Re: Tom Waters Race Car Products 904 Trans Shield
[Re: 340Cuda]
#2528093
07/27/18 10:27 PM
07/27/18 10:27 PM
Posts: 4,963 new jersey usa
11secdart
new jersey usa
I have a CSR shield on my 68 Dart , 408 Small Block , Indy 360-1 heads, TTI W2 headers, 904, with a Turbo Action shifter.
[Re: 340Cuda]
#2528377
07/28/18 07:18 PM
07/28/18 07:18 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
I got 3 CSR shields on A bodies with 904 and all fit without any banging on the trans tunnel...
notched the K member..and it all drops in easy
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: 340Cuda]
#2528569
07/29/18 11:56 AM
07/29/18 11:56 AM
11secdart
new jersey usa
Only mods to trans tunnel are the access holes I put in so I could reach the top bell housing bolts easier which I have plates to cover. You do have to grind off a few bosses on the bellhousing to clear the shield. I don't have to have the shield as the car is slowed to run mid 11s but have it for safety, it does add about an hour to a trans removal.
[Re: J_BODY]
#2528582
07/29/18 12:22 PM
07/29/18 12:22 PM
Posts: 3,496 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
https://racecarpartsdepot.com/shop?olsPage=products%2Fchry-904
...if this is the piece you’re referencing I’d say you’ll be making a new tunnel, and if 9.99 or faster you’ll also have to purchase the “flex plate shield”. Yes that's it. Its a 10 sec car no SFI flexplate or flexplate shield required.
[Re: 70AARcuda]
#2528585
07/29/18 12:30 PM
07/29/18 12:30 PM
340Cuda
Tulsa, Oklahoma
notched the K member..and it all drops in easy Hopefully my 69 was an exception. CSR recently refused to re-certify a 904 shield "because it was too old". I have heard others say they will only re-certify twice. We were going to use a Stroud blanket, they say they have no limits on how many times they will re-certify. However they feel for a Drag Week car there should be at least three inches of clearance between the headers and the trans to keep the blanket from getting cooked. I don't think we have that much.
[Re: 340Cuda]
#2528593
07/29/18 01:00 PM
07/29/18 01:00 PM
11secdart
new jersey usa
I recently went from Tubular Automotive headers to TTI s and they fit a lot closer to the trans and shield the bottom strap is really close to the collector. I have a Turbo Action shifter and had to modify the shifter cable bracket clamp as it is exactly were the collector flange meets the exhaust pipes. Seeing how close the shield is to the headers I can't imagine how tight a blanket will be to them. But I am sure there are a lot out there with a TTI blanket combo.
[Re: SportF]
#2528980
07/30/18 12:15 PM
07/30/18 12:15 PM
340Cuda
Tulsa, Oklahoma
If you are running a blanket, run it over the torsion bars. It is usually too close to the headers if you try to wrap the trans. Surprised that would pass tech, but something to look into.
[Re: 340Cuda]
#2529096
07/30/18 03:44 PM
07/30/18 03:44 PM
Posts: 8,005 Tulsa OK
Bad340fish
Tulsa OK
This is for my car and Tech at drag week last year was pretty tight, they bounced several to slower ETs because of insufficient trans shields or blankets. I know if I have one they won't look, that happens all the time. But not having one is an invite to inspection in my world haha. I should have one anyways for safety but I need one for tech.
68 Barracuda Formula S 340 87 "Chrysler" Conquest
[Re: 340Cuda]
#2529405
07/31/18 08:40 AM
07/31/18 08:40 AM
Posts: 1,206 Minn
SportF
Minn
If you are running a blanket, run it over the torsion bars. It is usually too close to the headers if you try to wrap the trans. Surprised that would pass tech, but something to look into. There is nothing in the rules that tell you how to mount a blanket. This will protect the driver and that is what matters. I have said this many times before, I seen an explosion with a shield, which did nothing. That racer almost lost his foot. The shield, what was left, was a yellow ball of yarn (Kevlar). A 904 is safer, but I will never run a shield.
[Re: SportF]
#2529407
07/31/18 09:05 AM
07/31/18 09:05 AM
Bad340fish
Tulsa OK
Maybe I am misunderstanding your routing but on my car after going around the torsion bars it would have to go back over the exhaust to tie back up. Its looking like the CSR Shield is going to be the only option, and with the time at hand we will likely be robbing the current SFI one out of my Dad's car(340Cuda) thanks Dad! lol
