. The tube in shouldn't have a big effect outside of the bushing not twisting as the control arm moves up and down.
I think you should go back to looking at the rear socket , I assume you have marked it to check for movement? the only other thing is if the front socket and it's lever are not actually one piece and are 2 then it could have slipped? I don't have a control arm handy to look at ...
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530459
08/02/18 01:32 PM
08/02/18 01:32 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Well, it looks like we'll have to take it out so we can give it a good look at how the front socket and adjusting lever are mated.
See no problem with the rear socket and all frame parts including K-frame are solid, this was a S. Carolina car originally.
I'll get back here as soon as we undo everything.
Thanks everyone, Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530537
08/02/18 04:15 PM
08/02/18 04:15 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
After some confusing responses, not all, the best thing for YOU to do is get that control arm off and on the bench to study it. You should see the lever , that adjuster bolt rests into the bottom of, should freely turn WITH the front T bar socket. You can rotate it some, but not 360 degrees tough. Never saw those 2 pieces turn separate of each other. If you upgraded bars, during re-install,don't be surprised when you have to pull the arms down pretty low to insert bar in front and rear.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530557
08/02/18 05:15 PM
08/02/18 05:15 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks Buildanother,I replaced the bars as I said to correct what I thought was a sagging bar on the driver's side, never thinking that the socket may have slipped on the adj. arm.
So the new bar re-install went well, dropped everything as low as it would go and removed the bump cushions too.
Went well because the driver's side socket had apparently moved enough that it had indexed to the next flat on the hex.
I'm really intrigued as to how mother MOPAR have the two parts joined.
Worse comes to worst, I imagine I my be able to put t the two pieces in the proper position and drill through them to put a good sized hardened pin through and somehow stake it to stay...we'll see
Thanks, Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530604
08/02/18 06:43 PM
08/02/18 06:43 PM
md
mopars4ever Offline
mopars4ever  Offline
md
I`m thinking that part( the lever and hex head) must be one piece and then they put the 2 halves of the arm together around it. I don`t see how it could move separately from one another. I may be wrong as I never had the arm apart to see for sure. If it is moving then I would just look for a replacement arm. Not sure I would try to repair it.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2530731
08/02/18 11:23 PM
08/02/18 11:23 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
The FSM shows the hex as a separate part, we'll get some answers in a couple of days.....
Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2531139
08/03/18 07:52 PM
08/03/18 07:52 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Makes me wonder why they would show it separate as it is not a serviceable part. The bushing, shaft, adjusting bolt and swivel and ball joint are the only service parts. Can you post a pic of the service manual page or pages? Just curious.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2531161
08/03/18 08:34 PM
08/03/18 08:34 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I've got a junk A-body arm out in the garage. I'll cut it apart and see what the socket/adjuster arm look like.
Re: Torsion bar anchor slipping? [Re: jlatessa] #2531342
08/04/18 01:42 AM
08/04/18 01:42 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
I was mistaken, looking at the diagram in the FSM, I thought I was looking at the rear of the lower control arm when I was actually looking at the front.
Rats, I hate admitting mistakes...
Anyhow the mystery continues, as we started dis-assembling, the NEW adjusting screw and block were very difficult to undo and the threads on the screw were galled to where it's unusable... How??? Everything was lubricated on assembly.
Can't imagine it slipping though as tight as it was.
We'll see as soon as we finish.
Have a lead on a replacement control arm, hopefully he has it.
Thanks for the guidance, Joe
Re: Torsion bar anchor slipping? [Re: jlatessa] #2531351
08/04/18 02:08 AM
08/04/18 02:08 AM
md
mopars4ever Offline
mopars4ever  Offline
md
Did you adjust them with the car jacked up and the weight off? Are they offshore adjusters or mopar ones?
Re: Torsion bar anchor slipping? [Re: mopars4ever] #2531361
08/04/18 02:26 AM
08/04/18 02:26 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have an a-body set out of the car and it appears the perimeter of the lever arm is welded to the round part that the t-bar plugs into.
Page 1 of 3 1 2 3
